這是51單片機(jī)課程設(shè)計(jì)
2017-1-15 03:03 上傳
2017-1-15 03:05 上傳
附件包含測(cè)溫系統(tǒng)的源代碼
和proteus仿真工程文件
8051 with a DS18B20 Temperture Sensor.rar
(33.41 KB, 下載次數(shù): 43)
2017-1-13 15:12 上傳
點(diǎn)擊文件名下載附件
51單片機(jī) 下載積分: 黑幣 -5
請(qǐng)大家多多指,下面是匯編語(yǔ)言源代碼:- DQ BIT P3.7 ; 1 wire line
- swpH equ 0d2H
- swpL equ 0ffH
- WDLSB DATA 30H ;
- WDMSB DATA 31H ;
- ORG 0000H
- LJMP MAIN
- ORG 000BH
- LJMP TMR0 ; Timer0 isr
- ; Timer0 Interrupt Service Routine
- TMR0: MOV TH0,#swpH
- MOV TL0,#swpL
- JB 21H,DSL
- MOV P0,42H
- ORL P0,#00100000B
- SJMP EXIT
- DSL:
- MOV P0,43H
- ORL P0,#00010000B
- EXIT:
- CPL 21H
- RETI
- ; Main program
- MAIN:
- TOINIT:
- CLR EA
- MOV TMOD,#01H
- MOV TH0,#swpH
- MOV TL0,#swpL
- SETB EA
- SETB ET0
- SETB TR0
- MOV R2,#2
- MOV R0,#42H ;
- OVER:
- MOV @R0,#00H;
- INC R0
- DJNZ R2,OVER
- LOOP:
- LCALL DSWD ;
- SJMP LOOP
- ; Read a temperature from the DS18B20
- DSWD:
- LCALL RSTSNR ; Init of the DS18B20
- JNB F0,KEND
- MOV R0,#0CCH
- LCALL SEND_BYTE
- MOV R0,#44H
- LCALL SEND_BYTE ; Send a Convert Command
- SETB EA
- MOV 48H,#1
- SS2:
- MOV 49H,#255
- SS1:
- MOV 4AH,#255
- SS0:
- DJNZ 4AH,SS0
- DJNZ 49H,SS1
- DJNZ 48H,SS2
- CLR EA
- LCALL RSTSNR
- JNB F0,KEND
- MOV R0,#0CCH
- LCALL SEND_BYTE
- MOV R0,#0BEH
- LCALL SEND_BYTE ; Send Read Scratchpad command
- LCALL READ_BYTE ; Read the low byte from scratchpad
- MOV WDLSB,A ; Save the temperature (low byte)
- LCALL READ_BYTE ; Read the high byte from scratchpad
- MOV WDMSB,A ; Save the temperature (high byte)
- LCALL TRANS12
- KEND:
- SETB EA
- RET
- TRANS12:
- MOV A,30H
- ANL A,#0F0H
- MOV 3AH,A
- MOV A,31H
- ANL A,#0FH
- ORL A,3AH
- SWAP A
- MOV B,#10
- DIV AB
- ;MOV 42H,A
- MOV 43H,B ;
- MOV b,#10
- DIV ab
- MOV 42H,B
- MOV 41H,A
- RET
- ; Send a byte to the 1 wire line
- SEND_BYTE: ;
- MOV A,R0
- MOV R5,#8
- SEN3: CLR C
- RRC A
- JC SEN1
- LCALL WRITE_0
- SJMP SEN2
- SEN1: LCALL WRITE_1
- SEN2: DJNZ R5,SEN3 ;
- RET
- ; Read a byte from the 1 wire line
- READ_BYTE:
- MOV R5,#8
- READ1: LCALL READ
- RRC A
- DJNZ R5,READ1 ;
- MOV R0,A
- RET
- ; Reset 1 wire line
- RSTSNR: SETB DQ
- NOP
- NOP
- CLR DQ
- MOV R6,#250 ;
- DJNZ R6,$
- MOV R6,#50
- DJNZ R6,$
- SETB DQ ;
- MOV R6,#15
- DJNZ R6,$
- CALL CHCK ;
- MOV R6,#60
- DJNZ R6,$
- SETB DQ
- RET
- ; low level subroutines
- CHCK: MOV C,DQ
- JC RST0
- SETB F0 ;
- SJMP CHCK0
- RST0: CLR F0 ;
- CHCK0: RET
- WRITE_0:
- CLR DQ
- MOV R6,#30
- DJNZ R6,$
- SETB DQ
- RET
- WRITE_1:
- CLR DQ
- NOP
- NOP
- NOP
- NOP
- NOP
- SETB DQ
- MOV R6,#30
- DJNZ R6,$
- RET
- READ: SETB DQ ;
- NOP
- NOP
- CLR DQ
- NOP
- NOP
- SETB DQ ;
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- MOV C,DQ
- MOV R6,#23
- DJNZ R6,$
- RET
- DELAY10: MOV R4,#20
- D2: MOV R5,#30
- DJNZ R5,$
- DJNZ R4,D2
- RET
- end
