查看: 2323|回復(fù): 1
單片機(jī)控制舵機(jī)程序?yàn)槭裁礋贿M(jìn)去
程序如下:
#include <reg52.h>
uchar count;
sbit pwm=P3^0;
sbit inc=P3^7;
sbit dec=P3^6;
uchar angle;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delayms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
void init()
        TMOD=0x01;
        IE=0x82;
        TH0=0xfe;
        TL0=0x33;
        TR0=1;
void timer0() interrupt 1
        TH0=0xfe;
        TL0=0x33;
        if(count<angle)
                pwm=1;
                pwm=0;
                count++;
                count=count%40;
void keyscan()
        if(inc==0)
                delayms(10);
                if(inc==0)
                        angle++;
                        count=0;
                        if(angle==6)
                                angle=5;
                        while(!inc);
        if(dec==0)
                delayms(10);
                if(dec==0)
                        angle--;
                        count=0;
                        if(angle==0)
                                angle=1;
                        while(!dec);
void display()
        uchar bai,shi,ge;
        switch(angle)
                case 1:
                        bai=0;
                        shi=0;
                        ge=0;
                        break;
                case 2:
                        bai=0;
                        shi=4;
                        ge=5;
                        break;
                case 3:
                        bai=0;
                        shi=9;
                        ge=0;
                        break;
                case 4:
                        bai=1;
                        shi=3;
                        ge=5;
                        break;
                case 5:
                        bai=1;
                        shi=8;
                        ge=0;
                        break;
        dula=1;
                P0=table[bai];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfe;
                wela=0;
                delayms(5);
                dula=1;
                P0=table[shi];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfd;
                wela=0;
                delayms(5);
                dula=1;
                P0=table[ge];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfb;
                wela=0;
                delayms(5);
        angle=1;
        count=0;
        init();
                keyscan();
                display();
相關(guān)帖子
ID:143116 發(fā)表于 2016-11-9 10:53 | 只看該作者
補(bǔ)上燒錄軟件的報錯
