查看: 3132|回復(fù): 2
交通燈系統(tǒng) 加強(qiáng)版紅綠燈 程序+仿真
ID:123203 發(fā)表于 2016-5-31 19:08 | 顯示全部樓層 |閱讀模式
  1. #define _MAIN_C
  2. #include "use.h"
  3. #include "main.h"
  4. #include "time.h"
  5. #include "key.h"
  6. bit flag1s;
  7. uchar count1s,NS_time,WE_time;
  8. uchar GreenTime=30,RedTime=35;
  9. uchar index=0;
  10. enum eStaSysterm StaSysterm=NormalRun;
  11. void main()
  12. {
  13.         EA=1;        //開總中斷
  14.         InintTimer0();                                                  //初始化定時(shí)器0
  15.         while(1)
  16.         {
  17.                 LEDScan();                                                  //數(shù)碼管即LED掃描
  18.                 KeyDriver();                                          //鍵盤驅(qū)動(dòng)掃描
  19.                 if(flag1s)
  20.                 {
  21.                         flag1s=0;
  22.                         NS_time--;                                          //紅綠燈倒計(jì)時(shí)時(shí)間減
  23.                         WE_time--;
  24.                 }
  25.         }
  26. }
  27. void InintTimer0()
  28. {
  29.         TMOD=0X01;
  30.         TH0=0X4C;
  31.         TL0=0X00;
  32.         ET0=1;
  33.         TR0=1;
  34. }
  35. void Timer0() interrupt 1
  36. {
  37.         TH0=0XBB;
  38.         TL0=0X00;
  39.         KeyScan();
  40.         if(++count1s<50)        return;
  41.         count1s=0;
  42.         if(StaSysterm==NormalRun) flag1s=1;         //非正常運(yùn)行時(shí),不紅綠燈數(shù)值不減一
  43. }
  44. void LEDScan()
  45. {
  46.          if(StaSysterm==NormalRun)                         //正常運(yùn)行
  47.          {
  48.                 if(NS_time==0 || WE_time==0)
  49.                 {
  50.                         switch(index)                                 //改變紅綠燈的狀態(tài),狀態(tài)機(jī)
  51.                         {
  52.                                 case 0:
  53.                                 {
  54.                                         index=1;
  55.                                         NS_time=GreenTime;
  56.                                         WE_time=RedTime;
  57.                                         P2=0X09;
  58.                                 }break;
  59.                                 case 1:
  60.                                 {
  61.                                         index=2;
  62.                                         NS_time=RedTime-GreenTime;
  63.                                         P2=0X0A;
  64.                                 }break;
  65.                                 case 2:
  66.                                 {
  67.                                         index=3;
  68.                                         NS_time=RedTime;
  69.                                         WE_time=GreenTime;
  70.                                         P2=0X24;
  71.                                 }break;
  72.                                 case 3:
  73.                                 {
  74.                                         index=0;
  75.                                         WE_time=RedTime-GreenTime;
  76.                                         P2=0X14;
  77.                                 }break;
  78.                                 default:break;
  79.                         }
  80.                 }
  81.                 Seg_Display(NS_time/10,0);
  82.                 Seg_Display(NS_time%10,1);
  83.                 Seg_Display(WE_time/10,2);
  84.                 Seg_Display(WE_time%10,3);
  85.         }
  86.         else if(StaSysterm==UrgentRun)
  87.         {        //緊急情況運(yùn)行
  88.                 P2=0x12;
  89.                 Delayms(200);
  90.                 P2=0x00;
  91.                 Delayms(200);
  92.         }
  93.         else                                                           //設(shè)置調(diào)整紅綠燈時(shí)間
  94.         {
  95.                 index=0;
  96.                 NS_time=0;
  97.                 WE_time=0;         //重新初始化紅綠燈并運(yùn)行
  98.                 UrgentScan();
  99.         }
  100. }
444444.rar (70.03 KB, 下載次數(shù): 43)
ID:124699 發(fā)表于 2016-12-11 14:16 | 顯示全部樓層
學(xué)習(xí)了!!這個(gè)資料很有用
ID:241724 發(fā)表于 2017-10-22 06:45 | 顯示全部樓層
感謝分享!調(diào)試中
