查看: 10576|回復(fù): 9
8x8點陣顯示滾動廣告 單片機源程序
ID:146211 發(fā)表于 2016-11-5 10:24 | 顯示全部樓層 |閱讀模式
工具/原料
  • 單片機開發(fā)板
  • keil C IDE開發(fā)工具
  • 8*8字模取模軟件
下載:
(121)8x8點陣顯示滾動廣告.zip (16.47 KB, 下載次數(shù): 127)
部分源碼預(yù)覽:
  1. /*=======================================================================
  2. 程序名        :        8x8點陣顯示滾動廣告
  3. 編寫人        :        李鎮(zhèn)
  4. 編寫時間:        2015年5月22日
  5. 硬件支持:        STC89C52(QFC51開發(fā)板聯(lián)系旺旺ID:qq763187758)
  6. 系統(tǒng)時鐘:        12MHZ
  7. 程序目的:        在試驗開發(fā)板的點陣上顯示滾動廣告.
  8. 試驗工具:        QFC51開發(fā)板,記得把顯示切換到點陣顯示4的位置
  9. 程序說明:        本程序的取模方式是縱向取模,0電平點亮,所以用軟件取的模還要反白,
  10.                         點陣掃描原理是:先選通第最左邊的一列,再發(fā)送取模數(shù)據(jù),一直掃描到最后一列
  11.                         點陣掃描每次只掃描前8列,滾動的效果的原理是,每隔一定時間,就把所有取模向前移一位,就達到滾動效果.
  12.                         當然也可以向后移一位,或者多位.
  13. ========================================================================*/
  14. #include <reg52.h>                                        //包含頭文件
  15. /*===把點陣的列選放在這個數(shù)組里===*/
  16. unsigned char big[8] = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  17.        //0111 1111 = 0x7f  選通第7列.從右至左,與數(shù)據(jù)的位相對,數(shù)據(jù)的0位在最右邊,點陣的第0列也在最右邊
  18.        //1011 1111 = 0xbf
  19.        //1101 1111 = 0xdf
  20.        //1110 1111 = 0xef
  21.        //1111 0111 = 0xf7
  22.        //1111 1011 = 0xfb
  23.        //1111 1101 = 0xfd
  24.        //1111 1110 = 0xfe        選通第0列,從右至左,與數(shù)據(jù)的位相對,數(shù)據(jù)的0位在最右邊,點陣的第0列也在最右邊
  25. /*===/www.qq763187758.com(縱向取模)===*/
  26. xdata unsigned char LedFai[] = {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCF,0xB7,0xBB,0xDD,0xBB,0xB7,0xCF,0xFF,
  27.        0xF1,0xFE,0xF9,0xFE,0xF1,0xFF,0xF1,0xFE,0xF9,0xFE,0xF1,0xFF,0xF1,0xFE,0xF9,0xFE,
  28.        0xF1,0xFF,0xFE,0xFF,0xC7,0xBB,0xBB,0xDB,0x80,0xFF,0xC7,0xBB,0xBB,0xDB,0x80,0xFF,
  29.        0x9F,0xBF,0xB8,0xB7,0x8F,0xFF,0xE1,0xD6,0xB6,0xB6,0xF9,0xFF,0xBD,0xBE,0xAE,0x96,
  30.        0xB9,0xFF,0xFF,0xDE,0x80,0xFE,0xFF,0xFF,0xC9,0xB6,0xB6,0xB6,0xC9,0xFF,0x9F,0xBF,
  31.        0xB8,0xB7,0x8F,0xFF,0x9F,0xBF,0xB8,0xB7,0x8F,0xFF,0x8D,0xAE,0xAE,0xAE,0xB1,0xFF,
  32.        0xC9,0xB6,0xB6,0xB6,0xC9,0xFF,0xFE,0xFF,0xE3,0xDD,0xDD,0xDD,0xFB,0xFF,0xE3,0xDD,
  33.        0xDD,0xDD,0xE3,0xFF,0xC1,0xEF,0xDF,0xDF,0xE1};
  34. /*===點陣掃描===*/
  35. void led_out(void)
  36. {
  37.         unsigned char i,j;                                //聲明1個變量用來循環(huán)用,1個變量用來循環(huán)延時用
  38.         for(i = 0;i < 8;i++)                        //for循環(huán)8次,i從0到7循環(huán)8次
  39.         {
  40.                 P0 = LedFai[i];                                //P0口輸出縱向取模,P1口輸出列選,在哪1列上顯示.從列選表里與i配合輸出.
  41.                 P1 = big[i];                                //P1口輸出列掃描,分別掃描點陣的8個列,從左到右一列一列掃描.
  42.                 for(j = 0;j < 140;j++);                //延時一段時間.
  43.                 P1 = 0xff;                                        //關(guān)閉列選.
  44.         }
  45. }
  46. /*===把字模數(shù)組里的元素整體向左移一位===*/
  47. //sizeof(LedFai)的作用是獲得LedFai數(shù)組的元素的個數(shù)。減1就得到此數(shù)組的最大元素下標。
  48. void LedLeft()
  49. {
  50.         unsigned char i;
  51.         unsigned char j = LedFai[0];                //先把字模數(shù)組的第0個元素暫存,因為取模左移時,這個字模要被移出.
  52.
  53.         for(i = 0;i < sizeof(LedFai)-1;i++)
  54.         {
  55.                 LedFai[i] = LedFai[i+1];                //把字模數(shù)組里的后一個字模向前移動一位.
  56.         }
  57.         LedFai[sizeof(LedFai)-1] = j;                //把字模數(shù)組的最前面字模放在這個數(shù)組的最后.
  58. }
  59. /*===主函數(shù)===*/
  60. void main(void)
  61. {
  62.         unsigned char j = 0;                                //聲明1個變量用來控制滾動時間
  63.         while(1)                                                        //主循環(huán).
  64.         {
  65.                 j++;                                                        //循環(huán)延時變量自增
  66.                 if(j == 100)                                        //如果時間到,滾動一次.
  67.                 {
  68.                         j = 0;                                                //清循環(huán)延時計數(shù)為0,重新開始計數(shù)
  69.                         LedLeft();                                        //取模移整體移一位
  70.                 }
  71.                 led_out();                                                //點陣掃描.
  72.         }
  73. }
參與人數(shù) 2黑幣 +55 收起 理由
wwr568174724 + 5 很給力!
admin + 50 共享資料的黑幣獎勵!
ID:1 發(fā)表于 2016-11-13 17:23 | 顯示全部樓層
51黑有你更精彩。!
ID:218310 發(fā)表于 2017-7-18 17:37 | 顯示全部樓層
ID:316044 發(fā)表于 2018-4-25 11:11 | 顯示全部樓層
剛接觸,還得學(xué)一學(xué),很多地方都不明白
ID:363785 發(fā)表于 2018-7-3 15:18 | 顯示全部樓層
感謝大大的程序
ID:398944 發(fā)表于 2018-9-22 22:55 | 顯示全部樓層
沒有硬件連接圖嗎?
ID:726079 發(fā)表于 2020-6-11 13:15 | 顯示全部樓層
感謝大大的程序
ID:776487 發(fā)表于 2020-6-11 18:03 來自觸屏版 | 顯示全部樓層
有沒有仿真視頻
ID:138443 發(fā)表于 2020-6-11 20:10 | 顯示全部樓層
支持通信更換內(nèi)容嗎?
ID:86450 發(fā)表于 2020-8-21 13:10 | 顯示全部樓層
沒有硬件連接圖嗎?
