查看: 1739|回復(fù): 1
52單片機(jī)控制多及程序(親測)
ID:114920 發(fā)表于 2016-4-18 13:53 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include "STC12c5A.h"
#define Left 0   //o궨òå×ó×a
#define Right 1   //o궨òåóò×a
sbit ControlPort = P2^0;  //¶æ»úDÅoŶ˿ú
unsigned char TimeOutCounter = 0,LeftOrRight = 0;
//TimeOutCounter:¶¨ê±Æ÷òç3ö¼Æêy
//  LeftOrRight: ×ó×aóò×a±êÖ¾
void InitialTimer ( void )
        TMOD=0x10;   //¶¨ê±¼ÆêyÆ÷11¤×÷óú·½ê½1
        TH1 = ( 65535 - 500*12 ) / 256;   //0.25ms
        TL1 = ( 65535 - 500*12 ) % 256;
        EA=1;        //¿a×üÖD¶Ï
        ET1=1;       //ÔêDí¶¨ê±¼ÆêyÆ÷1ÖD¶Ï
        TR1=1;       //Æô¶ˉ¶¨ê±¼ÆêyÆ÷1ÖD¶Ï
void delay_ms(unsigned int _countMS)
    unsigned int i;
unsigned char j;
for(i=_countMS*12;i>0;i--)
     for(j=120;j>0;j--);
void ControlLeftOrRight ( void )   //¿ØÖƶæ»úoˉêy
                        LeftOrRight = Left;
                        delay_ms(2000);
                        LeftOrRight = Right;
                        delay_ms(2000);
void main ( void )  //Ö÷oˉêy
                InitialTimer();
                for(;;)
                                ControlLeftOrRight();
void Timer1 ( void ) interrupt 3  //¶¨ê±Æ÷ÖD¶Ïoˉêy
                        TimeOutCounter ++;
                        switch ( LeftOrRight )
                                case 0 :     //Îa0ê±£¬¶æ»ú×ó×a£¬1ms
                                                if( TimeOutCounter <= 2 )
        ControlPort = 1;
        ControlPort = 0;
        break;
                                        case 1 :   //Îa1ê±£¬¶æ»úóò×a2ms
                                                        if( TimeOutCounter <= 10 )
        ControlPort = 1;
        ControlPort = 0;
        break;
                                                default : break;
                                        if( TimeOutCounter == 80 )  //20ms,2»òaDT¸Ä
                                                        TimeOutCounter = 0;
相關(guān)帖子
ID:1 發(fā)表于 2016-4-18 14:38 | 只看該作者
控制什么的?
