查看: 25428|回復(fù): 22
51單片機簡易電子琴仿真+源程序+電路原理圖
ID:137190 發(fā)表于 2016-8-31 18:16 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
51單片機簡易電子琴仿真電路原理圖
下面是51單片機簡易電子琴源程序:
  1. #include<AT89X52.h>
  2. #define KeyPort P1
  3. unsigned char High,Low; //定時器預(yù)裝值的高8位和低8位
  4. sbit SPK=P3^7;          //定義蜂鳴器接口
  5. sbit playSongKey=P0^0;          //功能鍵
  6. sbit RS=P2^0;//液晶數(shù)據(jù)命令選擇
  7. sbit RW=P2^1;//液晶讀寫選擇
  8. sbit EN=P2^2;//液晶使能端
  9. unsigned char code freq[][2]={
  10.   0xD8,0xF7,//00440HZ 1
  11.   0xBD,0xF8,//00494HZ 2
  12.   0x87,0xF9,//00554HZ 3
  13.   0xE4,0xF9,//00587HZ 4
  14.   0x90,0xFA,//00659HZ 5
  15.   0x29,0xFB,//00740HZ 6
  16.   0xB1,0xFB,//00831HZ 7
  17.   0xEF,0xFB,//00880HZ `1
  18. };
  19. unsigned char Time;
  20. unsigned char code YINFU[9][1]={{' '},{'1'},{'2'},{'3'},{'4'},{'5'},{'6'},{'7'},{'8'}};
  21.                           //世上只有媽媽好數(shù)據(jù)表
  22. unsigned char code MUSIC[]={ 6,2,3,      5,2,1,      3,2,2,    5,2,2,    1,3,2,    6,2,1,    5,2,1,
  23.                      6,2,4,      3,2,2,      5,2,1,    6,2,1,           5,2,2,         3,2,2,           1,2,1,
  24.                      6,1,1,      5,2,1,      3,2,1,         2,2,4,           2,2,3,         3,2,1,    5,2,2,
  25.                      5,2,1,      6,2,1,      3,2,2,         2,2,2,    1,2,4,         5,2,3,           3,2,1,
  26.                      2,2,1,      1,2,1,      6,1,1,         1,2,1,           5,1,6,         0,0,0
  27.                                       };
  28.                          // 音階頻率表 高八位
  29. unsigned char code FREQH[]={
  30.                          0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8,
  31.                          0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC, //1,2,3,4,5,6,7,8,i
  32.                          0xFC,0xFD,0xFD,0xFD,0xFD,0xFE,
  33.                          0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,
  34.                                } ;
  35.                          // 音階頻率表 低八位
  36. unsigned char code FREQL[]={
  37.                          0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
  38.                          0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F, //1,2,3,4,5,6,7,8,i
  39.                          0xEE,0x44, 0x6B,0xB4,0xF4,0x2D,
  40.                          0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16,
  41.                                 };
  42. void Init_Timer0(void);//定時器初始化
  43. //延時函數(shù)大約約2*z+5us
  44. void delay2xus(unsigned char z)
  45. {
  46.    while(z--);
  47. }
  48. // 延時函數(shù)大約約1ms
  49. void delayms(unsigned char x)
  50. {
  51.    while(x--)
  52.    {
  53.      delay2xus(245);
  54.      delay2xus(245);
  55.    }
  56. }
  57. /*------------------------------------------------
  58.                 節(jié)拍延時函數(shù)
  59. 各調(diào)1/4節(jié)拍時間:
  60. 調(diào)4/4  125ms
  61. 調(diào)2/4  250ms
  62. 調(diào)3/4  187ms
  63. ------------------------------------------------*/
  64. void delayTips(unsigned char t)
  65. {
  66.     unsigned char i;
  67.           for(i=0;i<t;i++)
  68.     {
  69.             delayms(250);
  70.     }
  71.     TR0=0;
  72. }
  73. //播放音樂的函數(shù)
  74. void PlaySong()
  75. {
  76.    TH0=High;//賦值定時器時間,決定頻率
  77.    TL0=Low;
  78.    TR0=1;      //打開定時器
  79.    delayTips(Time); //延時所需要的節(jié)拍
  80. }
  81. //定時器T0初始化子程序
  82. void Init_Timer0(void)
  83. {
  84. TMOD |= 0x01;          //使用模式1,16位定時器,使用"|"符號可以在使用多個定時器時不受影響
  85. EA=1;            //總中斷打開
  86. ET0=1;           //定時器中斷打開
  87. }
  88. //定時器T0中斷子程序
  89. void Timer0_isr(void) interrupt 1
  90. {
  91. TH0=High;
  92. TL0=Low;
  93. SPK=!SPK;
  94. }
  95. //主函數(shù)
  96. void main (void)
  97. {
  98.   unsigned char num,k,i;
  99.   Init_Timer0();    //初始化定時器0,主要用于數(shù)碼管動態(tài)掃描
  100.   SPK=0;                        //在未按鍵時,喇叭低電平,防止長期高電平損壞喇叭
  101.   while (1)
  102.   {
  103.    switch(KeyPort)          //對按鍵進(jìn)行處理
  104.                 {
  105.                  case 0xfe:num= 1;break;
  106.                  case 0xfd:num= 2;break;
  107.                  case 0xfb:num= 3;break;
  108.                  case 0xf7:num= 4;break;
  109.                  case 0xef:num= 5;break;
  110.                  case 0xdf:num= 6;break;
  111.                  case 0xbf:num= 7;break;
  112.                  case 0x7f:num= 8;break;      //分別對應(yīng)不用的音調(diào)
  113.                  default:num= 0;break;
  114.                 }
  115.     P2 = KeyPort;
  116.     if(num==0)
  117.     {
  118.        TR0=0;
  119.        SPK=0;   //在未按鍵時,喇叭低電平,防止長期高電平損壞喇叭
  120.           }
  121.     else
  122.     {
  123.             High=freq[num-1][1];
  124.                    Low =freq[num-1][0];
  125.                   TR0=1;
  126.           }
  127.    if(playSongKey==0)        //如果播放音樂按鍵被按下
  128.    {
  129.      delayms(10);
  130.      if(playSongKey==0)
  131.      {
  132.        i=0;
  133.        while(i<100)
  134.             {
  135.             k=MUSIC[i]+7*MUSIC[i+1]-1;//去音符振蕩頻率所需數(shù)據(jù)
  136.             High=FREQH[k];
  137.             Low=FREQL[k];
  138.             Time=MUSIC[i+2];          //節(jié)拍時長
  139.             i=i+3;
  140.                         if(P1!=0xff)//長按任意8音鍵退出播放
  141.                         {
  142.                delayms(10);
  143.                if(P1!=0xff)
  144.                                  i=101;
  145.                         }
  146.             PlaySong();
  147.             }
  148.                    TR0=0;
  149.      }
  150.    }
  151.   }
  152. }
51單片機簡易電子琴所有資料下載:http://www.torrancerestoration.com/bbs/dpj-54940-1.html
參與人數(shù) 7黑幣 +24 收起 理由
lulululu + 1 很給力!
waitera + 2 贊一個!
a1321594070 + 5 很給力!
101.1 + 1 很給力!
單片機@ + 5 很給力!
朋友們晚上好 + 5 很給力!
LWJSSG + 5 贊一個!
收藏收藏4 分享淘帖 頂1 踩
ID:89286 發(fā)表于 2017-7-4 07:02 | 只看該作者
thanks for sharing
ID:262319 發(fā)表于 2017-12-16 20:18 | 只看該作者
我仿真的時候怎么沒反應(yīng)啊
ID:262319 發(fā)表于 2017-12-16 20:20 | 只看該作者
這是什么意思
ID:277447 發(fā)表于 2018-1-18 19:13 | 只看該作者
把程序?qū)敕抡鏇]反應(yīng),怎么辦
ID:336941 發(fā)表于 2018-5-23 22:51 | 只看該作者
把程序?qū)?1,但是沒有反應(yīng)是什么情況呢
ID:356714 發(fā)表于 2018-6-22 17:09 | 只看該作者
為什么我仿真時按鍵不起作用
ID:357821 發(fā)表于 2018-6-26 10:59 | 只看該作者
厲害了
ID:359038 發(fā)表于 2018-6-26 11:26 | 只看該作者
不錯耶!
ID:362370 發(fā)表于 2018-6-30 17:51 | 只看該作者
還不錯!
ID:372095 發(fā)表于 2018-7-15 19:28 | 只看該作者
老哥,程序運行之后按鍵沒反應(yīng)怎么回事???
ID:392265 發(fā)表于 2018-9-1 11:38 | 只看該作者
大神大神
ID:402000 發(fā)表于 2018-9-25 09:47 | 只看該作者
nice thank you
ID:416511 發(fā)表于 2018-10-27 23:24 | 只看該作者
你好,這里面的能滿足以下的要求嗎?
基于單片機的電子琴設(shè)計
基本要求:利用單片機AT89C51設(shè)計電子琴,用矩陣鍵盤代表鍵琴,至少能彈出8個音符。
創(chuàng)新:鍵按下時間長短表征節(jié)拍的長短;點陣實時動態(tài)顯示音符的高低等。
任務(wù)區(qū)分:A——按照矩陣鍵盤上數(shù)字順序音節(jié)逐漸升高。
ID:416511 發(fā)表于 2018-10-29 22:58 | 只看該作者
你好 下載之后不會文件損壞或者仿真運行不了這種情況吧
ID:417858 發(fā)表于 2018-10-30 12:22 | 只看該作者
新手學(xué)習(xí)下!
ID:425357 發(fā)表于 2018-11-13 11:14 | 只看該作者
感謝分享 支持
ID:453126 發(fā)表于 2018-12-29 10:33 | 只看該作者
急需一個電子琴程序><
ID:497927 發(fā)表于 2019-3-25 15:18 | 只看該作者
想問一下里面液晶的那一塊定義有什么用
ID:501886 發(fā)表于 2019-4-1 20:55 | 只看該作者
雪中送炭
ID:560101 發(fā)表于 2019-6-11 16:44 | 只看該作者
做的可以繼續(xù)加油
ID:744791 發(fā)表于 2020-5-6 16:41 | 只看該作者
很給力!
ID:752151 發(fā)表于 2020-5-14 22:16 | 只看該作者
請問如何來改變歌曲
