查看: 4822|回復(fù): 0
基于1602液晶的簡易計(jì)算器
ID:164629 發(fā)表于 2017-2-19 18:19 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
#include <reg52.h>
unsigned char step = 0;  //操作步驟
unsigned char oprt = 0;  //運(yùn)算類型
signed long num1 = 0;    //操作數(shù)1
signed long num2 = 0;    //操作數(shù)2
signed long result = 0;  //運(yùn)算結(jié)果
unsigned char T0RH = 0;  //T0重載值的高字節(jié)
unsigned char T0RL = 0;  //T0重載值的低字節(jié)
void ConfigTimer0(unsigned int ms);
extern void KeyScan();
extern void KeyDriver();
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
extern void LcdAreaClear(unsigned char x, unsigned char y, unsigned char len);
extern void LcdFullClear();
    EA = 1;           //開總中斷
    ConfigTimer0(1);  //配置T0定時(shí)1ms
        InitLcd1602();    //初始化液晶
    LcdShowStr(15, 1, "0");  //初始顯示一個(gè)數(shù)字0
    while (1)
        KeyDriver();  //調(diào)用按鍵驅(qū)動(dòng)
/* 長整型數(shù)轉(zhuǎn)換為字符串,str-字符串指針,dat-待轉(zhuǎn)換數(shù),返回值-字符串長度 */
unsigned char LongToString(unsigned char *str, signed long dat)
    signed char i = 0;
    unsigned char len = 0;
    unsigned char buf[12];
    if (dat < 0)  //如果為負(fù)數(shù),首先取絕對值,并在指針上添加負(fù)號
        dat = -dat;
        *str++ = '-';
        len++;
    do {          //先轉(zhuǎn)換為低位在前的十進(jìn)制數(shù)組
        buf[i++] = dat % 10;
        dat /= 10;
    } while (dat > 0);
    len += i;     //i最后的值就是有效字符的個(gè)數(shù)
    while (i-- > 0)   //將數(shù)組值轉(zhuǎn)換為ASCII碼反向拷貝到接收指針上
        *str++ = buf[i] + '0';
    *str = '\0';  //添加字符串結(jié)束符
    return len;   //返回字符串長度
/* 顯示運(yùn)算符,顯示位置y,運(yùn)算符類型type */
void ShowOprt(unsigned char y, unsigned char type)
    switch (type)
        case 0: LcdShowStr(0, y, "+"); break;  //0代表+
        case 1: LcdShowStr(0, y, "-"); break;  //1代表-
        case 2: LcdShowStr(0, y, "*"); break;  //2代表*
        case 3: LcdShowStr(0, y, "/"); break;  //3代表/
        default: break;
/* 計(jì)算器復(fù)位,清零變量值,清除屏幕顯示 */
void Reset()
    num1 = 0;
    num2 = 0;
    step = 0;
    LcdFullClear();
/* 數(shù)字鍵動(dòng)作函數(shù),n-按鍵輸入的數(shù)值 */
void NumKeyAction(unsigned char n)
    unsigned char len;
    unsigned char str[12];
    if (step > 1)  //如計(jì)算已完成,則重新開始新的計(jì)算
        Reset();
    if (step == 0)  //輸入第一操作數(shù)
        num1 = num1*10 + n;             //輸入數(shù)值累加到原操作數(shù)上
        len = LongToString(str, num1);  //新數(shù)值轉(zhuǎn)換為字符串
        LcdShowStr(16-len, 1, str);     //顯示到液晶第二行上
    else            //輸入第二操作數(shù)
        num2 = num2*10 + n;             //輸入數(shù)值累加到原操作數(shù)上
        len = LongToString(str, num2);  //新數(shù)值轉(zhuǎn)換為字符串
/* 運(yùn)算符按鍵動(dòng)作函數(shù),運(yùn)算符類型type */
void OprtKeyAction(unsigned char type)
    unsigned char len;
    if (step == 0)  //第二操作數(shù)尚未輸入時(shí)響應(yīng),即不支持連續(xù)操作
        len = LongToString(str, num1); //第一操作數(shù)轉(zhuǎn)換為字符串
        LcdAreaClear(0, 0, 16-len);    //清除第一行左邊的字符位
        LcdShowStr(16-len, 0, str);    //字符串靠右顯示在第一行
        ShowOprt(1, type);             //在第二行顯示操作符
        LcdAreaClear(1, 1, 14);        //清除第二行中間的字符位
        LcdShowStr(15, 1, "0");        //在第二行最右端顯示0
        oprt = type;                   //記錄操作類型
        step = 1;
/* 計(jì)算結(jié)果函數(shù) */
void GetResult()
    unsigned char len;
    if (step == 1) //第二操作數(shù)已輸入時(shí)才執(zhí)行計(jì)算
        step = 2;
        switch (oprt)  //根據(jù)運(yùn)算符類型計(jì)算結(jié)果,未考慮溢出問題
            case 0: result = num1 + num2; break;
            case 1: result = num1 - num2; break;
            case 2: result = num1 * num2; break;
            case 3: result = num1 / num2; break;
            default: break;
        len = LongToString(str, num2);  //原第二操作數(shù)和運(yùn)算符顯示到第一行
        ShowOprt(0, oprt);
        LcdAreaClear(1, 0, 16-1-len);
        len = LongToString(str, result);  //計(jì)算結(jié)果和等號顯示在第二行
        LcdShowStr(0, 1, "=");
        LcdAreaClear(1, 1, 16-1-len);
/* 按鍵動(dòng)作函數(shù),根據(jù)鍵碼執(zhí)行相應(yīng)的操作,keycode-按鍵鍵碼 */
void KeyAction(unsigned char keycode)
    if  ((keycode>='0') && (keycode<='9'))  //輸入字符
        NumKeyAction(keycode - '0');
    else if (keycode == 0x26)  //向上鍵,+
        OprtKeyAction(0);
    else if (keycode == 0x28)  //向下鍵,-
        OprtKeyAction(1);
    else if (keycode == 0x25)  //向左鍵,*
        OprtKeyAction(2);
    else if (keycode == 0x27)  //向右鍵,÷
        OprtKeyAction(3);
    else if (keycode == 0x0D)  //回車鍵,計(jì)算結(jié)果
        GetResult();
    else if (keycode == 0x1B)  //Esc鍵,清除
        Reset();
/* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
    unsigned long tmp;  //臨時(shí)變量
    tmp = 11059200 / 12;      //定時(shí)器計(jì)數(shù)頻率
    tmp = (tmp * ms) / 1000;  //計(jì)算所需的計(jì)數(shù)值
    tmp = 65536 - tmp;        //計(jì)算定時(shí)器重載值
    tmp = tmp + 28;           //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
    T0RH = (unsigned char)(tmp>>8);  //定時(shí)器重載值拆分為高低字節(jié)
    T0RL = (unsigned char)tmp;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = T0RH;     //加載T0重載值
    TL0 = T0RL;
    ET0 = 1;        //使能T0中斷
    TR0 = 1;        //啟動(dòng)T0
/* T0中斷服務(wù)函數(shù),執(zhí)行按鍵掃描 */
void InterruptTimer0() interrupt 1
    TH0 = T0RH;  //重新加載重載值
    TL0 = T0RL;
    KeyScan();   //按鍵掃描
相關(guān)帖子
