查看: 4562|回復(fù): 1
51單片機(jī)籃球計(jì)分器程序
ID:145308 發(fā)表于 2016-10-31 11:52 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
#include <intrins.h>
uchar secs = 0;
uchar minutes = 1;
uchar LED,num1,num2,num = 4;
uchar  flag1 = 1,flag2 = 0;
uchar m_secs = 24;
uchar key_value = 0;
uchar table[13] = {1,2,3,4,5,6,7,8,9,0,1,2,3};
uchar code LedNum[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar scan_kay(void);
void delay(uchar z);
void INT0_Initial(void)
    EX0 = 1;
    IT0 = 1;
    EA = 1;
    P1 = 0xF0;
void INT0_Interrupt(void) interrupt 0
    uchar temp;
    temp = scan_kay();
    if(temp!=0x7f)
        key_value = temp;
    P1 = 0xF0;
void Time0_Initial(void)
    TMOD = 0x01;
    TH0 = (65536-50000)/256;
    TL0 = (65536-50000)%256;
    ET0 = 1;
    TR0 = 1;
    EA = 1;
    PT0 = 1;
    PX0 = 0;
volatile uchar cnt = 0;
void Time0_Interrupt(void) interrupt 1
    cnt ++;
minutes=11;
    if(cnt==15)
        cnt = 0;
        secs --;
        m_secs --;
        if(flag2==1)
            LED = !LED;
        if(flag2==0)
            LED = 0;
    if(secs>60)
        secs = 59;
        minutes --;
    if(m_secs>24)
        m_secs = 23;
        if(flag1==1)
            flag2 = 1;
        if(flag1==0)
            flag2 = 0;
    if(minutes>60)
        minutes = 11;
        m_secs = 24;
        num ++;
    if(num==4)
        num = 1;
void HEXTOBCD(void)
    table[0] = LedNum[num];
    table[1] = LedNum[m_secs/10];
    table[2] = LedNum[m_secs%10];
    table[3] = LedNum[minutes/10];
    table[4] = LedNum[minutes%10];
    table[5] = LedNum[secs/10];
    table[6] = LedNum[secs%10];
    table[7] = LedNum[num1/100];
    table[8] = LedNum[num1%100/10];
    table[9] = LedNum[num1%10];
    table[10] = LedNum[num2/100];
    table[11] = LedNum[num2%100/10];
    table[12] = LedNum[num2%10];
void Display(uchar *str)
    uchar i,temp = 0;
    for(i=0;i<13;i++)
        P0 = 0x00;
        _nop_();
        P2 = temp+i;
        P0 = str[i];
        delay(2);
uchar i,j;
void delay(uchar z)
for(i=1;i<z;i++)
  for(j=1;j<110;j++);
    INT0_Initial();
    Time0_Initial();
    delay(10);
    LED = 0;
        switch(key_value)
            case 12:
                num1 ++;key_value = 0;
                flag1 = 0;
                if(num1>255)
                 num1 = 0;
             break;
            case 13:
                num1 --;key_value = 0;
                flag1 = 0;
                if(num1>255)
                 num1 = 255;
             break;
            case 14:
                num2 ++;key_value = 0;
                flag1 = 0;
                if(num2>255)
                 num2 = 0;
             break;
            case 15:
                num2 --;key_value = 0;
                flag1 = 0;
                if(num2>255)
                 num2 = 255;
             break;
            case 1:
             TR0 = 1;
                key_value = 0;
             break;
            case 2:
                num1 = 0;num2 = 0;
             num = 4;
                secs = 0;minutes = 12;
                m_secs = 24;
                key_value = 0;
             TR0 = 1;
             break;
            case 3:
             TR0 = 0;
                key_value = 0;
             break;
            default:
             break;
        HEXTOBCD();
        delay(5);
        Display(table);
        delay(10);
uchar scan_key(void)
    uchar i,key_value;
    P1 = 0xFF;
    for(i=0;i<4;i++)
        P1 = ~(1<<i);
        key_value = P1&0xF0;
        if(key_value!=0xF0)
            delay(20);
            if(key_value!=0xF0)
                key_value &= 0xF0;
                switch(key_value)
                    case 0x70: key_value = 15-(3-i)*4;break;
                    case 0xb0: key_value = 14-(3-i)*4;break;
                    case 0xd0: key_value = 13-(3-i)*4;break;
                    case 0xe0: key_value = 12-(3-i)*4;break;
                    default: key_value = 0x7f;
                return key_value;
        P1 = 0xFF;
    return 0x7f;
    uchar key_va1,key_va2;
    key_va1 = scan_key();
    if(key_va1==0x7f)
        return 0x7f;
    do
        key_va2 = scan_key();
    }while(key_va1==key_va2);
    return key_va1;
相關(guān)帖子
ID:94489 發(fā)表于 2016-11-1 19:59 | 只看該作者
學(xué)習(xí)學(xué)習(xí)
