用的STC12C5A32S2,3.75點陣LED做顯示,8X24頻譜源代碼下載:
8X24頻譜顯示程序.rar
(64 KB, 下載次數(shù): 100)
2016-3-11 22:30 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
主程序:
- #include <STC12C5A60S2.h>
- #include<intrins.h>
- #define SAMPLE_NUM 128
- #define LOG 6
- #define TIME 2048 //中斷
- #define FFT_OUT_MIN 0
- #define FFT_OUT_MAX 7
- #define OFF L1=L2=L3=L4=L5=L6=L7=L8=L9=L10=L11=L12=L13=L14=L15=L16=L17=L18=L19=L20=L21=L22=L23=L24=1;
- #define ADC_POWER 0x80 //ADC power control bit
- #define ADC_FLAG 0x10 //ADC complete flag
- #define ADC_START 0x08 //ADC start control bit
- //#define ADC_SPEEDLL 0x00 //420 clocks
- //#define ADC_SPEEDL 0x20 //280 clocks
- #define ADC_SPEEDH 0x40 //140 clocks
- //#define ADC_SPEEDHH 0x60 //70 clocks
- //采樣存儲序列表
- unsigned char code BRTable[SAMPLE_NUM] ={0, 64, 32, 96, 16, 80, 48, 112,
- 8, 72, 40, 104, 24, 88, 56, 120,
- 4, 68, 36, 100, 20, 84, 52, 116,
- 12, 76, 44, 108, 28, 92, 60, 124,
- 2, 66, 34, 98, 18, 82, 50, 114,
- 10, 74, 42, 106, 26, 90, 58, 122,
- 6, 70, 38, 102, 22, 86, 54, 118,
- 14, 78, 46, 110, 30, 94, 62, 126,
- 1, 65, 33, 97, 17, 81, 49, 113,
- 9, 73, 41, 105, 25, 89, 57, 121,
- 5, 69, 37, 101, 21, 85, 53, 117,
- 13, 77, 45, 109, 29, 93, 61, 125,
- 3, 67, 35, 99, 19, 83, 51, 115,
- 11, 75, 43, 107, 27, 91, 59, 123,
- 7, 71, 39, 103, 23, 87, 55, 119,
- 15, 79, 47, 111, 31, 95, 63, 127};
- char code sin_tabb[SAMPLE_NUM] = {0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70, 75, 80, 85, 89, 94, 98, 102,
- 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126, 126, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112,
- 108, 105, 102, 98, 94, 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30,
- -36, -42, -48, -54, -59, -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121,
- -123, -124, -125, -126, -126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102,
- -98, -94, -89, -85, -80, -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6};
- char code cos_tabb[SAMPLE_NUM] = {127, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112, 108, 105, 102, 98, 94,
- 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30, -36, -42, -48, -54, -59,
- -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121, -123, -124, -125, -126, -
- 126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102, -98, -94, -89, -85, -80,
- -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6, 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70,
- 75, 80, 85, 89, 94, 98, 102, 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126};
- xdata unsigned char result[128];
- xdata unsigned char temp[128];
- xdata unsigned char num[128];
- unsigned char anum,timernum,timernum2,lednum3,Ltime,t;//用于分離
- unsigned char lednum[]={0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//0-7的顯示數(shù)組 P2組控制
- int xdata FftReal[SAMPLE_NUM];
- int xdata FftImage[SAMPLE_NUM];
- unsigned char code musicdisplay[]={
- 0x00,0x00,
- 0xFE,0x40,0x30,0x40,0xFE,0x00, // -M-
- 0xFC,0x02,0x02,0x02,0xFC,0x00, // -U-
- 0x64,0x92,0x92,0x92,0x4C,0x00, // -S-
- 0x00,0x82,0xFE,0x82,0x00,0x00, // -I-
- 0x7C,0x82,0x82,0x82,0x44,0x00, // -C-
- 0x00,0x00,0x00,
- 0xFE,0x82,0x82,0x82,0x7C,0x00, // -D-
- 0xFE,0x90,0x90,0x90,0x60,0x00, // -P-
- 0xFE,0x02,0x02,0x02,0x02,0x00, // -L-
- 0x3E,0x48,0x88,0x48,0x3E,0x00, // -A-
- 0xC0,0x20,0x1E,0x20,0xC0,0x00, // -Y-
- 0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00};
- #define LED P2
- #define pwm 9
- /////////// 列掃描端口
- sbit L24=P4^7;
- sbit L23=P1^4;
- sbit L22=P1^5;
- sbit L21=P1^6;
- sbit L20=P1^7;
- sbit L19=P3^0;
- sbit L18=P3^1;
- sbit L17=P3^2;
- sbit L16=P3^3;
- sbit L15=P3^4;
- sbit L14=P3^5;
- sbit L13=P3^6;
- sbit L12=P3^7;
- sbit L11=P0^0;
- sbit L10=P0^1;
- sbit L9=P0^2;
- sbit L8=P0^3;
- sbit L7=P0^4;
- sbit L6=P0^5;
- sbit L5=P0^6;
- sbit L4=P0^7;
- sbit L3=P4^6;
- sbit L2=P4^5;
- sbit L1=P4^4;
- void delay(unsigned char a)
- unsigned int i;
- while(--a)
- for(i=0;i<50;i++);
- void off()
- LED = 0x00;
- OFF
- // delay(10-pwm);
- void display(unsigned char i,unsigned char dat)
- P2=dat;
- switch(i)
- case 1:L1=0;break;
- case 2:L2=0;break;
- case 3:L3=0;break;
- case 4:L4=0;break;
- case 5:L5=0;break;
- case 6:L6=0;break;
- case 7:L7=0;break;
- case 8:L8=0;break;
- case 9:L9=0;break;
- case 10:L10=0;break;
- case 11:L11=0;break;
- case 12:L12=0;break;
- case 13:L13=0;break;
- case 14:L14=0;break;
- case 15:L15=0;break;
- case 16:L16=0;break;
- case 17:L17=0;break;
- case 18:L18=0;break;
- case 19:L19=0;break;
- case 20:L20=0;break;
- case 21:L21=0;break;
- case 22:L22=0;break;
- case 23:L23=0;break;
- case 24:L24=0;break;
- delay(pwm);
- off();
- void show_musicdisplay()
- unsigned char a,b,c;
- for(c=0;c<80;c++)
- for(b=12;b>0;b--)
- for(a=1;a<25;a++)
- display(a,musicdisplay[a-1+c]);
- void FFT_process() //下落遲滯
- unsigned char i;
- for(i=0;i<24;i++)
- if(result[i] < temp[i])
- num[i]++;
- if(num[i] == 1)
- if(temp[0]==0&&temp[1]==0&&temp[2]==0&&temp[3]==0&&temp[4]==0&&temp[5]==0&&temp[6]==0&&temp[7]==0&&temp[8]==0&&temp[9]==0&&temp[10]==0&&temp[11]==0&&temp[12]==0&&temp[13]==0&&temp[14]==0&&temp[15]==0&&temp[16]==0&&temp[17]==0&&temp[18]==0&&temp[19]==0&&temp[20]==0&&temp[21]==0&&temp[22]==0&&temp[23]==0&&temp[24]==0);
- else
- result[i] = --temp[i];
- num[i] = 0;
- else
- num[i] = 0;
- void disp()
- // unsigned char i,j,buff;
- timernum++;
- if(timernum == 25)
- timernum = 1;
- OFF
- FFT_process();
- /*for(i=0;i<16;i++)
- for(j=i+1;j<16;j++)
- if(result[j] > result[i])
- buff = result[i];
- result[i] = result[j];
- result[j] = buff;
- switch(timernum)
- case 1:anum = result[0];L1=0;break;
- case 2:anum = result[1];L2=0;break;
- case 3:anum = result[2];L3=0;break;
- case 4:anum = result[3];L4=0;break;
- case 5:anum = result[4];L5=0;break;
- case 6:anum = result[5];L6=0;break;
- case 7:anum = result[6];L7=0;break;
- case 8:anum = result[7];L8=0;break;
- case 9:anum = result[8];L9=0;break;
- case 10:anum = result[9];L10=0;break;
- case 11:anum = result[10];L11=0;break;
- case 12:anum = result[11];L12=0;break;
- case 13:anum = result[12];L13=0;break;
- case 14:anum = result[13];L14=0;break;
- case 15:anum = result[14];L15=0;break;
- case 16:anum = result[15];L16=0;break;
- case 17:anum = result[16];L17=0;break;
- case 18:anum = result[17];L18=0;break;
- case 19:anum = result[18];L19=0;break;
- case 20:anum = result[19];L20=0;break;
- case 21:anum = result[20];L21=0;break;
- case 22:anum = result[21];L22=0;break;
- case 23:anum = result[22];L23=0;break;
- case 24:anum = result[23];L24=0;break;
- if(anum >= 8)
- anum = FFT_OUT_MAX;
- LED = lednum[anum];
- void ADC_init()
- P1ASF = 0x01; //Open 8 channels ADC function
- ADC_RES = 0; //Clear previous result
- ADC_RESL= 0;
- ADC_CONTR = ADC_POWER | ADC_SPEEDH;
- delay(5); //ADC power-on and delay
- float ADC_read()
- //delay(10);
- ADC_CONTR = ADC_POWER | ADC_SPEEDH | ADC_START;
- _nop_(); //至少要延時4個時鐘周期
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
- ADC_CONTR &= ~ADC_FLAG; //關(guān)閉ADC
- return (ADC_RES*4+ADC_RESL); //Return ADC result
- short sqrt_16(unsigned long M)
- unsigned int N,i;
- unsigned long tmp,ttp;
- if( M == 0 )
- return 0;
- N = 0;
- tmp = (M >> 30);
- M <<= 2;
- if( tmp > 1 )
- N++;
- tmp -= N;
- for( i=15; i>0; i-- )
- N <<= 1;
- tmp <<= 2;
- tmp += (M >> 30);
- ttp = N;
- ttp = (ttp<<1)+1;
- M <<= 2;
- if( tmp >= ttp )
- tmp -= ttp;
- N ++;
- return N;
- void FFT()
- register unsigned char i,bb,j,k,p;
- register short TR,TI,temp;
- unsigned long ulReal,ulImage;
- unsigned char max;
- for(i=0;i<SAMPLE_NUM;i++)
- FftReal[BRTable[i]] = ADC_read();
- FftImage[i] = 0;
- for(i=1;i<=LOG;i++)
- bb=1;
- bb <<= (i-1);
- for(j=0;j<=bb-1;j++)
- p=1;
- p <<= (LOG-i);
- p = p*j;
- for(k=j;k<SAMPLE_NUM;k=k+2*bb)
- TR=FftReal[k];TI=FftImage[k];temp=FftReal[k+bb];
- FftReal[k]=FftReal[k]+((FftReal[k+bb]*cos_tabb[p])>>7)+((FftImage[k+bb]*sin_tabb[p])>>7);
- FftImage[k]=FftImage[k] - ((FftReal[k+bb]*sin_tabb[p])>>7)+((FftImage[k+bb]*cos_tabb[p])>>7);
- FftReal[k+bb]=TR-((FftReal[k+bb]*cos_tabb[p])>>7)-((FftImage[k+bb]*sin_tabb[p])>>7);
- FftImage[k+bb]=TI+((temp*sin_tabb[p])>>7)-((FftImage[k+bb]*cos_tabb[p])>>7);
- FftReal[k] >>= 1;
- FftImage[k] >>= 1;
- FftReal[k+bb] >>= 1;
- FftImage[k+bb] >>= 1;
- for(i=0;i<24;i++)
- ulReal = FftReal[i+1];
- ulReal *= ulReal;
- ulImage = FftImage[i+1];
- ulImage *= ulImage;
- result[i] = sqrt_16(ulReal+ulImage);
- /* for(i=0;i<17;i++)
- while(result[i] > FFT_OUT_MAX)
- for(i=0;i<17;i++)
- result[i] =result[i] -1;
- while(result[i] == FFT_OUT_MIN)
- for(i=0;i<24;i++)
- result[i] =result[i] +1;
- for(i=0;i<24;i++)
- if(result[i] > FFT_OUT_MAX)
- result[i] = FFT_OUT_MAX;
- if(result[i] > max)
- max = result[i];
- //局部增益 */ /*
- /*if(max >= 4)
- for(i=1;i<24;i++)
- if(result[i] >= 2)
- result[i]+=1; */
- void init()
- P2M0=0XFF;
- P2M1=0X00;
- P3M0=0XFF;
- P3M1=0X00;
- P1M0=0XFE;
- P1M1=0X01;
- P4SW=0x70;
- ADC_init();
- //AUXR |= 0x80; //定時器時鐘1T模式
- TMOD=0x01;
- TH0=(65535-TIME)/256;
- TL0=(65535-TIME)%256;
- EA=1;
- ET0=1;
- show_musicdisplay();
- TR0=1;
- void main()
- init();
- while(1)
- FFT();
- void timer0() interrupt 1
- unsigned char i;
- t++;
- if(t == 24)
- for(i=0;i<24;i++)
- temp[i] = result[i];
- t = 0;
- disp();
復制代碼
fft.h
- #ifndef _FFT_INCLUDED_
- #define _FFT_INCLUDED_
- struct compx
- float real;
- float imag;
- struct compx dd[65]; //FFT數(shù)據(jù)
- data struct compx temp;
- code float iw[64]=
- 1.000,0,0.9952,-0.0980,0.9808,-0.1951,0.9569,-0.2903,0.9239,-0.3827,0.8819,-0.4714,0.8315,-0.5556,
- 0.7730,-0.6344,0.7071,-0.7071,0.6344,-0.7730,0.5556,-0.8315,0.4714,-0.8819,0.3827,-0.9239,0.2903,-0.9569,
- 0.1951,-0.9808,0.0980,-0.9952,0.0,-1.0000,-0.0980,-0.9952,-0.1951,-0.9808,-0.2903,0.9569,-0.3827,-0.9239,
- -0.4714,-0.8819,-0.5556,-0.8315,-0.6344,-0.7730,-0.7071,-0.7071,-0.7730,-0.6344,-0.8315,-0.5556,-0.8819,-0.4714,
- -0.9239,-0.3827,-0.9569,-0.2903,-0.9808,-0.1951,-0.9952,-0.0980
- //復數(shù)乘法
- void ee(struct compx b1,uchar data b2)
- temp.real=b1.real*iw[2*b2]-b1.imag*iw[2*b2+1];
- temp.imag=b1.real*iw[2*b2+1]+b1.imag*iw[2*b2];
- //乘方函數(shù)
- uint mypow(uchar data nbottom,uchar data ntop)
- uint data result=1;
- uchar data t;
- for(t=0;t<ntop;t++)result*=nbottom;
- return result;
- //快速傅立葉變換
- void fft(struct compx *xin,uchar data N)
- uchar data fftnum,i,j,k,l,m,n,disbuff,dispos,dissec;
- data struct compx t;
- fftnum=N; //傅立葉變換點數(shù)
- for(m=1;(fftnum=fftnum/2)!=1;m++);//求得M的值
- for(k=0;k<=N-1;k++) //碼位倒置
- n=k;
- j=0;
- for(i=m;i>0;i--) //倒置
- j=j+((n%2)<<(i-1));
- n=n/2;
- if(k<j){t=xin[1+j];xin[1+j]=xin[1+k];xin[1+k]=t;}//交換數(shù)據(jù)
- for(l=1;l<=m;l++) //FFT運算
- disbuff=mypow(2,l); //求得碟間距離
- dispos=disbuff/2; //求得碟形兩點之間的距離
- for(j=1;j<=dispos;j++)
- for(i=j;i<N;i=i+disbuff) //遍歷M級所有的碟形
- dissec=i+dispos; //求得第二點的位置
- ee(xin[dissec],(uint)(j-1)*(uint)N/disbuff);//復數(shù)乘法
- t=temp;
- xin[dissec].real=xin[i].real-t.real;
- xin[dissec].imag=xin[i].imag-t.imag;
- xin[i].real=xin[i].real+t.real;
- xin[i].imag=xin[i].imag+t.imag;
- //完成顯示數(shù)據(jù)的轉(zhuǎn)換工作,包括頂點下落速度控制以及頂點更新定格
- //對fft數(shù)據(jù)進行處理,得到各個頻率段的電壓幅值
- void processfft(void)
- uchar data pt=0,tmp;
- for(pt=1;pt<65;pt++)
- dd[pt].imag=0; //清零虛部
- fft(dd,64); //對當前數(shù)據(jù)進行傅立葉變換
- dd[pt].real=sqrt(dd[pt].real*dd[pt].real+dd[pt].imag*dd[pt].imag);//取均方根
- if(Menu==1)
- for(pt=2;pt<34;pt+=2)
- for(tmp=(dd[pt].real/32)+1,LEDBuf[pt]=0xFF;tmp>=1;tmp--)//tmp>1;不保留最低位那一行常亮
- LEDBuf[pt]<<=1;
- LEDBuf[pt]=~(LEDBuf[pt]);
- else if(Menu==2)
- //下落感
- tmp=(dd[pt].real/32)+1;
- if(refreshflag[pt]<tmp) //刷新數(shù)據(jù),取較大高度值 存儲顯示
- for(LEDBuf[pt]=0xFF;tmp>1;tmp--) //tmp>1;不保留 最低位那一行常亮;{}一次也不執(zhí)行;
- LEDBuf[pt]<<=1;
- refreshflag[pt]=(dd[pt].real/32)+1;
- else
- if(refreshflag[pt]>1)refreshflag[pt]--; //頂端下落速度控制 改變值可以改變下降速度
- for(LEDBuf[pt]=0xFF,tmp=refreshflag[pt];tmp>1;tmp--) //tmp>1;不保留 最低位那一行常亮
- LEDBuf[pt]<<=1;
- else if(Menu==0)
- //下落感頻譜
- for(LEDBuf[pt]=0xFF;tmp>=1;tmp--)//tmp>1;不保留 最低位那一行常亮;{}一次也不執(zhí)行;
- LEDBuf[pt]<<=1;
- else
- for(LEDBuf[pt]=0xFF,tmp=refreshflag[pt];tmp>=1;tmp--)
- LEDBuf[pt]<<=1;
- #endif
復制代碼
