/*作者:lern01 自己總覺(jué)得程序有待優(yōu)化,且星期顯示有問(wèn)題,對(duì)7求余為0時(shí),星期不變化,請(qǐng)高手給予指點(diǎn),謝謝! **/
#include<reg51.h>
#include<intrins.h>
sbit rs=P3^5;
sbit lcden=P3^4;
sbit rw=P3^6;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit s4=P3^7; //矩陣鍵盤 公共
sbit EP = P3^4; //使能端
sbit RW = P3^6; //數(shù)據(jù)/命令選擇端
sbit RS = P3^5; //讀寫(xiě)選擇端
sbit KEY_1 = P3^0; //設(shè)置模式選擇
sbit KEY_2 = P3^1; //
static uint code table1[] = {0, 31, 59, 90, 120, 151,181, 212, 242, 273, 303, 334};
static uchar code *Week[7] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
uchar sec = 0, hour = 12, minu = 0;
uchar count = 0, week = 0; month = 1, day = 1;
void T0_Init()
ET0 = 1;
TMOD = 0x01;
TH0 = (65536 - 46071)/256;
TL0 = (65536 - 46071)%256;
TR0 = 1;
void delay(uint ms)
uint i, j;
for(i=ms; i>0; i--)
for(j=110; j>0; j--);
void Write_Cmd(uchar cmd) //寫(xiě)入命令
// Lcd_Ready();
RS = 0;
RW = 0;
EP = 0;
P0 = cmd;
delay(5);
EP = 1;
delay(5);
EP = 0;
void Write_Dat(uchar dat) //寫(xiě)入數(shù)據(jù)
// Lcd_Ready(); //LCD1602 不忙則跳出
RS = 1;
RW = 0;
EP = 0;
P0 = dat;
delay(5);
EP = 1;
delay(5);
EP = 0;
void Write_Week(uchar day, uchar month) //星期與日期同步
week = (table1[(month - 1)] + day - 1);
week = week % 7;
Write_Cmd(0x80 + 12);
while(*Week[week] != '\0')
Write_Dat(*Week[week]++);
void Write_Num(uchar x, uchar y, uchar num) //將時(shí)分秒和日期寫(xiě)入1602
uchar unit, decad;
unit = num % 10;
decad = num /10;
if(y == 1)
Write_Cmd(0x80 + 0x40 + x);
Write_Dat(0x30 + decad); //即加48,將數(shù)字轉(zhuǎn)換為ASC||字符數(shù)字
Write_Dat(0x30 + unit);
Write_Cmd(0x80 + x);
void Lcd_Init() //LCD初始化設(shè)定
Write_Cmd(0x38); // 16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
Write_Cmd(0x0c); // 顯示開(kāi),關(guān)光標(biāo)
Write_Cmd(0x06); // 讀寫(xiě)地址自動(dòng)加1,光標(biāo)加1
Write_Cmd(0x01); //清除屏幕
Write_Cmd(0x80);
void Display() //
Write_Week(day, month);
Write_Num(9, 0, day);
Write_Num(6, 0, month);
Write_Num(4, 1, hour);
Write_Num(7, 1, minu);
Write_Num(10, 1, sec);
Write_Cmd(0x80 + 0x40 + 6);
Write_Dat(':');
Write_Cmd(0x80 + 0x40 + 9);
Write_Dat(':');
void TimerCount()
if(count == 20)
count = 0;
sec++;
if(sec == 60)
sec = 0;
minu++;
if(minu == 60)
minu = 0;
hour++;
if(hour == 24)
hour = 0;
day++;
week++;
if(week == 7)
week = 0;
switch(month)
case 1:
if(day == 32)
day = 0;
month++;
break;
case 2:
if(day == 29)
day = 0;
month++;
break;
case 3:
if(day == 32)
day = 0;
month++;
break;
case 4:
if(day == 31)
day = 0;
month++;
break;
case 5:
if(day == 32)
day = 0;
month++;
break;
case 6:
if(day == 31)
day = 0;
month++;
break;
case 7:
if(day == 32)
day = 0;
month++;
break;
case 8:
if(day == 32)
day = 0;
month++;
break;
case 9:
if(day == 31)
day = 0;
month++;
break;
case 10:
if(day == 32)
day = 0;
month++;
break;
case 11:
if(day == 31)
day = 0;
month++;
break;
case 12:
if(day == 32)
day = 0;
month = 1;
break;
Display();
void KeyScan()
static uchar key1cnt = 0; //KEY_1按下的次數(shù)
if(KEY_1 == 0)
delay(10);
if(KEY_1 == 0)
key1cnt++;
while(!KEY_1);
switch(key1cnt)
case 1:
TR0 = 0;
Write_Cmd(0x80 + 0x40 + 5);
Write_Cmd(0x0F); //顯示光標(biāo)且光標(biāo)閃爍
break;
case 2:
Write_Cmd(0x80 + 0x40 + 8);
break;
case 3:
Write_Cmd(0x80 + 0x40 + 11);
break;
case 4:
Write_Cmd(0x80 + 7);
break;
case 5:
Write_Cmd(0x80 + 10);
break;
case 6:
TR0 = 1;
Write_Cmd(0x0C); //不顯示光標(biāo)
key1cnt = 0;
break;
if(key1cnt != 0)
if(KEY_2 == 0)
delay(10);
if(KEY_2 == 0)
while(!KEY_2);
switch(key1cnt)
case 1:
hour++;
if(hour == 24)
hour = 0;
break;
case 2:
minu++;
if(minu == 60)
minu = 0;
break;
case 3:
sec++;
if(sec == 60)
sec = 0;
break;
case 4:
month++;
if(month == 13)
month = 1;
break;
case 5:
day++;
if(day == 32)
day = 1;
break;
uchar i = 0;
uchar code table[] = {"2017-01-01 Sun"};
EA = 1;
Lcd_Init(); //1602初始化
T0_Init(); //定時(shí)器0初始化
Write_Cmd(0x80 + 1);
while(table[i] != '\0')
Write_Dat(table[i]);
i++;
KeyScan();
void Timer0() interrupt 1
count++;
TimerCount();
為什么要做個(gè)測(cè)試呢?我把程序改了下現(xiàn)在可以用了,星期我也沒(méi)搞明白怎樣顯示,希望高手指導(dǎo) |
