The BLINKY program is a very simple program that blinks the LED's on
connected to Port 5 of the MCB950. When you can successfully build
and run this program, you have used the entire toolset including:
The uVision integrated development environment.
The C51 compiler, linker and the uVision simulator/debugger.
This BLINKY program is available in several targets:
Simulator: for uVision Debugger testing with simulator
ULINK2 NXP 95x: for Debugging with Keil ULINK2 JTAG adapter
FS2 System Navigtor: for Debugging with the FS2 System Navigator
Use the following jumper settings on the MCB900 board:
RUN: OFF RESET: ON for Download with Flash Magic
RUN: ON RESET: OFF for Program Run
2017-3-24 19:54 上傳
2017-3-24 19:55 上傳
Blinky.zip
2017-3-24 10:52 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
25.63 KB, 下載次數(shù): 6, 下載積分: 黑幣 -5
