- #include<reg51.h>
- #define uchar unsigned char
- uchar a0=16,b0=16,c0=16,d0=16,e0=16,f0=16,wei,temp,key,i,j,k;
- uchar jia,jian,cheng,chu,dengyu,jia0,jian0,cheng0,chu0,qingling;
- uchar s0,s1,s2,s3,s4,s5; //參加運(yùn)算的各個(gè)位
- unsigned long qian,hou;//定義參于運(yùn)算的第一個(gè)數(shù)和第二個(gè)數(shù)。
- sbit dula=P2^6;
- sbit wela=P2^7;
- sbit beep=P2^3;
- unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
- 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
- void delay(uchar i)
- for(j=i;j>0;j--)
- for(k=125;k>0;k--);
- void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f)
- dula=0;
- P0=table[a];
- dula=1;
- dula=0;
- wela=0;
- P0=0xfe;
- wela=1;
- wela=0;
- delay(5);
- P0=table[b];
- dula=1;
- dula=0;
- P0=0xfd;
- wela=1;
- wela=0;
- delay(5);
- P0=table[c];
- dula=1;
- dula=0;
- P0=0xfb;
- wela=1;
- wela=0;
- delay(5);
- P0=table[d];
- dula=1;
- dula=0;
- P0=0xf7;
- wela=1;
- wela=0;
- delay(5);
- P0=table[e];
- dula=1;
- dula=0;
- P0=0xef;
- wela=1;
- wela=0;
- delay(5);
- P0=table[f];
- dula=1;
- dula=0;
- P0=0xdf;
- wela=1;
- wela=0;
- delay(5);
- void keyscan()
- P3=0xfe;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xee:
- key=0;
- wei++;
- break;
- case 0xde:
- key=1;
- wei++;
- break;
- case 0xbe:
- key=2;
- wei++;
- break;
- case 0x7e:
- key=3;
- wei++;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- P3=0xfd;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xed:
- key=4;
- wei++;
- break;
- case 0xdd:
- key=5;
- wei++;
- break;
- case 0xbd:
- key=6;
- wei++;
- break;
- case 0x7d:
- key=7;
- wei++;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- P3=0xfb;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xeb:
- key=8;
- wei++;
- break;
- case 0xdb:
- key=9;
- wei++;
- break;
- case 0xbb:
- qingling=1;
- //key=10;
- //wei++;
- break;
- case 0x7b:
- dengyu=1;
- //key=11;
- //wei++;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- P3=0xf7;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xe7:
- jia=1;
- //key=12;
- // wei++;
- break;
- case 0xd7:
- jian=1;
- break;
- case 0xb7:
- cheng=1;
- break;
- case 0x77:
- chu=1;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- void display0()
- if(key!=20)
- switch(wei)
- case 1: a0=key;
- b0=16;
- c0=16;
- d0=16;
- e0=16;
- f0=16;
- break;
- case 2: b0=key;
- c0=16;
- d0=16;
- e0=16;
- f0=16;
- break;
- case 3: c0=key;
- d0=16;
- e0=16;
- f0=16;
- break;
- case 4: d0=key;
- e0=16;
- f0=16;
- break;
- case 5: e0=key;
- f0=16;
- break;
- case 6: f0=key;
- //wei=0;
- break;
- key=20;
- display(a0,b0,c0,d0,e0,f0);
- if(a0!=16) s5=a0;
- if(b0!=16) s4=b0;
- if(c0!=16) s3=c0;
- if(d0!=16) s2=d0;
- if(e0!=16) s1=e0;
- if(f0!=16) s0=f0;
- void main()
- { uchar gongneng,yunsuan;
- while(1)
- keyscan();
- gongneng=jia|jian|cheng|chu|dengyu|qingling;
- if(gongneng==0)
- display0();
- else
- { yunsuan=jia|jian|cheng|chu;
- if(yunsuan)
- a0=16;
- b0=16;
- c0=16;
- d0=16;
- e0=16;
- f0=16;
- //wei=0;
- if(jia)
- {jia=0; jia0=1;jian0=0;cheng0=0;chu0=0;}
- if(jian)
- {jian=0;jia0=0;jian0=1;cheng0=0;chu0=0;}
- if(cheng)
- {cheng=0;jia0=0;jian0=0;cheng0=1;chu0=0;}
- if(chu)
- {chu=0; jia0=0;jian0=0;cheng0=0;chu0=1;}
- switch(wei)
- case 6:
- qian=s5*100000+s4*10000+s3*1000+s2*100+s1*10+s0;break;
- case 5:
- qian=s5*10000+s4*1000+s3*100+s2*10+s1;break;
- case 4:
- qian=s5*1000+s4*100+s3*10+s2;break;
- case 3:
- qian=s5*100+s4*10+s3;break;
- case 2:
- qian=s5*10+s4;break;
- case 1:
- qian=s5;break;
- wei=0;
- s0=0;s1=0;s2=0;s3=0;s4=0;s5=0;
- //P1=0x55;
- if(dengyu)
- dengyu=0;
- //display(16,16,16,16,16,16);
- switch(wei)
- case 6:
- hou=s5*100000+s4*10000+s3*1000+s2*100+s1*10+s0;break;
- case 5:
- hou=s5*10000+s4*1000+s3*100+s2*10+s1;break;
- case 4:
- hou=s5*1000+s4*100+s3*10+s2;break;
- case 3:
- hou=s5*100+s4*10+s3;break;
- case 2:
- hou=s5*10+s4;break;
- case 1:
- hou=s5;break;
- wei=0;
- if(jia0)
- {jia0=0; hou=qian+hou;}
- if(jian0)
- {jian0=0; hou=qian-hou;}
- if(cheng0)
- {cheng0=0; hou=qian*hou;}
- if(chu0)
- {chu0=0; hou=qian/hou;}
- if(hou<10)
- a0=hou;b0=16;c0=16;d0=16;e0=16;f0=16;
- else
- if(hou<100)
- {a0=hou/10;b0=hou%10;c0=16;d0=16;e0=16;f0=16;}
- else
- if(hou<1000)
- {a0=hou/100;b0=hou%100/10;c0=hou%10;d0=16;e0=16;f0=16;}
- else
- if(hou<10000)
- {a0=hou/1000;b0=hou%1000/100;c0=hou%100/10;d0=hou%10;e0=16;f0=16;}
- else
- if(hou<100000)
- {a0=hou/10000;b0=hou%10000/1000;c0=hou%1000/100;d0=hou%100/10;e0=hou%10;f0=16;}
- else
- if(hou<1000000)
- {a0=hou/100000;b0=hou%100000/10000;c0=hou%10000/1000;d0=hou%1000/100;e0=hou%100/10;f0=hou%10;}
- P1=hou;
- if(qingling)
- a0=16;b0=16;c0=16;d0=16;e0=16;f0=16;
- jia=0;jian=0;cheng=0;chu=0;
- jia0=0;jian0=0;cheng0=0;chu0=0;
- qingling=0;dengyu=0;
- qian=0;hou=0;
復(fù)制代碼 |
