查看: 5222|回復(fù): 3
51單片機(jī)串口發(fā)送數(shù)據(jù)有問題,加了一個(gè)沒有調(diào)用的數(shù)組后串口通信就有問題了
ID:99434 發(fā)表于 2016-3-30 19:33 | 只看該作者 回帖獎勵(lì) |倒序?yàn)g覽 |閱讀模式
程序如下,如果加了ucha FP_Save_Finger[9]這個(gè)數(shù)組會出問題,但我根本沒有調(diào)用過那個(gè)數(shù)組,沒加這個(gè)數(shù)組時(shí)串口通信正常
#include <reg52.h>
sbit CS=P0^7; //串行寫入,液晶借接口
sbit SID=P0^6;
sbit SCLK=P0^5;
sbit  RST=P0^3;
sbit  PSB=P0^4;
uchar buffer[18];
//指紋識別通信協(xié)議
uchar code  FP_pack_head[6]={0xef,0x01,0xff,0xff,0xff,0xff};//協(xié)議包頭
unsigned char code FP_Get_Img[6] = {0x01,0x00,0x03,0x01,0x0,0x05};    //獲取指紋圖像
code unsigned char FPMXX_Get_Templete_Count[6] ={0x01,0x00,0x03,0x1D,0x00,0x21 }; //獲取模板總數(shù)
code unsigned char FP_Search[11]={0x01,0x0,0x08,0x04,0x01,0x0,0x0,0x03,0xA1,0x0,0xB2}; //搜索指紋范圍0-929
code unsigned char FP_Search_0_9[11]={0x01,0x0,0x08,0x04,0x01,0x0,0x0,0x0,0x13,0x0,0x21}; //搜索0-9號指紋
code unsigned char FP_Img_To_Buffer1[7]={0x01,0x0,0x04,0x02,0x01,0x0,0x08}; //將圖像放進(jìn)buffer1
code unsigned char FP_Img_To_Buffer2[7]={0x01,0x0,0x04,0x02,0x02,0x0,0x09}; //將圖像放進(jìn)buffer2
code unsigned char FP_Reg_Model[6]={0x01,0x0,0x03,0x05,0x0,0x09}; //將buffer1和buffer2合成特征模板
code unsigned char FP_Delet_All_Model[6]={0x01,0x0,0x03,0x0d,0x00,0x11};//刪除指紋模塊里的所有模板
uchar  FP_Save_Finger[9]={0x01,0x00,0x06,0x06,0x01,0x00,0x0b,0x00,0x19};
//延時(shí)程序
void delay_1ms(uint m)
        uchar t,j;
        for(t=0;t<m;t++)
                for(j=0;j<110;j++);
//////////////串口發(fā)送,接收
void UART_init_57600()
         SCON = 0x50; // 1010000   工作方式一,允許接收
         TMOD = 0x20; //8位自動重裝 ,T1工作方式2,
         TH1 = 250;        //自動重裝,波特率為57600
         TL1 = 250;
         PCON = 0x80; //波特率加倍
         RI = 0;        //中斷標(biāo)志位
         TI = 0;
         TR1 = 1; //啟動定時(shí)器1
         EA = 1; //全局中斷允許位
         ES = 1; //打開串口中斷
                 //T1定時(shí)器為串口通信的波特率設(shè)置位
void UART_Send_Byte(uchar d)//串口發(fā)送
        SBUF = d;
        while(!TI);
        TI = 0;
unsigned char UART_Receive_Byte()//串口接收
        uchar dat;
        while(!RI);
        RI = 0;
        dat = SBUF;
        return (dat);
void FP_cmd_head()//協(xié)議包頭
        uchar i;
        for(i=0;i<6;i++)
                UART_Send_Byte(FP_pack_head[i]);
void FPMXX_Cmd_Get_Img(void)//獲取指紋圖像
    uchar i;
    FP_cmd_head();
    for(i=0;i<6;i++)
      UART_Send_Byte(FP_Get_Img[i]);
                for(i=0;i<12;i++)
    buffer[i]=UART_Receive_Byte();
//將圖像轉(zhuǎn)換為特征碼存儲在特征文件緩沖區(qū)1
void FINGERPRINT_Cmd_Img_To_Buffer1(void)
            unsigned char i;
               FP_cmd_head();
                      for(i=0;i<7;i++)
                         UART_Send_Byte(FP_Img_To_Buffer1[i]);
                        for(i=0;i<12;i++)
//將圖像轉(zhuǎn)換為特征碼存儲在特征文件緩沖區(qū)2
void FINGERPRINT_Cmd_Img_To_Buffer2(void)
     unsigned char i;
     for(i=0;i<6;i++)
            for(i=0;i<7;i++)
                         UART_Send_Byte(FP_Img_To_Buffer2[i]);
                 for(i=0;i<12;i++)
//將Buffer1和buffer2合并成指紋模板
void FINGERPRINT_Cmd_Reg_Model(void)
    unsigned char i;
    for(i=0;i<6;i++)
    for(i=0;i<6;i++)
      UART_Send_Byte(FP_Reg_Model[i]);
                for(i=0;i<12;i++)
/////液晶函數(shù)
void send_command(uchar command_data) //把命令寫進(jìn)去函數(shù) 液晶
        uchar i;
        uchar i_data;
        i_data=0xf8;
        CS=1;
        SCLK=0;
        for(i=0;i<8;i++)
                        SID=(bit)(i_data&0x80);
                        SCLK=0;
                        SCLK=1;
                        i_data=i_data<<1;
        i_data=command_data;
        i_data&=0xf0;
        for(i=0;i<8;i++)
                        SCLK=0;
                        SCLK=1;
                        i_data=i_data<<1;
        i_data<<=4;
        for(i=0;i<8;i++)
                        SCLK=0;
                        SCLK=1;
                        i_data=i_data<<1;
        CS=0;
        delay_1ms(10);
void send_data(uchar command_data)  //把數(shù)據(jù)寫進(jìn)去函數(shù)  液晶
        uchar i;
        uchar i_data;
        i_data=0xfa;
        CS=1;
        for(i=0;i<8;i++)
                        SCLK=0;
                        SCLK=1;
                        i_data=i_data<<1;
        i_data&=0xf0;
        for(i=0;i<8;i++)
                        SCLK=0;
                        SCLK=1;
                        i_data=i_data<<1;
        i_data<<=4;
        for(i=0;i<8;i++)
                        SCLK=0;
                        SCLK=1;
                        i_data=i_data<<1;
        CS=0;
        delay_1ms(10);
void lcd_init()
        RST=1; //不復(fù)位,串行方式
        PSB=0;
        delay_1ms(100);
        send_command(0x30); /*設(shè)置8位數(shù)據(jù)接口,基本指令模式。*/
        send_command(0x02); /*清DDRAM*/
        send_command(0x06); /*游標(biāo)及顯示右移一位*/
        send_command(0x0c); /*整體顯示開,游標(biāo)關(guān),反白關(guān)*/
        send_command(0x01); /*寫入空格清屏幕*/
        send_command(0x80); /*設(shè)定首次顯示位置*/
        uchar i,shi,ge;
        delay_1ms(200);
        UART_init_57600();//波特率初始化
        lcd_init();//液晶顯示初始化
        do
        FPMXX_Cmd_Get_Img();
        }while(buffer[9]!=0x0);//等待接收指紋模塊反饋的數(shù)據(jù)是否正確
        send_command(0x80);//把接收到的數(shù)據(jù)顯示在液晶上
        for(i=0;i<12;i++)
                shi=buffer[i]/0x10;
                ge=buffer[i]%0x10;
                if(shi>9)
                        send_data(shi+0x37);
                        send_data(shi+0x30);
                if(ge>9)
                        send_data(ge+0x37);
                        send_data(ge+0x30);
        while(1);
相關(guān)帖子
ID:111494 發(fā)表于 2016-3-30 21:12 | 只看該作者
是否編譯時(shí)候出錯(cuò)了,變量太多,超標(biāo)了
ID:99434 發(fā)表于 2016-3-30 22:04 | 只看該作者
編譯沒錯(cuò),而且如果把多加的那個(gè)數(shù)組改成code的話就可以了,但是由于新加的數(shù)組需要改變所以不能加code,現(xiàn)在束手無策
ID:97438 發(fā)表于 2016-3-31 00:07 | 只看該作者
因?yàn)槟愕某绦虺隽藘?nèi)存吧,換塊性能好一點(diǎn)的芯片就行了
