查看: 6391|回復: 2
這是一個51單片機倒計時程序
ID:123409 發(fā)表于 2016-5-26 20:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
大家參考參考,可以提提寶貴建議
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint  unsigned int
  5. uint countb=0,counta=0;                // counta 為10ms計數器,countb為1s計數器,均為全局變量
  6. sbit s1 = P2^0;
  7. sbit s2 = P2^1;
  8. sbit s3 = P2^2;
  9. sbit s4 = P2^3;
  10. sbit en = P2^5;
  11. sbit speaker = P2^4;
  12. sbit k1=P3^2;
  13. sbit k2=P3^3;
  14.
  15. uchar a1,a2,b1,b2;
  16. code ledseg7[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};           //0~9不帶小數點的段碼表
  17.             //   0    1    2    3    4    5    6    7    8    9
  18. code ledseg8[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
  19.             //   0    1    2    3    4    5    6    7    8    9            //0~9帶小數點的段碼表
  20. /********延時函數********/
  21. void Delay(uint xms)              //延時程序,xms是形式參數
  22. {
  23.         uint i,j;
  24.         for(i=xms;i>0;i--)
  25.         for(j=100;j>0;j--);                //此處分號不可少
  26. }
  27. /*******顯示函數********/
  28. void display(uchar a,uchar b,uchar c,uchar d)
  29. {
  30.         en = 1;           //啟用數碼管信號
  31.         s1 = 0;
  32.         P0 = ledseg7[a];
  33.         Delay(5);
  34.         s1 = 1;
  35.         s2 = 0;
  36.         P0 = ledseg8[b];
  37.         Delay(5);
  38.         s2 = 1;
  39.         s3 = 0;
  40.         P0 = ledseg7[c];
  41.         Delay(5);
  42.         s3 = 1;
  43.         s4 = 0;
  44.         P0 = ledseg7[d];
  45.         Delay(5);
  46.         s4 = 1;
  47. }
  48. /********重置,暫停設置******/
  49. void key()
  50. {
  51.         if(k1==0)         //開始,暫停
  52.     {
  53.         Delay(10);
  54.                    if(k1==0)
  55.         {
  56.                      while(!k1);
  57.                          TR0=~TR0;
  58.         }
  59.     }
  60.         if(k2==0)          //復位
  61.         {
  62.            Delay(10);
  63.            if(k2==0)
  64.            {
  65.             TH0=0xDC; TL0=0x00;
  66.         countb=0;
  67.                 counta=0;
  68.         TR0=0;
  69.         while(k2!=0);
  70.     }
  71.     }
  72.
  73. }
  74. /********定時器T0中斷函數*******/
  75. void timer0() interrupt  1
  76. {
  77.         TH0=0xDC;TL0=0x00;
  78.         counta++;                            //計數值加1
  79.           if(counta==100)                //若counta為99,(100*10ms=1s)
  80.           {
  81.                   counta=0;                        // counta清0
  82.                 countb++;
  83.           }
  84.         if(countb==30)
  85.         {
  86.                 TR0=0;
  87.                 s3=1;
  88.                 counta=0,countb=0;
  89.                 speaker=0;
  90.                 Delay(500);
  91.                 speaker=1;
  92.                 Delay(500);
  93.                 speaker=0;
  94.                 Delay(500);
  95.                 speaker=1;
  96.         }
  97. }
  98. void main()
  99. {
  100.         P0=0xff;
  101.            TMOD=0x01;                         //定時器T0方式1
  102.            TH0=0xDC; TL0=0x00;              //10ms定時初值
  103.         TR0=0;
  104.            EA=1;
  105.            ET0=1;         //開總中斷,開定時器T0中斷,啟動定時器T0
  106.            while(1)
  107.            {
  108.             key();
  109.                 b2=countb/10;      //取出記數秒數的十位
  110.                    b1=countb%10;      //取出計數秒的個位
  111.                 a2=counta/10;      //取出記數百分秒數的十位
  112.                    a1=counta%10;             //取出計數百分秒的個位
  113.                    display(b2,b1,a2,a1);  //調顯示函數
  114.            }
  115. }
復制代碼
clock.docx
13.44 KB, 下載次數: 14, 下載積分: 黑幣 -5
程序代碼
參與人數 1黑幣 +50 收起 理由
admin + 50 共享資料的黑幣獎勵!
ID:214205 發(fā)表于 2017-6-24 12:01 | 只看該作者
很給力
ID:213173 發(fā)表于 2017-6-24 16:43 | 只看該作者
顯示函數執(zhí)行一次超過20ms,有可能閃爍,也無法正常反映十分秒和百分秒動態(tài),按鍵程序里使用了Delay(10);延時和while(!k1);等待按鍵釋放,會明顯劣化顯示質量。
Powered by 單片機教程網
