查看: 23350|回復: 40
單片機+LM2596數(shù)控穩(wěn)壓電源源程序
ID:140343 發(fā)表于 2016-10-11 20:16 | 顯示全部樓層 |閱讀模式
主要器件:
使用LCD1602顯示
電源可調(diào)模塊用到LM2596
模數(shù)轉(zhuǎn)換ADC0832
主要功能:
理論電壓范圍 1.25V~40V
電壓、電流顯示
短路保護電路
資料下載:
LM2596 數(shù)控電源.rar (2.1 KB, 下載次數(shù): 771)
源程序:
  1. #include"reg52.h"
  2. #include<stdio.h>
  3. #include <intrins.h>
  4. typedef  unsigned char uchar;
  5. typedef  unsigned int uint;
  6. #define LCD_Data P0
  7. #define Busy    0x80 //用于檢測LCD狀態(tài)字中的Busy標識
  8. sbit ADC0832_CLK = P1^5;
  9. sbit ADC0832_DODI = P1^6;
  10. sbit ADC0832_CS = P1^7;
  11. sbit LCD_RS=P2^7;//定義引腳
  12. sbit LCD_RW=P2^6;
  13. sbit LCD_E=P2^5;
  14. float volts,amps;
  15. //5ms延時
  16. void Delay5Ms(void)
  17. {
  18.     unsigned int TempCyc = 5552;
  19.     while(TempCyc--);
  20. }
  21. //400ms延時
  22. void Delay400Ms(void)
  23. {
  24.     unsigned char TempCycA = 5;
  25.     unsigned int TempCycB;
  26.     while(TempCycA--)
  27.     {
  28.         TempCycB=7269;
  29.         while(TempCycB--);
  30.     };
  31. }
  32. //讀狀態(tài)
  33. unsigned char ReadStatusLCD(void)
  34. {
  35.     LCD_Data = 0xFF;
  36.     LCD_RS = 0;
  37.     LCD_RW = 1;
  38.     LCD_E = 0;
  39.     LCD_E = 0;
  40.     LCD_E = 1;
  41.     while (LCD_Data & Busy); //檢測忙信號
  42.     return(LCD_Data);
  43. }
  44. //寫數(shù)據(jù)
  45. void WriteDataLCD(unsigned char WDLCD)
  46. {
  47.     ReadStatusLCD(); //檢測忙
  48.     LCD_Data = WDLCD;
  49.     LCD_RS = 1;
  50.     LCD_RW = 0;
  51.     LCD_E = 0; //若晶振速度太高可以在這后加小的延時
  52.     LCD_E = 0; //延時
  53.     LCD_E = 1;
  54. }
  55. //寫指令
  56. void WriteCommandLCD(unsigned char WCLCD,BuysC) //BuysC為0時忽略忙檢測
  57. {
  58.     if (BuysC) ReadStatusLCD(); //根據(jù)需要檢測忙
  59.     LCD_Data = WCLCD;
  60.     LCD_RS = 0;
  61.     LCD_RW = 0;
  62.     LCD_E = 0;
  63.     LCD_E = 0;
  64.     LCD_E = 1;
  65. }
  66. //讀數(shù)據(jù)
  67. unsigned char ReadDataLCD(void)
  68. {
  69.     LCD_RS = 1;
  70.     LCD_RW = 1;
  71.     LCD_E = 0;
  72.     LCD_E = 0;
  73.     LCD_E = 1;
  74.     return(LCD_Data);
  75. }
  76. void LCDInit(void) //LCM初始化
  77. {
  78.     LCD_Data = 0;
  79.     WriteCommandLCD(0x38,0); //三次顯示模式設(shè)置,不檢測忙信號
  80.     Delay5Ms();
  81.     WriteCommandLCD(0x38,0);
  82.     Delay5Ms();
  83.     WriteCommandLCD(0x38,0);
  84.     Delay5Ms();
  85.
  86.     WriteCommandLCD(0x38,1); //顯示模式設(shè)置,開始要求每次檢測忙信號
  87.     WriteCommandLCD(0x08,1); //關(guān)閉顯示
  88.     WriteCommandLCD(0x01,1); //顯示清屏
  89.     WriteCommandLCD(0x06,1); // 顯示光標移動設(shè)置
  90.     WriteCommandLCD(0x0C,1); // 顯示開及光標設(shè)置
  91. }
  92. //按指定位置顯示一個字符
  93. void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
  94. {
  95.     Y &= 0x1;
  96.     X &= 0xF; //限制X不能大于15,Y不能大于1
  97.     if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
  98.     X |= 0x80; // 算出指令碼
  99.     WriteCommandLCD(X, 0); //這里不檢測忙信號,發(fā)送地址碼
  100.     WriteDataLCD(DData);
  101. }
  102. //按指定位置顯示一串字符
  103. void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
  104. {
  105.     unsigned char ListLength;
  106.
  107.     ListLength = 0;
  108.     Y &= 0x1;
  109.     X &= 0xF; //限制X不能大于15,Y不能大于1
  110.     while (DData[ListLength]>=0x20) //若到達字串尾則退出
  111.     {
  112.         if (X <= 0xF) //X坐標應小于0xF
  113.      {
  114.             DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
  115.             ListLength++;
  116.          X++;
  117.      }
  118.     }
  119. }
  120. //讀取ADC0832轉(zhuǎn)換值函數(shù)
  121. //入口函數(shù):channel選擇通道
  122. uchar ADC0832_Read(uchar channel)
  123. {
  124.     uchar i = 0;
  125.     uchar tmp = 0;  //高字節(jié)數(shù)據(jù)
  126.     uchar tmp1 = 0; //低字節(jié)數(shù)據(jù)
  127.
  128.     //開始標志位
  129.     ADC0832_DODI = 1;
  130.     _nop_();  _nop_();
  131.     ADC0832_CS = 0;     //片選信號
  132.     ADC0832_CLK = 1;
  133.     _nop_();  _nop_();
  134.     ADC0832_CLK = 0;
  135.     _nop_();  _nop_();
  136.     //選擇通道
  137.     switch(channel)
  138.     {
  139.         case 0:     //通道0
  140.             ADC0832_DODI = 1;   //SGL = 1;
  141.             _nop_();  _nop_();
  142.             ADC0832_CLK = 1;
  143.             _nop_();  _nop_();
  144.             ADC0832_CLK = 0;
  145.             _nop_();  _nop_();
  146.             ADC0832_DODI = 0;   //ODD = 0;
  147.             _nop_();  _nop_();
  148.             ADC0832_CLK = 1;
  149.             _nop_();  _nop_();
  150.             ADC0832_CLK = 0;
  151.             _nop_();  _nop_();
  152.             break;
  153.         case 1:     //通道1
  154.             ADC0832_DODI = 1;   //SGL = 1;
  155.             _nop_();  _nop_();
  156.             ADC0832_CLK = 1;
  157.             _nop_();  _nop_();
  158.             ADC0832_CLK = 0;
  159.             _nop_();  _nop_();
  160.             ADC0832_DODI = 1;   //ODD = 1;
  161.             _nop_();  _nop_();
  162.             ADC0832_CLK = 1;
  163.             _nop_();  _nop_();
  164.             ADC0832_CLK = 0;
  165.             _nop_();  _nop_();
  166.             break;
  167.
  168.         default:
  169.             break;
  170.     }
  171.     ADC0832_DODI = 1;
  172.     _nop_();  _nop_();
  173.     //讀取8位轉(zhuǎn)換數(shù)值
  174.     for(i=0;i<8;i++)
  175.     {
  176.         ADC0832_CLK = 1;
  177.         _nop_();  _nop_();
  178.         ADC0832_CLK = 0;
  179.         _nop_();  _nop_();
  180.         if(ADC0832_DODI)
  181.         {
  182.             tmp |= 0x01;
  183.         }
  184.         else
  185.         {
  186.             tmp &= 0xfe;
  187.         }
  188.         if(i<7)
  189.         {
  190.             tmp <<= 1;
  191.         }
  192.     }
  193.     tmp1 =  tmp & 0x01;
  194.     tmp1 <<= 6;
  195.     for(i=0;i<7;i++)
  196.     {
  197.         ADC0832_CLK = 1;
  198.         _nop_();  _nop_();
  199.         ADC0832_CLK = 0;
  200.         _nop_();  _nop_();
  201.         if(ADC0832_DODI)
  202.         {
  203.             tmp1 |= 0x80;
  204.         }
  205.         else
  206.         {
  207.             tmp1 &= 0x7f;
  208.         }
  209.         if(i<6)
  210.         {
  211.             tmp1 >>= 1;
  212.         }
  213.     }
  214.     ADC0832_CS = 1;
  215.     if(tmp == tmp1) //當高字節(jié)與低字節(jié)相同時,該值有效
  216.     {
  217.         return tmp; //返回數(shù)值
  218.     }
  219. }
  220. void DisPlayValue(uint volts,uint amps)
  221. {
  222.     DisplayOneChar(0,0,'U');
  223.     DisplayOneChar(1,0,'=');
  224.     if(volts/10000 == 0)
  225.     {
  226.         DisplayOneChar(2,0,'0' + (volts/1000%10));
  227.         DisplayOneChar(3,0,'.');
  228.         DisplayOneChar(4,0,'0' + (volts/100%10));
  229.         DisplayOneChar(5,0,'0' + (volts/10%10));
  230.         DisplayOneChar(6,0,'0' + (volts%10));
  231.         DisplayOneChar(7,0,' ');
  232.         DisplayOneChar(8,0,'V');
  233.         DisplayOneChar(9,0,' ');
  234.     }
  235.     else
  236.     {
  237.         DisplayOneChar(2,0,'0' + (volts/10000));
  238.         DisplayOneChar(3,0,'0' + (volts/1000%10));
  239.         DisplayOneChar(4,0,'.');
  240.         DisplayOneChar(5,0,'0' + (volts/100%10));
  241.         DisplayOneChar(6,0,'0' + (volts/10%10));
  242.         DisplayOneChar(7,0,'0' + (volts%10));
  243.         DisplayOneChar(8,0,' ');
  244.         DisplayOneChar(9,0,'V');
  245.     }
  246.
  247.     DisplayOneChar(0,1,'I');
  248.     DisplayOneChar(1,1,'=');
  249.     DisplayOneChar(2,1,'0' + (amps/1000));
  250.     DisplayOneChar(3,1,'.');
  251.     DisplayOneChar(4,1,'0' + (amps/100%10));
  252.     DisplayOneChar(5,1,'0' + (amps/10%10));
  253.     DisplayOneChar(6,1,'0' + (amps/1%10));
  254.     DisplayOneChar(7,1,' ');
  255.     DisplayOneChar(8,1,'A');
  256. }
  257. void GetValue(void)
  258. {
  259.     uchar tmp,i;
  260.     uint ntmp;
  261.     for(i=0;i<10;i++)
  262.     {
  263.         tmp = ADC0832_Read(0);
  264.         ntmp += tmp;
  265.     }
  266.     volts = (ntmp/10)*0.1137*1000;
  267.     Delay5Ms();
  268.     ntmp = 0;
  269.     for(i=0;i<20;i++)
  270.     {
  271.         tmp = ADC0832_Read(1);
  272.         ntmp += tmp;
  273.     }
  274.     amps = (ntmp/20)*0.0196*1000;
  275.     Delay5Ms();
  276.     DisPlayValue(volts,amps);
  277. }
  278. void main(void)
  279. {
  280.     Delay400Ms(); //啟動等待,等LCD講入工作狀態(tài)
  281.     LCDInit(); //LCM初始化
  282.     Delay5Ms(); //延時片刻(可不要)
  283.     ReadDataLCD();//測試用句無意義
  284.     while(1)
  285.     {
  286.         GetValue();
  287.     }
  288. }
復制代碼
參與人數(shù) 2黑幣 +10 收起 理由
vvv64 + 5 回帖助人的獎勵!
隨易而安 + 5 共享資料的黑幣獎勵!
ID:142450 發(fā)表于 2016-10-12 16:31 | 顯示全部樓層
沒原理圖?
ID:94489 發(fā)表于 2016-10-12 21:34 | 顯示全部樓層
沒原理圖?
ID:143386 發(fā)表于 2016-10-19 11:59 | 顯示全部樓層
不錯 學習學習
ID:135781 發(fā)表于 2016-11-3 18:48 | 顯示全部樓層
為什么我的幣總是不夠的?
ID:156204 發(fā)表于 2016-12-20 13:33 | 顯示全部樓層
ID:151661 發(fā)表于 2016-12-20 16:17 | 顯示全部樓層
51黑有你更精彩
ID:155317 發(fā)表于 2016-12-21 16:04 | 顯示全部樓層
正需要啊。學習中
ID:156689 發(fā)表于 2016-12-21 22:26 | 顯示全部樓層
挺好噠~~~
ID:135369 發(fā)表于 2016-12-22 07:58 來自觸屏版 | 顯示全部樓層
前一段時間購買了XL4016,做大功率數(shù)控電源,原理同上,
ID:162913 發(fā)表于 2017-1-25 09:27 | 顯示全部樓層
一直在尋找這個,終于找到了 ,下載學習中...........
ID:158622 發(fā)表于 2017-4-5 22:04 | 顯示全部樓層
怎么不能生成HEX
ID:165180 發(fā)表于 2017-4-6 13:22 | 顯示全部樓層
沒原理圖,沒什么意思。!
ID:199061 發(fā)表于 2017-5-10 20:55 | 顯示全部樓層
理論電流輸出是多少?還有U2的那兩個集成運放是干什么的?
ID:227981 發(fā)表于 2017-8-16 22:29 | 顯示全部樓層
厲害,學習學習!
ID:246491 發(fā)表于 2017-11-18 11:30 | 顯示全部樓層
一直在尋找此類作品,正好學習一下知識
ID:232205 發(fā)表于 2017-12-9 17:52 | 顯示全部樓層
厲害,學習學習!
ID:140964 發(fā)表于 2018-3-9 09:56 | 顯示全部樓層
謝謝分享,急需
這樣的例程
ID:341246 發(fā)表于 2018-6-11 07:58 | 顯示全部樓層
謝謝分享,收藏了
ID:76087 發(fā)表于 2018-6-26 23:11 | 顯示全部樓層
只有電壓采集 ,沒有調(diào)整輸出的功能啊
ID:7503 發(fā)表于 2018-6-27 08:12 | 顯示全部樓層
正需要,謝謝樓主分享
ID:245004 發(fā)表于 2018-7-5 22:35 | 顯示全部樓層
電壓顯示,沒有單片機調(diào)壓,想做一個調(diào)壓的
ID:245004 發(fā)表于 2018-7-5 22:48 | 顯示全部樓層
5swords 發(fā)表于 2016-12-20 13:33
原理圖在此http://www.torrancerestoration.com/bbs/dpj-56592-1.html
不配套,可互補;
這個是顯示,那個是調(diào)壓。
ID:155299 發(fā)表于 2018-7-9 22:33 | 顯示全部樓層
挺好的,學習下
ID:222880 發(fā)表于 2018-9-4 17:40 | 顯示全部樓層
正需要,學習下
ID:222880 發(fā)表于 2018-9-4 17:42 | 顯示全部樓層
正需要,謝謝樓主分享
ID:70432 發(fā)表于 2018-10-8 14:11 | 顯示全部樓層
參考一下,謝謝樓主
ID:418213 發(fā)表于 2018-11-4 23:24 | 顯示全部樓層
謝謝分享。
ID:430715 發(fā)表于 2018-11-21 18:16 | 顯示全部樓層
感謝,非常感謝,號
ID:487024 發(fā)表于 2019-3-8 17:31 | 顯示全部樓層
學習一下。
ID:420564 發(fā)表于 2019-6-3 16:05 | 顯示全部樓層
學習了,謝謝樓主分享
ID:76087 發(fā)表于 2019-6-12 02:30 | 顯示全部樓層
恩,這個代碼,是純ADC采樣顯示,沒有數(shù)控的功能.
ID:380985 發(fā)表于 2019-7-16 23:10 來自觸屏版 | 顯示全部樓層
坑了唄,就一個點c文件
ID:520939 發(fā)表于 2019-11-18 22:25 | 顯示全部樓層
坑了唄,就一個點c文件
ID:629626 發(fā)表于 2019-11-24 20:57 | 顯示全部樓層
有圖嗎?
ID:546589 發(fā)表于 2019-11-24 22:41 | 顯示全部樓層
受益匪淺
ID:661942 發(fā)表于 2019-12-11 21:24 | 顯示全部樓層
非常感謝提供 這個!
ID:128989 發(fā)表于 2021-5-1 09:25 | 顯示全部樓層
不錯的數(shù)控電源
ID:163501 發(fā)表于 2021-6-13 13:01 來自觸屏版 | 顯示全部樓層
xiaoer 發(fā)表于 2016-12-22 07:58
可以分享一下嗎?謝謝你
ID:688460 發(fā)表于 2023-3-26 16:10 | 顯示全部樓層
樓主這里有個LM2596數(shù)控電源的程序希望能幫到你:http://www.torrancerestoration.com/bbs/dpj-56600-1.html
