/* --- STC MCU Limited ------------------------------------------------*/
/* --- STC15F4K60S4 系列 AD轉(zhuǎn)換查詢方式舉例----------------------------*/
/* --- Mobile: (86)13922805190 ----------------------------------------*/
/* --- Fax: 86-0513-55012956,55012947,55012969 ------------------------*/
/* --- Tel: 86-0513-55012928,55012929,55012966-------------------------*/
/* 如果要在程序中使用此代碼,請(qǐng)?jiān)诔绦蛑凶⒚魇褂昧薙TC的資料及程序 */
/* 如果要在文章中應(yīng)用此代碼,請(qǐng)?jiān)谖恼轮凶⒚魇褂昧薙TC的資料及程序 */
//本示例在Keil開發(fā)環(huán)境下請(qǐng)選擇Intel的8058芯片型號(hào)進(jìn)行編譯
//若無(wú)特別說(shuō)明,工作頻率一般為11.0592MHz
#include "reg51.h"
#include "intrins.h"
#define FOSC 11059200L
#define BAUD 9600
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define URMD 0 //0:使用定時(shí)器2作為波特率發(fā)生器
//1:使用定時(shí)器1的模式0(16位自動(dòng)重載模式)作為波特率發(fā)生器
//2:使用定時(shí)器1的模式2(8位自動(dòng)重載模式)作為波特率發(fā)生器
sfr T2H = 0xd6; //定時(shí)器2高8位
sfr T2L = 0xd7; //定時(shí)器2低8位
sfr P1M1 = 0x91; //PxM1.n,PxM0.n =00--->Standard, 01--->push-pull
sfr P1M0 = 0x92; // =10--->pure input, 11--->open drain
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xB1;
sfr P3M0 = 0xB2;
sfr P4M1 = 0xB3;
sfr P4M0 = 0xB4;
sfr P5M1 = 0xC9;
sfr P5M0 = 0xCA;
sfr P6M1 = 0xCB;
sfr P6M0 = 0xCC;
sfr P7M1 = 0xE1;
sfr P7M0 = 0xE2;
sfr AUXR = 0x8e; //輔助寄存器
sfr ADC_CONTR = 0xBC; //ADC控制寄存器
sfr ADC_RES = 0xBD; //ADC高8位結(jié)果
sfr ADC_LOW2 = 0xBE; //ADC低2位結(jié)果
sfr P1ASF = 0x9D; //P1口第2功能控制寄存器
#define ADC_POWER 0x80 //ADC電源控制位
#define ADC_FLAG 0x10 //ADC完成標(biāo)志
#define ADC_START 0x08 //ADC起始控制位
#define ADC_SPEEDLL 0x00 //540個(gè)時(shí)鐘
#define ADC_SPEEDL 0x20 //360個(gè)時(shí)鐘
#define ADC_SPEEDH 0x40 //180個(gè)時(shí)鐘
#define ADC_SPEEDHH 0x60 //90個(gè)時(shí)鐘
void InitUart();
void InitADC();
void SendData(BYTE dat);
BYTE GetADCResult(BYTE ch);
void Delay(WORD n);
void ShowResult(BYTE ch);
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
P6M0 = 0x00;
P6M1 = 0x00;
P7M0 = 0x00;
P7M1 = 0x00;
InitUart(); //初始化串口
InitADC(); //初始化ADC
while (1)
ShowResult(0); //顯示通道0
ShowResult(1); //顯示通道1
ShowResult(2); //顯示通道2
ShowResult(3); //顯示通道3
ShowResult(4); //顯示通道4
ShowResult(5); //顯示通道5
ShowResult(6); //顯示通道6
ShowResult(7); //顯示通道7
發(fā)送ADC結(jié)果到PC
SendData(ch); //顯示通道號(hào)
SendData(GetADCResult(ch)); //顯示ADC高8位結(jié)果
// SendData(ADC_LOW2); //顯示低2位結(jié)果
讀取ADC結(jié)果
ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
_nop_(); //等待4個(gè)NOP
_nop_();
_nop_();
_nop_();
while (!(ADC_CONTR & ADC_FLAG));//等待ADC轉(zhuǎn)換完成
ADC_CONTR &= ~ADC_FLAG; //Close ADC
return ADC_RES; //返回ADC結(jié)果
初始化串口
void InitUart()
SCON = 0x5a; //設(shè)置串口為8位可變波特率
#if URMD == 0
T2L = 0xd8; //設(shè)置波特率重裝值
T2H = 0xff; //115200 bps(65536-18432000/4/115200)
AUXR = 0x14; //T2為1T模式, 并啟動(dòng)定時(shí)器2
AUXR |= 0x01; //選擇定時(shí)器2為串口1的波特率發(fā)生器
#elif URMD == 1
AUXR = 0x40; //定時(shí)器1為1T模式
TMOD = 0x00; //定時(shí)器1為模式0(16位自動(dòng)重載)
TL1 = 0xd8; //設(shè)置波特率重裝值
TH1 = 0xff; //115200 bps(65536-18432000/4/115200)
TR1 = 1; //定時(shí)器1開始啟動(dòng)
#else
TMOD = 0x20; //設(shè)置定時(shí)器1為8位自動(dòng)重裝載模式
TH1 = TL1 = 0xfb; //115200 bps(256 - 18432000/32/115200)
TR1 = 1;
#endif
初始化ADC
void InitADC()
P1ASF = 0xff; //設(shè)置P1口為AD口
ADC_RES = 0; //清除結(jié)果寄存器
ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
Delay(2); //ADC上電并延時(shí)
發(fā)送串口數(shù)據(jù)
while (!TI); //等待前一個(gè)數(shù)據(jù)發(fā)送完成
TI = 0; //清除發(fā)送標(biāo)志
SBUF = dat; //發(fā)送當(dāng)前數(shù)據(jù)
軟件延時(shí)
void Delay(WORD n)
WORD x;
while (n--)
x = 5000;
while (x--);
