#include <serial.c> //包含串行處理模塊
bit showclocksign;
bit showblocksign;
bit showfensign;
uchar count;
uint second;
uchar paoplace;
uint zongfen;
uchar speed=32;
idata uint free[16]; //定義行首處理空間
unsigned char idata *freep; //定義指向該數(shù)組的指針
gotoxy(uchar x,y)
{putbyte(0x1b);putbyte('['
putbyte((y%100)/10+0x30);
putbyte((y%10)+0x30);
putbyte(';');
putbyte((x%100)/10+0x30);
putbyte((x%10)+0x30);
putbyte('H');
clrscr()
{gotoxy(0,0); putbyte(0x1b); putstring("[J"); }
showpao()
{gotoxy(1,16); putbyte(0x1b); putstring("[K");
gotoxy(paoplace,16); putbyte('|');
gotoxy(1,17); putbyte(0x1b); putstring("[K");
gotoxy(paoplace-1,17);
putbyte('/');putbyte('H');putbyte('\\');
gotoxy(0,24);
uint bdata showp;
sbit outblock=showp^15;
showblock() //showblock
{uchar i,j;uint bdata p;
uint st;
gotoxy(0,0);
for(i=15;i!=0;i--)
{putbyte('|');
showp=free[i];
st=0x8000;
for(j=0;j!=16;j++)
{ if ((showp&st)!=0) putbyte('@');
else putbyte(' ');
st>>=1;
//showp=showp>>1;
putbyte('|');CR;
gotoxy(0,24);
showblocksign=0;
showfen()
{gotoxy(6,19);
//putstring("得分: ");
putint(zongfen,1);
showfensign=0;
//putbyte(' ');
//puthex(free[15]/256); puthex(free[15]%256);
//gotoxy(0,24);
void main(void)
{uchar idata c,i,j;bit k;
uint temp,notype;
serial_init(); // ET0=0;
putstring("\r\nSerial ready!\r\n");
start: ET0=1;clrscr();
putstring("飛機(jī)游戲"
"\r\n
"\r\n游戲控制方法:"
"\r\n 操作者不動(dòng)鍵盤10秒鐘進(jìn)入演示狀態(tài),按'a'或'4'飛機(jī)"
"\r\n 左移,按'd'或'6'右移,按's'或'0'發(fā)彈,按'-'降低難度,"
"\r\n 按'+'提高難度,按'p'立即進(jìn)入演示狀態(tài)。"
"\r\n 按任何鍵開始游戲。");
while(!inbufsign);
zongfen=0;showblock();showfen();notype=1000;
gotoxy(0,19); //putstring("lever: h-hard e-easy\r\n5-left 6-right 0-shot");
putstring("得分:\r\n級(jí)別: +:高 -:低\r\n5:左移 6:右移 0:發(fā)射");
gotoxy(7,20);putchar(speed,1);
for(i=0;i!=16;i++)
{free[i]=0;
paoplace=9;showpao();
while(1) {
if (showblocksign) showblock();
if (showfensign) showfen();
if (free[0]!=0)
{ET0=0;notype=1000;free[0]=0;gotoxy(0,22);putstring("結(jié)束!再玩一遍?(y/n)");
while(getbyte()!='y');goto start;
notype--;if(notype==10){notype=1000;goto autoplay;}
delay(100);
if (notype>900) {gotoxy(0,22);putbyte(0x1b); putstring("[K");}
if (inbufsign)
{ c=getbyte();notype=1000;
switch (c)
{case '5': //left move
case 'a':
paoplace--; if (paoplace==1) paoplace=2;
showpao();
break;
case '6': //right move
case 'd':
paoplace++; if (paoplace==18) paoplace=17;
showpao();
break;
case '=':
case '+':
speed--;
if (speed==0)speed=1;
gotoxy(7,20);
putchar(speed,1);
break;
case '_':
case '-':
speed++;
if (speed==255)speed=254;
gotoxy(7,20);
putchar(speed,1);
break;
case 's':
case '0': //shot
for(i=15,j=1;i!=0;i--,j=16-i)
{gotoxy(paoplace,i); putbyte('o');delay(50);
putbyte(8);putbyte(' ');
//free[i]=0xffff;
temp=0x0001<<(17-paoplace);
if((free[j]&temp)!=0)
{free[j]&= (temp^0xffff);zongfen+=10;showfensign=1;break;}
break;
case 'y': goto start;
case 'p':
autoplay: gotoxy(0,22);putbyte(0x1b); putstring("[K");putstring("游戲自動(dòng)演示中。");
ET0=1;speed=20;gotoxy(7,20);putchar(speed,1);
do
{free[j] &= (temp^0xffff);zongfen+=10;showfensign=1;goto again;}
again:
if (!(((free[5]&temp)!=0)||((free[4]&temp)!=0)))
{if (k) {paoplace--;}
else {paoplace++;}
if (paoplace==1){ paoplace=2; k=0;}
if (paoplace==18) {paoplace=17;k=1;}
if (free[0]!=0) //if dead?
//while(getbyte()!='y');goto start;
break;
showpao();
}while(!inbufsign);
//freep=free;
//putbytes(freep,1);
//getline(freep,1);
uint code *getcode;
void timer0(void) interrupt 1
uchar i;
TH0=31;TL0=00;
//1/32S
count++;
if (count==speed) //11059200
{count=0; //1s
for(i=0;i<16;i++)
{free[i]=free[i+1];
free[15]=*getcode;
getcode++;if (getcode==1000) getcode=0;
showblocksign=1;
showclocksign=1;
second++; //1S
if (second==3600) {second=0;showclocksign=1;}
// if (iftimeover) timeovercount++;
//else timeovercount=0;
//serial.c 代碼
//串口中斷服務(wù)程序,僅需做簡(jiǎn)單調(diào)用即可完成串口輸入輸出的處理
//出入均設(shè)有緩沖區(qū),大小可任意設(shè)置。
//可供使用的函數(shù)名:
//char getbyte(void);從接收緩沖區(qū)取一個(gè)byte,如不想等待則在調(diào)用前檢測(cè)inbufsign是否為1。
//putbyte(char c);放入一個(gè)字節(jié)到發(fā)送緩沖區(qū)
//putbytes(unsigned char *outplace,j);放一串?dāng)?shù)據(jù)到發(fā)送緩沖區(qū),自定義長(zhǎng)度
//putstring(unsigned char code *puts);發(fā)送一個(gè)定義在程序存儲(chǔ)區(qū)的字符串到串口
//puthex(unsigned char c);發(fā)送一個(gè)字節(jié)的hex碼,分成兩個(gè)字節(jié)發(fā)。
//putchar(uchar c,uchar j);發(fā)送一個(gè)字節(jié)數(shù)據(jù)的asc碼表達(dá)方式,需要定義小數(shù)點(diǎn)的位置
//putint(uint ui,uchar j);發(fā)送一個(gè)整型數(shù)據(jù)的asc碼表達(dá)方式,需要定義小數(shù)點(diǎn)的位置
//delay(unsigned char d); 延時(shí)n x 100ns
//getline(char idata *line, unsigned char n); 獲取一行數(shù)據(jù)回車結(jié)束,必須定義最大輸入字符數(shù)
//CR;發(fā)送一個(gè)回車換行
#include <w77e58.h>
#define OLEN 10 //size of serial transmission buffer
idata unsigned char outbuf[OLEN]; // storage for transmission buffer
unsigned char idata *outlast=outbuf; //最后由中斷傳輸出去的字節(jié)位置
unsigned char idata *putlast=outbuf; //最后放入發(fā)送緩沖區(qū)的字節(jié)位置
#define ILEN 2 //size of serial receiving buffer
idata unsigned char inbuf[ILEN];
unsigned char idata *inlast=inbuf; //最后由中斷進(jìn)入接收緩沖區(qū)的字節(jié)位置
unsigned char idata *getlast=inbuf; //最后取走的字節(jié)位置
bit outbufsign; //輸出緩沖區(qū)非空標(biāo)志有=1
bit inbufsign; //接收緩沖區(qū)非空標(biāo)志 有=1
bit inbufful; //輸入緩沖區(qū)滿標(biāo)志 滿=1
#define CR putstring("\r\n") //CR=回車換行
unsigned char code comready[]="com is ready!";
//延時(shí)n x 100ns
void delay(unsigned char d) //在源程序開頭定義是否用w77e58或22。1184M晶振
{unsigned char j;
do{ d--;
//110592 & 89c52
#ifndef cpuw77e58
#ifndef xtal221184
j=21; //k=38 cpu80320 100us k=21 cpu 8052
#else
j=42;
#endif
#else
#ifndef xtal221184
j=38;
#else
j=76;
#endif
#endif
do {j--;} while(j!=0);
}while(d!=0);
//放入一個(gè)字節(jié)到發(fā)送緩沖區(qū)
putbyte(char c)
{uchar i,j;
ES=0; //暫停串行中斷,以免數(shù)據(jù)比較時(shí)出錯(cuò)?
if (outlast==putlast )
{ i=(0-TH1);
do{i--;j=36; do {j--;}while(j!=0); }while(i!=0); //延時(shí)一個(gè)字節(jié)發(fā)送時(shí)間
*putlast=c; //放字節(jié)進(jìn)入緩沖區(qū)
putlast++; //發(fā)送緩沖區(qū)指針加一
if (putlast==outbuf+OLEN) putlast=outbuf; //指針到了頂部換到底部
if (!outbufsign) {outbufsign=1;TI=1; } //緩沖區(qū)開始為空置為有,啟動(dòng)發(fā)送
ES=1;
//放一串?dāng)?shù)據(jù)到發(fā)送緩沖區(qū)
putbytes(unsigned char *outplace,unsigned char j)
int i;
for(i=0;i<j;i++)
{putbyte(*outplace);
outplace++;
uchar idata free[4];uchar data i;
i=0;
free[i++]=(c/100+0x30);
if (j==3) free[i++]='.';
free[i++]=(c%100)/10+0x30;
if (j==2) free[i++]='.';
if (j==2 && free[i-3]==0x30) free[i-3]=0x20;
free[i++]=(c%10)+0x30;
if (j==1 && free[i-3]==0x30) free[i-3]=0x20;
if (j==1 && free[i-3]==0x20 && free[i-2]==0x30) free[i-2]=0x20;
putbytes(free,i);
{uchar idata free[6];
uchar data i;
i=0;
free[i++]=(ui/10000+0x30);
if (j==5) free[i++]='.';
free[i++]=((ui%10000)/1000+0x30);
if (j==4) free[i++]='.';
if (j==4 && free[i-3]==0x30) free[i-3]=0x20;
free[i++]=((ui%1000)/100+0x30);
if (j==3 && free[i-4]==0x30) free[i-4]=0x20;
if (j==3 && free[i-4]==0x20 && free[i-3]==0x30) free[i-3]=0x20;
free[i++]=((ui%100)/10+0x30);
if (j==2 && free[i-5]==0x30) free[i-5]=0x20;
if (j==2 && free[i-5]==0x20 && free[i-4]==0x30) free[i-4]=0x20;
if (j==2 && free[i-5]==0x20 && free[i-4]==0x20 && free[i-3]==0x30) free[i-3]=0x20;
free[i++]=(ui%10+0x30);
if (j==1 && free[i-5]==0x30) free[i-5]=0x20;
if (j==1 && free[i-5]==0x20 && free[i-4]==0x30) free[i-4]=0x20;
if (j==1 && free[i-5]==0x20 && free[i-4]==0x20 && free[i-3]==0x30) free[i-3]=0x20;
if (j==1 && free[i-5]==0x20 && free[i-4]==0x20 && free[i-3]==0x20 && free[i-2]==0x30) free[i-2]=0x20;
putbytes(free,i);
//發(fā)送一個(gè)定義在程序存儲(chǔ)區(qū)的字符串到串口
putstring(unsigned char *puts)
{for (;*puts!=0;puts++) //遇到停止符0結(jié)束
putbyte(*puts);
//發(fā)送一個(gè)字節(jié)的hex碼,分成兩個(gè)字節(jié)發(fā)。
unsigned char code hex_[]={"0123456789ABCDEF"};
{int ch;
ch=(c>>4)&0x0f;
putbyte(hex_[ch]);
ch=c&0x0f;
putbyte(hex_[ch]);
//從接收緩沖區(qū)取一個(gè)byte,如不想等待則在調(diào)用前檢測(cè)inbufsign是否為1。
uchar getbyte (void)
{ char idata c ;
while (!inbufsign); //緩沖區(qū)空等待
ES=0;
c= *getlast; //取數(shù)據(jù)
getlast++; //最后取走的數(shù)據(jù)位置加一
inbufful=0; //輸入緩沖區(qū)的滿標(biāo)志清零
if (getlast==inbuf+ILEN) getlast=inbuf; //地址到頂部回到底部
if (getlast==inlast) inbufsign=0; //地址相等置接收緩沖區(qū)空空標(biāo)志,再取數(shù)前要檢該標(biāo)志
ES=1;
return (c); //取回?cái)?shù)據(jù)
//接收一行數(shù)據(jù),必須定義放數(shù)據(jù)串的指針位置和大小
del=0x7f,backspace=0x08,cr=0x0d,lf=0x0a
void getline (uchar idata *line, unsigned char n)
{ unsigned char cnt = 0; //定義已接收的長(zhǎng)度
char c;
do {
if ((c = getbyte ()) == 0x0d) c = 0x00; //讀一個(gè)字節(jié),如果是回車換成結(jié)束符
if (c == 0x08 || c == 0x7f) //BACKSPACE 和 DEL 的處理
{ if (cnt != 0) //已經(jīng)輸入退掉一個(gè)字符
{cnt--; //總數(shù)目減一
line--; //指針減一
putbyte (0x08); //屏幕回顯的處理
putbyte (' ');
putbyte (0x08);
putbyte (*line = c); //其他字符取入,回顯
line++; //指針加一
cnt++; //總數(shù)目加一
while (cnt < n - 1 && c != 0x00 && c!=0x1b); //數(shù)目到了,回車或ESC停止
*line = 0; //再加上停止符0
putinbuf(uchar c)
{ES=0; if(!inbufful)
{*inlast= c; //放入數(shù)據(jù)
inlast++; //最后放入的位置加一
if (inlast==inbuf+ILEN) inlast=inbuf; //地址到頂部回到底部
if (inlast==getlast) inbufful=1; //接收緩沖區(qū)滿置滿標(biāo)志
inbufsign=1;
ES=1;
//串口中斷處理
serial () interrupt 4
if (TI )
{ TI = 0;
if (outbufsign)
//if (putlast==outlast) outbufsign=0;
//else
SBUF=*outlast; //未發(fā)送完繼續(xù)發(fā)送
outlast++; //最后傳出去的字節(jié)位置加一
if (outlast==outbuf+OLEN) outlast=outbuf; //地址到頂部回到底部
if (putlast==outlast) outbufsign=0; //數(shù)據(jù)發(fā)送完置發(fā)送緩沖區(qū)空標(biāo)志
if (RI)
RI = 0;
if(!inbufful)
*inlast= SBUF; //放入數(shù)據(jù)
inbufsign=1;
//串口初始化
0xfd=19200,0xfa=9600,0xf4=4800,0xe8=2400,0xd0=1200
serial_init ()
SCON = 0x50; // mode 1: 8-bit UART, enable receiver
TMOD |= 0x20; //timer 1 mode 2: 8-Bit reload
PCON |= 0x80; TH1 = 0xfd;//fa, //baud*2 reload value 19200 baud
TR1 = 1; //timer 1 run
ES = 1; REN=1; EA=1; SM2=1; //SM2=1時(shí)收到的第9位為1才置位RI標(biāo)志
TMOD |=0x01; //th1 auto load 2X8,th0 1X16
TH0=31; TL0=0; //X 32 =1S
TR0=1; ET0=1;
//測(cè)試用主函數(shù)
void main(void)
char c;
idata unsigned char free[16];
unsigned char idata *freep=free;
serial_init();
putstring(crlf);
putstring(comready);
putstring("jdioptuejls;j;klja");
delay(10);
c=getbyte();
putbyte(0x20);
puthex(c);
switch(c)
{case 'r':
putbytes(inbuf,ILEN);
break;
case 'g':
getline(freep,10);
putbyte(0x20);
putstring(freep);
break;
default:
putbyte(c);
W77E58.H代碼
#ifndef true
#define true 1
#define false 0
#endif
#ifndef byte
#define byte unsigned char
#define word unsigned int
#define dword unsigned long
#endif
#define clr_bit(bit_name) bit_name=0
#define set_bit(bit_name) bit_name=1
typedef union
word w;
byte bh;
byte bl;
} WordType;
typedef union
dword dw;
byte b[4];
word w[2];
} DwordType;
//--BYTE Registers-------------------------------------------------
sfr P0 = 0x80;
sfr P1 = 0x90;
sfr P2 = 0xA0;
sfr P3 = 0xB0;
#define p0 P0
#define p1 P1
#define p2 P2
#define p3 P3
sfr PSW = 0xD0;
sfr ACC = 0xE0;
sfr B = 0xF0;
sfr SP = 0x81;
sfr DPL = 0x82;
sfr DPH = 0x83;
sfr PCON = 0x87;//PCON.7(SMOD)撥特率加倍,PCON.1(PD)掉電方式,PCON.0(IDL)凍結(jié)方式
//PCON.6(SMOD0)幀錯(cuò)檢測(cè)允許,PCON.3(GF1)PCON.2(GF0)
sfr TCON = 0x88;//定時(shí)控制寄存器
sfr TMOD = 0x89;//"gate,c/t,m1,m0"x2定時(shí)器方式GATE=1時(shí)只有intx=1時(shí)才可以開放定時(shí)器x;
//c/t =1時(shí)計(jì)書數(shù)方式,=0時(shí)定時(shí)方式。m1m0=00時(shí)13位計(jì)數(shù),=01時(shí)16位=10時(shí)自裝入8位,
//11時(shí)定時(shí)器0分兩個(gè),定時(shí)器1停止。
sfr TL0 = 0x8A;
sfr TL1 = 0x8B;
sfr TH0 = 0x8C;
sfr TH1 = 0x8D;
sfr IE = 0xA8;
sfr IP = 0xB8; //中斷優(yōu)先級(jí)
sfr SCON = 0x98; //串口控制與狀態(tài)
sfr SBUF = 0x99;
//--W77E58 Extensions---------------------------------------------
sfr T2CON = 0xC8;
sfr T2MOD = 0xc9;//HC5,HC4,HC3,HC2,T2CR,-,T2OE,DCEN
//hc5-hc2 =1時(shí)外中斷5-2標(biāo)志硬件自動(dòng)清除。
//t2cr=1 捕獲完成時(shí)自動(dòng)復(fù)位
//t2oe=1 定時(shí)器2輸出允許
//dcen=1 減計(jì)數(shù)允許,結(jié)合外部輸入t2ex使用,16位自裝入模式
sfr RCAP2L= 0xCA;//重裝的預(yù)置數(shù),捕獲的輸出
sfr RCAP2H= 0xCB;
sfr TL2 = 0xCC;
sfr TH2 = 0xCD;
sfr DPL1 = 0x84;
sfr DPH1 = 0x85;
sfr DPS = 0x86;
sfr CKCON = 0x8e;//wd1,wd0,t2m,t1m,t0m,md2,md1,md0
//wd1wd0:看門狗計(jì)數(shù)00=2^17,01=2^20,10=2^23,11=2^26
//t2m,t1m,t0m等于1時(shí)時(shí)鐘4分頻
//md2,md1,md0 MOVX執(zhí)行機(jī)器周期000=2,001=3。。。111=9
sfr EXIF = 0x91;//ie5,ie4,ie3,ie2,XT/RG,RGMD,RGSL,-
//ie5,ie3=1外中斷下跳變中斷標(biāo)志
//ie4,ie3=2外中斷上跳變中斷標(biāo)志
sfr P4 = 0xa5;//低四位有效
sfr SADDR = 0xa9;//從機(jī)串口0地址
sfr SADDR1= 0xaa;//從機(jī)串口1地址
sfr SADEN = 0xb9;//串口0地址屏蔽,等于0時(shí)所有地址都會(huì)引起中斷
sfr SADEN1= 0xba;//串口0地址屏蔽,等于0時(shí)所有地址都會(huì)引起中斷
sfr SCON1 = 0xc0;
sfr SBUF1 = 0xc1;
sfr ROMMAP= 0xc2;//ROMMAP.7為等待信號(hào)使能,用movx指令時(shí),wait腳為p4.0
sfr PMR = 0xc4;//CD1,CD0,SWB,-,XTOFF,ALE-OFF,-DME0
//cd0cd1=0時(shí)鐘不變,=1-1/4,=2-1/64,=3=1/1024
//swb=1強(qiáng)制4分頻,外中斷或串口中斷喚醒
//aleoff =1時(shí)ale信號(hào)終止,外部?jī)?nèi)存訪問時(shí)自動(dòng)喚醒
//dme0 =1時(shí)內(nèi)部1kram使能
sfr STATUS= 0xc5;//-,HIP,LIP,XTUP,SPTA1,SPRA1,SPTA0,SPRA0
//hip=1正在處理高優(yōu)先級(jí)中斷
//lip=1正在處理低優(yōu)先級(jí)中斷
//spta1串口0正在發(fā)送數(shù)據(jù)
//spra1串口0正在接收數(shù)據(jù)
//spta0串口0正在發(fā)送數(shù)據(jù)
//spra0串口0正在接收數(shù)據(jù)
sfr TA = 0xc7;//保護(hù)位
sfr WDCON = 0xd8;//SMOD_1,POR,-,-,WDIF,WTRF,EWT,RWT
//smod1 加倍串口1的撥特率,pro電源復(fù)位標(biāo)志
//por 電源復(fù)位標(biāo)志
//wdif看門狗定時(shí)中斷標(biāo)志,軟清
//wtrf看門狗定時(shí)器復(fù)位標(biāo)志,看門狗引起復(fù)位后,該位置1
//ewt 允許看門狗定時(shí)器自動(dòng)復(fù)位
//rwt復(fù)位看門狗定時(shí)器,如果看門狗溢出還沒有被復(fù)位計(jì)數(shù)器,將會(huì)引
//起中斷,再過(guò)512周期將復(fù)位
sfr EIE = 0xe8;//-,-,-,EWDI,EX5,EX4,EX3,EX2
//ewdi=1,允許看門狗中斷?
//ex5-ex2;外部中斷允許
sfr EIP = 0xf8;//-,-,-,pwdi,px5,px4,px3,px2
//pwdi=1 看門狗中斷優(yōu)先
//px5-px2=1 外部中斷優(yōu)先
//--BIT Registers-------------------------------------------------
//PSW
sbit CY = 0xD7;
sbit AC = 0xD6;
sbit F0 = 0xD5;
sbit RS1 = 0xD4;
sbit RS0 = 0xD3;
sbit OV = 0xD2;
sbit P = 0xD0;
//TCON
sbit TF1 = 0x8F; //定時(shí)器1溢出標(biāo)志,自動(dòng)清零
sbit TR1 = 0x8E; //timer1運(yùn)行控制位
sbit TF0 = 0x8D; //定時(shí)器0溢出標(biāo)志,自動(dòng)清零
sbit TR0 = 0x8C; //timer0運(yùn)行控制位
sbit IE1 = 0x8B; //外中斷1跳變中斷請(qǐng)求標(biāo)志,自動(dòng)清零
sbit IT1 = 0x8A; //中斷1跳變檢測(cè)使能
sbit IE0 = 0x89; //外中斷0跳變中斷請(qǐng)求標(biāo)志,自動(dòng)清零
sbit IT0 = 0x88; //中斷0跳變檢測(cè)使能
//IE
sbit EA = 0xAF;
sbit ES = 0xAC;
sbit ET1 = 0xAB;
sbit EX1 = 0xAA;
sbit ET0 = 0xA9;
sbit EX0 = 0xA8;
//IP
sbit PS = 0xBC; //串口0中斷優(yōu)先設(shè)定
sbit PT1 = 0xBB; //定時(shí)器1中斷優(yōu)先
sbit PX1 = 0xBA; //外中斷1
sbit PT0 = 0xB9; //定時(shí)器0中斷優(yōu)先
sbit PX0 = 0xB8; //外中斷0
//P3
sbit RD = 0xB7;
sbit WR = 0xB6;
sbit T1 = 0xB5;
sbit T0 = 0xB4;
sbit INT1 = 0xB3;
sbit INT0 = 0xB2;
sbit TXD = 0xB1;
sbit RXD = 0xB0;
//SCON
sbit SM0 = 0x9F; //SM0/FE 串口0方式0選擇或幀錯(cuò)標(biāo)志,人工清零
sbit SM1 = 0x9E; //串口1工作方式選擇0-4/12tclk同步,1-10位可設(shè)bps異步,2-64/32tclk
//異步,3-11位可變bps異步
sbit SM2 = 0x9D; //允許方式2和3的多機(jī)通訊控制位。方式2、3中=1時(shí)接收到的
//第9位為0時(shí)不啟動(dòng)接收中斷ri標(biāo)志
//方式1中,=1時(shí)只有收到有效停止時(shí)才啟動(dòng)ri,方式0中=1將撥
//特率提高3倍。
sbit REN = 0x9C; //允許接收標(biāo)志
sbit TB8 = 0x9B; //方式23中要發(fā)送的第9位。
sbit RB8 = 0x9A; //方式23中接收到的第9位。
sbit TI = 0x99; //發(fā)送中斷標(biāo)志
sbit RI = 0x98; //接收中斷標(biāo)志
// PSW
sbit F1 = 0xd1;
//IE
sbit ET2 = 0xAD; //定時(shí)器2允許
sbit ES1 = 0xae; //串口1優(yōu)先
//IP
sbit PT2 = 0xBD; //定時(shí)器2優(yōu)先
sbit PS1 = 0xbe; //串口1優(yōu)先
//P1
sbit T2 = 0x90; //計(jì)數(shù)器2輸入端口
sbit T2EX = 0x91; //計(jì)數(shù)器捕獲觸發(fā)
sbit RXD1 = 0x92; //串口1入
sbit TXD1 = 0x93; //串口2出
sbit INT2 = 0x94; //外中斷2,上跳變觸發(fā)
sbit INT3 = 0x95; //外中斷3,下跳變觸發(fā)
sbit INT4 = 0x96; //外中斷4,上跳變觸發(fā)
sbit INT5 = 0x97; //外中斷5,下跳變觸發(fā)
//T2CON
sbit TF2 = 0xCF; //定時(shí)器2溢出標(biāo)志,軟清除
sbit EXF2 = 0xCE; //定時(shí)器2外部標(biāo)志,當(dāng)exen2=1且t2ex引腳負(fù)跳變引起捕獲或重載
//時(shí)置位,軟清。
sbit RCLK = 0xCD; //接收時(shí)鐘標(biāo)志,=1時(shí)串口0用定時(shí)器2溢出做時(shí)鐘。
sbit TCLK = 0xCC; //發(fā)送時(shí)鐘標(biāo)志,=1時(shí)串口0用定時(shí)器2溢出做時(shí)鐘。
sbit EXEN2 = 0xCB; //定時(shí)器2外部允許標(biāo)志,=1時(shí)若未用作撥特率發(fā)生器,t2ex腳的負(fù)
跳變引起捕獲
sbit TR2 = 0xCA; //定時(shí)器2運(yùn)行控制位
sbit C_T2 = 0xC9; //計(jì)數(shù)/定時(shí)選擇,=1時(shí)計(jì)數(shù)
sbit CP_RL= 0xC8; //捕獲/重載標(biāo)志,=1時(shí),外部允許時(shí),vt2ex負(fù)跳變發(fā)生捕獲
//=0時(shí) 溢出或外部允許時(shí),vt2ex負(fù)跳變發(fā)生重載
//SCON1
//注釋參考SCON
sbit SM0_1 = 0xC7;
sbit SM1_1 = 0xC6;
sbit SM2_1 = 0xC5;
sbit REN_1 = 0xC4;
sbit TB8_1 = 0xC3;
sbit RB8_1 = 0xC2;
sbit TI_1 = 0xC1;
sbit RI_1 = 0xC0;
//WDCON
sbit SMOD_1= 0xDF; //加倍串口1的撥特率,pro電源復(fù)位標(biāo)志
sbit POR = 0xDE; //電源復(fù)位標(biāo)志
sbit WDIF = 0XDB; //看門狗定時(shí)中斷標(biāo)志,軟清
sbit WTRF = 0xDA; //看門狗定時(shí)器復(fù)位標(biāo)志,看門狗引起復(fù)位后,該位置1
sbit EWT = 0xD9; //允許看門狗定時(shí)器自動(dòng)復(fù)位
sbit RWT = 0xD8; //復(fù)位看門狗定時(shí)器,如果看門狗溢出還沒有被復(fù)位計(jì)
//數(shù)器,將會(huì)引起中斷,再過(guò)512周期將復(fù)位
//EIE
sbit EWDI = 0xec; //允許看門狗中斷
sbit EX5 = 0xeb; //ex5-ex2;外部中斷允許
sbit EX4 = 0xea;
sbit EX3 = 0xe9;
sbit EX2 = 0xe8;
//EIP
sbit PWDI = 0xfc; //pwdi=1 看門狗中斷優(yōu)先
sbit PX5 = 0xfb; //px5-px2=1 外部中斷優(yōu)先
sbit PX4 = 0xfa;
sbit PX3 = 0xf9;
sbit PX2 = 0xf8;
