查看: 2891|回復(fù): 0
基于51單片機(jī)開發(fā)板的秒表程序
ID:111893 發(fā)表于 2016-4-2 11:41 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
typedef unsigned char uint8;
typedef unsigned int  uint16;
typedef unsigned long uint32;
code uint8 number[]={        0x3f,0x06,0x5b,0x4f,
                                                           0x66,0x6d,0x7d,0x07,
                                                       0x7f,0x6f,0x77,0x7c,
                                                           0x39,0x5e,0x79,0x71};
uint8 a[8];
uint16 counter = 0;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
void timer1_init()
        TMOD|=0x10;
        TMOD&=0xDF;
        TH1  =0xFC;
        TL1  =0x67;
        TR1  =1;
void int_init()
        ET1 = 1;
        EA  = 1;
void refresh_led()
        static uint8 j=7;
        switch(j)
                case 7:LSA=0;LSB=0;LSC=0;j--;P0=number[a[0]];break;
                case 6:LSA=1;LSB=0;LSC=0;j--;P0=number[a[1]];break;
                case 5:LSA=0;LSB=1;LSC=0;j--;P0=number[a[2]];break;
                case 4:LSA=0;LSB=0;LSC=1;j--;P0=number[a[3]];break;
                case 3:LSA=1;LSB=0;LSC=1;j--;P0=number[a[4]];break;
                case 2:LSA=0;LSB=1;LSC=1;j--;P0=number[a[5]];break;
                case 1:LSA=1;LSB=1;LSC=0;j--;P0=number[a[6]];break;
                case 0:LSA=1;LSB=1;LSC=1;j=7;P0=number[a[7]];break;
                default :break;
        timer1_init();
        int_init();
        while(1);
void interrupt_timer1() interrupt 3
        static uint32 m;
        TH1 = 0xFC;
        TL1 = 0x67;
        P0 = 0x00;
        counter++;
        if(counter == 1000)
                m++;
                counter = 0;
                a[0]=m%10;
                a[1]=m/10%10;
                a[2]=m/100%10;
                a[3]=m/1000%10;
                a[4]=m/10000%10;
                a[5]=m/100000%10;
                a[6]=m/1000000%10;
                a[7]=m/10000000%10;
        refresh_led();
相關(guān)帖子
