查看: 6852|回復(fù): 3
自己做的基于51單片機+lcd1602的計數(shù)器 希望可以幫到大家
ID:209499 發(fā)表于 2017-6-15 10:51 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
這是個人自己做的,希望可以幫到大家、
單片機代碼:
  1. #include<AT89X51.H>
  2. #include<intrins.h>
  3. sbit RS=P3^3;
  4. sbit RW=P3^6;
  5. sbit E=P3^5;
  6. sbit BF=P1^7;
  7. unsigned char chan=0xc0;
  8. int tcount=0,t,p;
  9. long q;
  10. void delay1ms()
  11. {  unsigned char i,j;
  12.    for(i=0;i<10;i++)
  13.            for(j=0;j<33;j++);
  14. }
  15. void delay(unsigned int n)  //延時
  16. {  unsigned int i;
  17.    for(i=0;i<n;i++)
  18.      delay1ms();
  19. }
  20. void nop(unsigned s)  //1602的延時
  21. {  unsigned char i;
  22.    for(i=0;i<s;i++)
  23.      _nop_();
  24. }
  25. unsigned char busytest(void)
  26. {   bit result;
  27.         RS=0;
  28.         RW=1;
  29.         E=1;
  30.         nop(4);
  31.         result=BF;
  32.         E=0;
  33.         return result;
  34. }
  35. void writecontrol(unsigned condata)
  36. {while(busytest()==1);
  37.         RS=0;
  38.         RW=0;
  39.         E=0;
  40.         nop(2);
  41.         P1=condata;
  42.         nop(4);
  43.         E=1;
  44.         nop(4);
  45.         E=0;
  46. }
  47. void writedata(unsigned d)
  48. {while(busytest()==1);
  49.         RS=1;
  50.         RW=0;
  51.         E=0;
  52.         P1=d;
  53.         nop(4);
  54.         E=1;
  55.         nop(4);
  56.         E=0;
  57. }
  58. void lcdinit(void)
  59. {delay(15);
  60.         writecontrol(0x38);
  61.         delay(5);
  62.         writecontrol(0x38);
  63.         delay(5);
  64.         writecontrol(0x38);
  65.         delay(5);
  66.         writecontrol(0x0c);
  67.         delay(5);
  68.         writecontrol(0x06);
  69.         delay(5);
  70.         writecontrol(0x01);
  71.          delay(5);
  72. }
  73. void display(long temp)
  74. {
  75. int a[6],i;
  76.          a[0]=temp/100000;        //65536
  77.          a[1]=(temp%100000)/10000;
  78.          a[2]=(temp%10000)/1000;
  79.          a[3]=(temp%1000)/100;
  80.          a[4]=(temp%100)/10;
  81.          a[5]=temp%10;
  82.           writecontrol(0x80+0x00);
  83.                 writedata('C');
  84.           writedata('0');
  85.                 writedata('N');
  86.                 writedata('T');
  87.           writedata('E');
  88.                 writedata('R');
  89.                 writedata(':');
  90.           writecontrol(0x80+0x40+0X05);
  91.     for(i=0;i<6;i++)
  92.          {writedata(a[i]+0x30);
  93.    }
  94. }
  95. void cry()  //初始化定時器,定時器0計數(shù),定時器1計時50ms
  96. { TMOD=0x15;
  97.         TH0=0x00;
  98.         TL0=0x00;
  99.         TH1=0x3c;
  100.         TL1=0xb0;
  101.         TR0=1;TF0=0;
  102.         TR1=1;TF1=0;
  103.         EA=1;
  104.         ET0=1;
  105.         ET1=1;
  106.         p=0;
  107.         tcount=0;
  108. }
  109. void jishi() interrupt 3   //定時器1定時0.5s
  110. {        TH1=0x3c;
  111.         TL1=0xb0;
  112.         TF1=0;
  113.         tcount++;
  114.         if(tcount==10)
  115.         {tcount=0;
  116.          t=1;
  117.         }
  118. }
  119. void jishu() interrupt 1   //定時器0計數(shù),每次溢出p+1,計算溢出次數(shù)
  120. { TH0=0x00;
  121.         TL0=0x00;
  122.         TF0=0;
  123.         p=p+1;
  124. }
  125. void main()
  126. {
  127.   lcdinit();
  128.         P2=0x0f;
  129.         P2=0X1F;
  130.         display(q);
  131.         cry();
  132.   while(1)
  133.         {
  134.           while(t==1)  //當0.5s到了
  135.                 {
  136.                  q=(p*65536+TH0*256+TL0)*2;   //計算頻率
  137.                  display(q);//送1602顯示
  138.                  t=0;p=0;cry();  //重新初始化
  139.                 }
  140.         }
  141.
  142. }
下載:
計數(shù)器.zip (85.89 KB, 下載次數(shù): 42)
相關(guān)帖子
ID:372020 發(fā)表于 2018-7-15 16:18 | 只看該作者
為什么這個代碼沒有數(shù)字變化?
ID:381237 發(fā)表于 2018-8-7 21:45 | 只看該作者
這個就是單片機1602LCD顯示數(shù)字頻率計,并不是計數(shù)器。
