#在這里快/**************************************************************************************** /*硬件制作:07電氣工程 張國榮 /*軟件調(diào)試:07電氣工程 付春平 /*描 述: 搖搖棒程序,通過滾珠開關(guān)檢測周期,搖動時間自適應(yīng),圖像始終保持在中間。開機(jī)后每搖晃10次切換下一組字模 /* 按了一下按鍵后變成了手動切換,直到回到第一組字的時候再自動切換 如有問可直接加我QQ:77554971 技術(shù)交流群:120069344 套件出售 詳細(xì)制作在里面了! 最后祝各位制作成功!學(xué)習(xí)進(jìn)步! /*****************************************************************************************/ #include <STC11F60XE.h> /*********外部接口定義**********/ #define uchar unsigned char #define uint unsigned int //宏定義 #define out P1 //數(shù)據(jù)輸出端口 sbit led1=P3^0; //第1組LED sbit led2=P3^1; //第2組LED sbit led3=P3^3; //第3組LED sbit led4=P3^4; //第4組LED sbit key1=P3^5; //按鍵輸入 sbit p3_2=P3^2; uchar KY,num; //KY作用在后面說明 uchar BUFF; //緩存 /*********全局變量定義**********/ unsigned long int TimeCount=0; unsigned int DelayN=80, //延時臨時計數(shù) DelayTime=80; //每次延時的周期個數(shù) unsigned char key,keyy; /**********************************************/ void delay(unsigned char n); void DelayMs(void); /*******************************************/ unsigned char code text0[]={ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0x00,0xB7,0xBB,0xB7,0xBB,0xB3,0xBB,0xB4,0xBB,0xB5,0xBB,0xB7,0xBB,0xB7,0xBB,0xB7,0xBB,0x07,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"自",1*/ 0xBF,0xBF,0xBE,0xDF,0x39,0xE0,0xFF,0xDF,0xEF,0xBF,0xEF,0xBF,0x6D,0xB0,0x6D,0xB7,0x6D,0xB7,0x01,0xB7,0x6E,0xB7,0x6E,0xB7,0x6E,0xB0,0xEF,0xBF,0xEF,0xBF,0xFF,0xFF,/*"適",2*/ 0xFF,0xBF,0xFF,0xC7,0x03,0xF8,0xBB,0xDF,0x7B,0xDF,0xFB,0xD0,0xEB,0xDB,0xDA,0xDF,0x39,0xDC,0x7B,0xCF,0xFB,0xD3,0xFB,0xDC,0x1B,0xDF,0xBB,0xDF,0xFF,0xDF,0xFF,0xFF,/*"應(yīng)",3*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/ 0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"搖",6*/ 0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"搖",7*/ 0xEF,0xFC,0x2F,0xFF,0x00,0x00,0xAF,0xFF,0x6F,0xFD,0xBB,0xF5,0xAB,0xF6,0x2B,0xF5,0x8B,0xF5,0xA0,0x00,0x2B,0xF5,0xAB,0xF4,0xAB,0xF6,0xBB,0xF5,0xBF,0xFD,0xFF,0xFF,/*"棒",8*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",9*/ }; unsigned char code text1[]={ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/ 0xF7,0xFD,0xF7,0xFE,0x76,0xFF,0x31,0x00,0x57,0xFF,0xE7,0x7C,0xFF,0xBF,0x01,0xCF,0x7D,0xF0,0x7D,0xFF,0x7D,0xFF,0x7D,0x80,0x01,0x7F,0xFF,0x7F,0xFF,0x0F,0xFF,0xFF,/*"祝",2*/ 0x7F,0xFF,0xBF,0xFF,0x0F,0x80,0xD3,0xFF,0xBC,0xEF,0xDF,0xF3,0x67,0xFC,0xF0,0xDE,0xF5,0xBF,0x17,0xC0,0xF7,0xFF,0x77,0xFF,0xD7,0xFC,0xE3,0xE3,0xF7,0xF7,0xFF,0xFF,/*"你",3*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/ 0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",6*/ 0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",7*/ 0xBF,0xFF,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF3,0x01,0xFC,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0x01,0x80,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xFF,0xFF,/*"開",8*/ 0xFF,0xFB,0x7F,0xFC,0xFF,0xFF,0xFF,0xFF,0x0F,0xC0,0xFF,0xBF,0xFE,0xBF,0xFD,0xBF,0xE3,0xBF,0xF7,0xBF,0xFF,0xBF,0xBF,0x87,0x7F,0xFF,0xFF,0xF8,0xFF,0xFD,0xFF,0xFF,/*"心",9*/ }; unsigned char code text2[]={ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0x01,0x00,0x00,0x80,0x01,0x00,0x00,0x80,0xF9,0xFF,0xFF,0x9F, 0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0x01,0xFE,0xFF, 0x7F,0x00,0xF8,0xFF,0x3F,0x00,0xF0,0xFF,0x1F,0x00,0xE0,0xFF,0x0F,0x00,0xC0,0xFF,0x07,0x00,0x80,0xFF,0x03,0x00,0x00,0xFF,0x03,0x00,0x00,0xFF,0x03,0x00,0x00,0xFE, 0x03,0x00,0x00,0xFC,0x03,0x00,0x00,0xF8,0x07,0x00,0x00,0xF0,0x0F,0x00,0x00,0xE0,0x1F,0x00,0x00,0xE0,0x3F,0x00,0x00,0xC0,0x3F,0x00,0x00,0x80,0x1F,0x00,0x00,0xC0, 0x0F,0x00,0x00,0xE0,0x07,0x00,0x00,0xF0,0x03,0x00,0x00,0xF8,0x03,0x00,0x00,0xFC,0x03,0x00,0x00,0xFE,0x03,0x00,0x00,0xFF,0x07,0x00,0x80,0xFF,0x0F,0x00,0xC0,0xFF, 0x1F,0x00,0xE0,0xFF,0x3F,0x00,0xE0,0xFF,0xFF,0x00,0xF8,0xFF,0xFF,0x01,0xFC,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x07,0x00,0x00,0xE0,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xC0,0xFF,0xFF,0xFF,0xC7,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF, 0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xC7,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xE0,0xFF,0xFF,0xFF,0xFF,/*"未命名文件",0*/ }; /***********n(us)延時子程序***************/ void DelayUs(uint N) { uint x; for(x=0; x<=N;x++); } /******************************************/ void main() { AUXR=0x80; CLK_DIV=1; EX0=1; //開放外部中斷0 IT0=1; //中斷0為邊沿觸發(fā)方式 IP=0x02; //設(shè)置中斷優(yōu)先級 TMOD=0x02; //定時器0方式2,8位重裝載 TH0=0x80; //設(shè)定定時器初值 TL0=0x80; KY=0; EA=1; //開放中斷 ET0=1; //開放定時器0中斷 TR0=1; //啟動定時器0,開始計時*/ key=0; //初始化顯示第一組文字 keyy=0; P1M0=0x55; //0101 0101 /P1.0 P1 .2 P1.4 P1.6推挽輸出 P1M1=0xAA; while(1){//等待中斷 if(key1==0){ //有鍵按下 DelayUs(50); if(key1==0){ key++; //更換下一幅圖片 if(key>2) key=0; //圖片循環(huán)顯示 根據(jù)顯示的組數(shù)來定義 這里有9組 所以就要keyy>9 while(key1==0); //等待按鍵釋放 } } if(num>10) //每中斷10次切換 { keyy++; num=0; } if(keyy>2)keyy=0; //圖片循環(huán)顯示 根據(jù)顯示的組數(shù)來定義 這里有9組 所以就要keyy>9 } } /*********文字顯示子程序**********/ void display_word(unsigned char code *text) { unsigned char i,j=2; //j為圖片起始位置 3 為第3個開始是圖片 如果要顯示高時32的大字 也屬于圖片格式 DelayUs(6400); for(i=0;i<64;i++) { P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; if((key>=j)||(keyy>=j)) BUFF=(*(text+i*4+3)); else BUFF=(*(text+128+i*2+1)); led4=0; P1=~BUFF>>1; P3M0=0x10; //0001 0000 //P3.4推挽輸出 P3 .0 P3.3 P3.1輸入高阻 P3M1=0x0B; //0000 1011 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 led4=1; P1=BUFF; //01010101 1357 P3M0=0x10; //0001 0000 //P3.4推挽輸出 P3 .0 P3.3 P3.1輸入高阻 P3M1=0x0B; //0000 1011 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 if((key>=j)||(keyy>=j)) BUFF=(*(text+i*4+2)); else BUFF=(*(text+128+i*2)); led3=0; P1=~BUFF>>1; P3M0=0x08; //0000 1000 //P3.3推挽輸出 P3 .0 P3.1 P3.4輸入高阻 P3M1=0x13; //0001 0011 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 led3=1; P1=BUFF; //01010101 1357 P3M0=0x08; //0000 1000 //P3.3推挽輸出 P3 .0 P3.1 P3.4輸入高阻 P3M1=0x13; //0001 0011 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; if((key>=j)||(keyy>=j)) BUFF=(*(text+i*4+1)); else BUFF=(*(text+i*2+1)); led2=0; P1=~BUFF>>1; P3M0=0x02; //0000 0010 //P3.1推挽輸出 P3 .0 P3.3 P3.4輸入高阻 P3M1=0x19; //0001 1001 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 led2=1; P1=BUFF; //01010101 1357 P3M0=0x02; //0000 0010 //P3.1推挽輸出 P3 .0 P3.3 P3.4輸入高阻 P3M1=0x19; //0001 1001 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 if((key>=j)||(keyy>=j)) BUFF=(*(text+i*4)); else BUFF=(*(text+i*2)); led1=0; P1=~BUFF>>1; P3M0=0x01; //0000 0001 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1A; //0001 1010 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 led1=1; P1=BUFF; //01010101 1357 P3M0=0x01; //0000 0001 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1A; //0001 1010 delay(1); } } /*********顯示內(nèi)容選擇子程序**********/ void display(unsigned char t) { keyy=0; switch (t){ //通過按鍵選擇顯示內(nèi)容 case 0: {display_word(text0);}break; case 1: {display_word(text1);}break; case 2: {display_word(text2);}break; // case 3: {display_word(text3);}break; // case 4: {display_word(text4);}break; // case 5: {display_word(text5);}break; // case 6: {display_word(text6);}break; // case 7: {display_word(text7);}break; // case 8: {display_word(text8);}break; // case 9: {display_word(text9);}break; // case 10:{display_word(text10);}break; //default:{display_word(text1);} }} /*****************************************/ void display1(unsigned char y) { switch (y){ //通過按鍵選擇顯示內(nèi)容 case 0: {display_word(text0);}break; case 1: {display_word(text1);}break; case 2: {display_word(text2);}break; // case 3: {display_word(text3);}break; // case 4: {display_word(text4);}break; // case 5: {display_word(text5);}break; // case 6: {display_word(text6);}break; // case 7: {display_word(text7);}break; // case 8: {display_word(text8);}break; // case 9: {display_word(text9);}break; // case 10:{display_word(text10);}break; } } /***************************************/ /*********延時子程序**********/ void delay(unsigned char n) { for(;n>0;n--){ DelayN=DelayTime; while (DelayN); } } /*********中斷子程序**********/ void int0() interrupt 0 //使用外部中斷0 { KY=~KY; if(KY==0) { DelayTime=TimeCount/1580; TimeCount=0; //延時周期計數(shù)清零 if(key==0) { num++; display1(keyy); //根據(jù)按鍵選擇循環(huán)顯示文字 } else { display(key); //根據(jù)按鍵選擇循環(huán)顯示文字 } } } void timer0() interrupt 1 //定時器0中斷子程序 { TimeCount++; if (DelayN!=0) DelayN--; } 復(fù)制代碼速回復(fù)# |
