電子鐘仿真原理圖
2016-12-24 03:04 上傳
2016-12-24 03:05 上傳
所有資料下載:
電子鐘.rar
(84.98 KB, 下載次數(shù): 36)
2016-12-18 11:59 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
單片機源碼預(yù)覽:
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit lcdrs=P2^0; //定義1602液晶RS端
- sbit lcden=P2^1;//定義1602液晶LCDEN端
- sbit lcdrw=P2^4; //定義1602液晶RW端
- sbit s1=P3^0; //定義按鍵--功能鍵
- sbit s2=P3^1; //定義按鍵--增加鍵
- sbit s3=P3^2; //定義按鍵--減小鍵
- sbit s4=P3^3; //定義按鍵--鬧鐘鍵
- sbit beep=P2^2; //定義蜂鳴器端
- sbit led=P2^3; //定義LED燈端
- uchar count,s1num,s4num;
- char year,month,day,week,miao,shi,fen,pshi;
- uchar code table[]=" 20 - - ";//定義初始上電時液晶默認顯示狀態(tài)
- void delay(uint z) //延時函數(shù)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void zhuanhuan()
- if(shi==0)
- pshi=12;
- if(shi<=12&&shi>=1)
- pshi=shi;
- if(shi>12)
- pshi=shi-12;
- void di()//蜂鳴器發(fā)聲函數(shù)
- beep=0;
- delay(300);
- beep=1;
- delay(300);
- void write_com(uchar com)//液晶寫命令函數(shù)
- lcdrs=0;
- lcdrw=0;
- P0=com;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void write_date(uchar date)//液晶寫數(shù)據(jù)函數(shù)
- lcdrs=1;
- lcdrw=0;
- P0=date;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void _shi() //寫"AM"、"PM"函數(shù)
- if(shi>=12)
- write_com(0x80+0x40+1);//寫出"PM"
- write_date('P');
- write_date('M');
- else
- write_com(0x80+0x40+1);//寫出"AM"
- write_date('A');
- write_date('M');
- void write_ymd(uchar add1,uchar date1)//寫年月日函數(shù)
- uchar shi,ge;
- shi=date1/10;//分解一個2位數(shù)的十位和個位
- ge=date1%10;
- write_com(0x80+add1);//設(shè)置顯示位置
- write_date(0x30+shi);//送去液晶顯示十位
- write_date(0x30+ge); //送去液晶顯示個位
- void write_sfm(uchar add,uchar date)//寫時分秒函數(shù)
- uchar shi,ge;
- shi=date/10;//分解一個2位數(shù)的十位和個位
- ge=date%10;
- write_com(0x80+0x40+add);//設(shè)置顯示位置
- void write_week(char week) //寫液晶星期顯示函數(shù)
- write_com(0x80+12);
- switch(week)
- case 1: write_date('M');delay(5);
- write_date('O');delay(5);
- write_date('N');
- break;
- case 2: write_date('T');delay(5);
- write_date('U');delay(5);
- write_date('E');
- break;
- case 3: write_date('W');delay(5);
- write_date('E');delay(5);
- write_date('D');
- break;
- case 4: write_date('T');delay(5);
- write_date('H');delay(5);
- write_date('U');
- break;
- case 5: write_date('F');delay(5);
- write_date('R');delay(5);
- write_date('I');
- break;
- case 6: write_date('S');delay(5);
- write_date('A');delay(5);
- write_date('T');
- break;
- case 7: write_date('S');delay(5);
- write_date('N');
- break;
- void writeym()
- day=1;
- month++;
- if(month==13)
- month=1;
- year++;
- if(year==100)
- year=0;
- write_ymd(3,year);//年若變化則重新寫入
- write_ymd(6,month);//月若變化則重新寫入
- void init()//初始化函數(shù)
- uchar num;
- lcden=0;
- year=15;//初始化種變量值
- month=6;
- day=27;
- week=6;
- shi=13;
- fen=59;
- miao=58;
- count=0;
- s1num=0;
- s4num=0;
- write_com(0x38);//初始化1602液晶
- write_com(0x0c);//設(shè)置開顯示,不顯示光標
- write_com(0x06); //寫一個字符后地址加1
- write_com(0x01); //顯示清0,數(shù)據(jù)指針清0
- write_com(0x80);//設(shè)置顯示初始坐標
- for(num=0;num<15;num++)//顯示年月日星期
- write_date(table[num]);
- delay(5);
- delay(5);
- write_com(0x80+0x40+6);//寫出時間顯示部分的兩個":"
- write_date(':');
- delay(5);
- write_com(0x80+0x40+9);
- write_date(':');
- delay(5);
- write_week(week);
- write_ymd(3,year);//分別送去液晶顯示
- write_ymd(9,day);
- write_sfm(10,miao);//分別送去液晶顯示
- write_sfm(7,fen);
- write_sfm(4,shi);
- TMOD=0x01;//設(shè)置定時器0工作模式1
- TH0=(65536-50000)/256;//定時器裝初值
- TL0=(65536-50000)%256;
- EA=1; //開總中斷
- ET0=1; //開定時器0中斷
- TR0=1; //啟動定時器0
- void keyscan()//按鍵掃描函數(shù)
- if(s1==0)
- delay(5);
- if(s1==0)//確認功能鍵被按下
- s1num++;//功能鍵按下次數(shù)記錄
- while(!s1);//釋放確認
- if(s1num==1)//第一次被按下時
- TR0=0; //關(guān)閉定時器
- write_com(0x80+3);//光標定位到年位置
- write_com(0x0f); //光標開始閃爍
- if(s1num==2)//第二次按下光標閃爍定位到月位置
- write_com(0x80+6);
- if(s1num==3)//第三次按下光標閃爍定位到日位置
- write_com(0x80+9);
- if(s1num==4)//第四次按下光標閃爍定位到星期位置
- if(s1num==7)//第七次被按下時光標定位到秒位置
- write_com(0x80+0x40+10);
- if(s1num==6)//第六次按下光標閃爍定位到分位置
- write_com(0x80+0x40+7);
- if(s1num==5)//第五次按下光標閃爍定位到時位置
- write_com(0x80+0x40+4);
- if(s1num==8)//第七次按下
- s1num=0;//記錄按鍵數(shù)清零
- write_com(0x0c);//取消光標閃爍
- TR0=1; //啟動定時器使時鐘開始走
- if(s1num!=0)//只有功能鍵被按下后,增加和減小鍵才有效
- if(s2==0)
- delay(5);
- if(s2==0)//增加鍵確認被按下
- while(!s2);//按鍵釋放
- if(s1num==1)//若功能鍵第一次按下
- year++; //則調(diào)整年加1
- if(year==100)//若滿100后將清零
- year=0;
- write_ymd(3,year);//每調(diào)節(jié)一次送液晶顯示一下
- write_com(0x80+3);//顯示位置重新回到調(diào)節(jié)處
- if(s1num==2)//若功能鍵第二次按下
- month++;//則調(diào)整月加1
- if(month==13)//若滿12后將置一
- month=1;
- write_ymd(6,month);//每調(diào)節(jié)一次送液晶顯示一下
- write_com(0x80+6);//顯示位置重新回到調(diào)節(jié)處
- if(s1num==3)//若功能鍵第三次按下
- day++;//則調(diào)整日加1
- if(year%4==0&&month==2)
- if(day==30)//若滿29后將置一
- day=1;
- if(year%4!=0&&month==2)
- if(day==29)//若滿28后將置一
- day=1;
- if(month!=2&&month!=4&&month!=6&&month!=9&&month!=11)
- if(day==32)//若滿31后將置一
- day=1;
- if(month==4||month==6||month==9||month==11)
- if(day==31)//若滿30后將置一
- day=1;
- write_ymd(9,day);;//每調(diào)節(jié)一次送液晶顯示一下
- write_com(0x80+9);//顯示位置重新回到調(diào)節(jié)處
- if(s1num==4)//若功能鍵第四次按下
- week++;//則調(diào)整星期加1
- if(week==8)//若滿8后將置一
- week=1;
- write_week(week);//每調(diào)節(jié)一次送液晶顯示一下
- write_com(0x80+12);//顯示位置重新回到調(diào)節(jié)處
- if(s1num==7)//若功能鍵第七次按下
- miao++; //則調(diào)整秒加1
- if(miao==60)//若滿60后將清零
- miao=0;
- write_sfm(10,miao);//每調(diào)節(jié)一次送液晶顯示一下
- write_com(0x80+0x40+10);//顯示位置重新回到調(diào)節(jié)處
- if(s1num==6)//若功能鍵第二次按下
- fen++;//則調(diào)整分鐘加1
- if(fen==60)//若滿60后將清零
- fen=0;
- write_sfm(7,fen);//每調(diào)節(jié)一次送液晶顯示一下
- write_com(0x80+0x40+7);//顯示位置重新回到調(diào)節(jié)處
- if(s1num==5)//若功能鍵第五次按下
- shi++;
- if(shi==24)//若滿24后將清零
- shi=0;
- if(s4num==0)
- write_sfm(4,shi);;//每調(diào)節(jié)一次送液晶顯示一下
- write_com(0x80+0x40+4);//顯示位置重新回到調(diào)節(jié)處
- if(s4num==1)
- zhuanhuan();
- _shi();
- write_sfm(4,pshi);;//每調(diào)節(jié)一次送液晶顯示一下
- if(s3==0)
- delay(5);
- if(s3==0)//確認減小鍵被按下
- while(!s3);//按鍵釋放
- year--;//則調(diào)整秒減1
- if(year==-1)//若減到負數(shù)則將其重新設(shè)置為99
- year=99;
- month--;//則調(diào)整分鐘減1
- if(month==0)//若減到負數(shù)則將其重新設(shè)置為59
- month=12;
- if(s1num==3)//若功能鍵第二次按下
- day--;//則調(diào)整日加1
- if(day==0)//若滿29后將置一
- day=29;
- if(day==0)//若滿28后將置一
- day=28;
- if(day==0)//若滿31后將置一
- day=31;
- if(day==0)//若滿30后將置一
- day=30;
- if(s1num==4)//若功能鍵第二次按下
- week--;//則調(diào)整小時減1
- if(week==0)//若減到負數(shù)則將其重新設(shè)置為23
- week=7;
- if(s1num==7)//若功能鍵第一次按下
- miao--;//則調(diào)整秒減1
- if(miao==-1)//若減到負數(shù)則將其重新設(shè)置為59
- miao=59;
- fen--;//則調(diào)整分鐘減1
- if(fen==-1)//若減到負數(shù)則將其重新設(shè)置為59
- fen=59;
- if(s1num==5)//若功能鍵第二次按下
- shi--;
- if(shi==-1)//若滿24后將清零
- shi=23;
- if(s4num==0)
- if(s4num==1)
- zhuanhuan();
- _shi();
- if(s1num==0)
- if(s4==0)
- delay(5);
- if(s4==0)//確認功能鍵被按下
- s4num++;//功能鍵按下次數(shù)記錄
- while(!s4);//釋放確認
- if(s4num==1)//第一次被按下時
- zhuanhuan();
- _shi();
- if(s4num==2)//第二次按下
- s4num=0;//記錄按鍵數(shù)清零
- write_date(' ');
- write_date(' ');
- write_sfm(4,shi);
- void main()//主函數(shù)
- init();//首先初始化各數(shù)據(jù)
- while(1)//進入主程序大循環(huán)
- keyscan();//不停的檢測按鍵是否被按下
- if(s1num!=0)
- led=0;
- else
- led=miao%2;
- if((shi>7&&shi<23)&&(fen==0)&&(miao==0))
- di();
- void timer0() interrupt 1//定時器0中斷服務(wù)程序
- TH0=(65536-50000)/256;//再次裝定時器初值
- count++; //中斷次數(shù)累加
- if(count==20) //20次50毫秒為1秒
- count=0;
- miao++;
- if(miao==60)//秒加到60則進位分鐘
- miao=0;//同時秒數(shù)清零
- fen++;
- if(fen==60)//分鐘加到60則進位小時
- fen=0;//同時分鐘數(shù)清零
- shi++;
- if(shi==24)//小時加到24則小時清零
- shi=0;
- week++;
- if(week==8)
- week=1;
- write_week(week);//星期若變化則重新寫入
- day++;
- if(year%4==0&&month==2)//判斷是否為閏年的2月
- if(day==30)
- writeym();
- write_ymd(9,day);//日若變化則重新寫入
- if(year%4!=0&&month==2)//判斷是否為平年的2月
- if(day==29)
- writeym();
- if(day==32)
- writeym();
- if(day==31)
- writeym();
- if(s4num==1)
- zhuanhuan();
- _shi();
- write_sfm(4,pshi);//12小時制小時若變化則重新寫入
- else write_sfm(4,shi);//24小時制小時若變化則重新寫入
- write_sfm(7,fen);//分鐘若變化則重新寫入
- write_sfm(10,miao);//秒若變化則重新寫入
