一個(gè)用51單片機(jī)和ADXL345傳感器做的手勢(shì)遙控車分享給51黑電子論壇的朋友們,作者是鼎鼎大名的Chinked-out工作室.
視頻演示:
本遙控車的源程序詳細(xì)解說視頻:
手勢(shì)遙控車驅(qū)動(dòng)電路原理圖:
2017-3-24 02:52 上傳
手勢(shì)遙控車手控電路原理圖:
2017-3-24 02:53 上傳
手勢(shì)遙控車元件清單 | | | | | | | | | | | | | | | | | | | |
| SOP28轉(zhuǎn)DIP28轉(zhuǎn)接板 | |
ADXL345.c程序源碼:
- #include "STC15F2K60S2.h"
- #include "string.h"
- #include "stdio.h" //Keil library
- #include <INTRINS.H>
- sbit SCL=P1^0; //IIC時(shí)鐘引腳定義
- sbit SDA=P1^1; //IIC數(shù)據(jù)引腳定義
- unsigned char idata BUF[6]; //接收數(shù)據(jù)緩存區(qū) X軸高八位,X軸低八位; Y軸高八位,Y軸低八位; Z軸高八位,Z軸第低八位
- unsigned char idata Sbuf[32];
- signed int idata XYZ_data[3];
- void Init_ADXL345(void); //初始化ADXL345
- void Single_Write_ADXL345(unsigned char REG_Address,unsigned char REG_data); //單個(gè)寫入數(shù)據(jù)
- void Multiple_Read_ADXL345(); //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
- void Delay5us();
- void Delay5ms();
- void Delay300ms();
- void ADXL345_Start();
- void ADXL345_Stop();
- void ADXL345_SendACK(bit ack);
- bit ADXL345_RecvACK();
- void ADXL345_SendByte(unsigned char dat);
- unsigned char ADXL345_RecvByte();
- void Send();
- void UartInit();
- void Data_Process();
- bit flag;
- //******主程序********
- void main()
- Delay300ms();
- UartInit();
- Init_ADXL345(); //初始化ADXL345
- while(1) //循環(huán)
- Multiple_Read_ADXL345(); //連續(xù)讀出數(shù)據(jù),存儲(chǔ)在BUF中
- Data_Process();
- Send();
- Delay300ms();
- 起始信號(hào)
- SDA = 1; //拉高數(shù)據(jù)線
- SCL = 1; //拉高時(shí)鐘線
- Delay5us(); //延時(shí)
- SDA = 0; //產(chǎn)生下降沿
- SCL = 0; //拉低時(shí)鐘線
- 停止信號(hào)
- SDA = 0; //拉低數(shù)據(jù)線
- SDA = 1; //產(chǎn)生上升沿
- 發(fā)送應(yīng)答信號(hào)
- 入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫應(yīng)答信號(hào)
- 接收應(yīng)答信號(hào)
- flag = SDA; //讀應(yīng)答信號(hào)
- return flag;
- 向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- unsigned char i;
- for (i=0; i<8; i++) //8位計(jì)數(shù)器
- SDA=dat&0x80;
- dat <<= 1;
- ADXL345_RecvACK();
- //從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)
- unsigned char i;
- unsigned char dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- dat <<= 1;
- dat |= SDA; //讀數(shù)據(jù)
- return dat;
- //******單字節(jié)寫入*******************************************
- ADXL345_Start(); //起始信號(hào)
- ADXL345_SendByte(0xA6); //發(fā)送設(shè)備地址
- ADXL345_SendByte(REG_Address); //內(nèi)部寄存器地址
- ADXL345_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù)
- ADXL345_Stop(); //發(fā)送停止信號(hào)
- //連續(xù)讀出ADXL345內(nèi)部加速度數(shù)據(jù),地址范圍0x32~0x37
- void Multiple_read_ADXL345(void)
- unsigned char i;
- ADXL345_SendByte(0xA6); //發(fā)送設(shè)備地址+寫信號(hào)
- ADXL345_SendByte(0x32); //發(fā)送存儲(chǔ)單元地址,從0x32開始
- ADXL345_SendByte(0xA7); //發(fā)送設(shè)備地址+讀信號(hào)
- for (i=0; i<6; i++) //連續(xù)讀取6個(gè)地址數(shù)據(jù),存儲(chǔ)中BUF
- BUF[i] = ADXL345_RecvByte(); //BUF[0]存儲(chǔ)0x32地址中的數(shù)據(jù)
- if (i == 5)ADXL345_SendACK(1);//最后一個(gè)數(shù)據(jù)需要回NOACK
- else ADXL345_SendACK(0); //回應(yīng)ACK
- ADXL345_Stop(); //停止信號(hào)
- Delay5ms();
- //初始化ADXL345,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改************************
- void Init_ADXL345()
- Single_Write_ADXL345(0x2C,0x08); //速率設(shè)定為12.5
- Single_Write_ADXL345(0x2D,0x08); //選擇電源模式
- Single_Write_ADXL345(0x31,0x0B); //測(cè)量范圍,正負(fù)16g,13位模式
- void UartInit() //9600bps@11.0592MHz
- SCON = 0x50; //8位數(shù)據(jù),可變波特率
- AUXR |= 0x40; //定時(shí)器1時(shí)鐘為Fosc,即1T
- AUXR &= 0xFE; //串口1選擇定時(shí)器1為波特率發(fā)生器
- TMOD &= 0x0F; //設(shè)定定時(shí)器1為16位自動(dòng)重裝方式
- TL1 = 0xE0; //設(shè)定定時(shí)初值
- TH1 = 0xFE; //設(shè)定定時(shí)初值
- ET1 = 0; //禁止定時(shí)器1中斷
- TR1 = 1; //啟動(dòng)定時(shí)器1
- void Send()
- unsigned char i,j;
- j=strlen(Sbuf);
- for(i=0;i<j;i++)
- SBUF=Sbuf[i];
- while(!TI);
- TI=0;
- XYZ_data[0]=BUF[1]<<8|BUF[0];
- XYZ_data[1]=BUF[3]<<8|BUF[2];
- XYZ_data[2]=BUF[5]<<8|BUF[4];
- sprintf(Sbuf,"X=%d,Y=%d,Z=%d\n",XYZ_data[0],XYZ_data[1],XYZ_data[2]);
- void Delay300ms() //@11.0592MHz
- unsigned char i, j, k;
- _nop_();
- _nop_();
- i = 13;
- j = 156;
- k = 83;
- do
- do
- while (--k);
- } while (--j);
- } while (--i);
- void Delay5us() //@11.0592MHz
- unsigned char i;
- _nop_();
- i = 11;
- while (--i);
- void Delay5ms() //@11.0592MHz
- unsigned char i, j;
- i = 54;
- j = 199;
- do
- while (--j);
- } while (--i);
接受程序:- #include "STC15F2K60S2.h"
- #define Go 0xAA //小車實(shí)際動(dòng)作控制字符,以實(shí)物為準(zhǔn)
- #define Back 0x55
- #define Left 0x5A
- #define Right 0xA5
- #define Stop 0x00
- void UartInit();
- unsigned char Rec_Data=0;
- void main()
- UartInit();
- while(1)
- if(Rec_Data==Go||Rec_Data==Back||Rec_Data==Left||Rec_Data==Right||Rec_Data==Stop)
- P1=Rec_Data;
- else P1=Stop;
- EA=1; //開總中斷
- ES=1; //開串口中斷
- void uart_receive(void) interrupt 4
- if(RI)
- …………余下代碼請(qǐng)下載附件…………
源代碼說明:由于使用的是STC15系列單片機(jī),所以需要包含STC15F系列的頭文件,之前沒有上傳,現(xiàn)在給不上了,或自行到STC官方網(wǎng)學(xué)習(xí)添加方法。
原理圖說明:原理圖分為小車驅(qū)動(dòng)電路和手勢(shì)控制電路。小車驅(qū)動(dòng)電路和手勢(shì)控制電路的藍(lán)牙母座連線有所不同,請(qǐng)注意區(qū)分。驅(qū)動(dòng)電路中SET腳和3V3腳是短接的,而手控部分無需短接。
L293D的輸入端和單片機(jī)P1端口相連,
當(dāng)P1輸出字符“AA”時(shí),電機(jī)M1、M2、M3、M4全部正轉(zhuǎn),小車前進(jìn)
當(dāng)P1輸出字符“55”時(shí),電機(jī)M1、M2、M3、M4全部反轉(zhuǎn),小車后退
當(dāng)P1輸出字符“5A”時(shí),電機(jī)M1、M2反轉(zhuǎn),M3、M4正轉(zhuǎn),小車向左轉(zhuǎn)
當(dāng)P1輸出字符“A5”時(shí),電機(jī)M1、M2正轉(zhuǎn),M3、M4反轉(zhuǎn),小車向右轉(zhuǎn)
當(dāng)P1輸出字符“00”時(shí),電機(jī)M1、M2、M3、M4兩端無電壓,小車不動(dòng)
工作室交流討論群:231931086
2017-3-24 02:54 上傳
下載:
手勢(shì)遙控車資料包.zip
(241.71 KB, 下載次數(shù): 154)
2017-3-24 02:58 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
