查看: 2495|回復: 1
1602液晶屏的VHDL源程序
ID:144230 發(fā)表于 2016-10-24 15:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
Entity LCD1602 is
Port(clk,CR:in std_logic;
     RW,EN,RS:out std_logic;
       Qdata:out std_logic_vector(7 downto 0));
end;
Architecture LCD of LCD1602 is
signal Qfp:integer range 0 to 4999999;
signal cp:std_logic;
begin
  process(clk,CR)
     begin
          if CR='0' then
                Qfp<=0;
                    cp<='0';
               elsif clk'event and clk='1' then
                     Qfp<=Qfp+1;
                         if Qfp=0 then
                            cp<=not cp;
                         end if;
               end if;
     end process;
     RW<='0';
     EN<=cp;
     process(cp)
        variable cnt:integer range 0 to 37;
        begin
          if CR='0' then
             cnt:=0;
               Qdata<="00000001";
          elsif cp'event and cp='1' then
              cnt:=cnt+1;
          end if;
          case cnt is
          -------Init LCD1602-----------
          when 0 =>RS<='0';Qdata<="00111000";  --0x38,
          when 1 =>RS<='0';Qdata<="00001100";  --0x0C
          when 2 =>RS<='0';Qdata<="00000001";  --0x01
          when 3 =>RS<='0';Qdata<="00000110";  --0x60
          when 4 =>RS<='0';Qdata<="10000000";  --display,0x00+0x80,1h1w
          -------data display-------------
          when 5=>RS<='1';Qdata<="10100000";--空格
      when 6=>RS<='1';Qdata<="10100000";--空格
      when 7=>RS<='1';Qdata<="10100000";--空格
      when 8=>RS<='1';Qdata<="01011001"; --Y
      when 9=>RS<='1';Qdata<="01110101";--u
      when 10=>RS<='1';Qdata<="01101010";--j
      when 11=>RS<='1';Qdata<="01101001";--i
      when 12=>RS<='1';Qdata<="01100001";--a
      when 13=>RS<='1';Qdata<="01101110";--n
      when 14=>RS<='1';Qdata<="01110001";--q
      when 15=>RS<='1';Qdata<="01110101";--u
      when 16=>RS<='1';Qdata<="01100001";--a
      when 17=>RS<='1';Qdata<="01101110";--n
      when 18=>RS<='1';Qdata<="10100000";---空格
      when 19=>RS<='1';Qdata<="10100000";---空格
      when 20=>RS<='1';Qdata<="10100000";---空格
        when 21=>RS<='0';Qdata<="11000000";--設(shè)定顯示的位置在10H+80H,
       when 22=>RS<='1';Qdata<="01000100";---D diangong xueyuan
     when 23=>RS<='1';Qdata<="01101001";---i
     when 24=>RS<='1';Qdata<="01100001";---a
     when 25=>RS<='1';Qdata<="01101110";---n
     when 26=>RS<='1';Qdata<="01100111";---g
     when 27=>RS<='1';Qdata<="01101111";---o
     when 28=>RS<='1';Qdata<="01101110";--n
     when 29=>RS<='1';Qdata<="01100111";---g
     when 30=>RS<='1';Qdata<="10100000";--- 空格
     when 31=>RS<='1';Qdata<="01011000";---X
     when 32=>RS<='1';Qdata<="01110101";---u
     when 33=>RS<='1';Qdata<="01100101";---e
     when 34=>RS<='1';Qdata<="01111001";---y
     when 35=>RS<='1';Qdata<="01110101";---u
     when 36=>RS<='1';Qdata<="01100001";---a
     when 37=>RS<='1';Qdata<="01101110";---n
     end case;
      end process;
     end;
ID:730662 發(fā)表于 2020-5-13 16:46 | 只看該作者
請問    這個引腳約束怎么編寫
