查看: 3897|回復(fù): 3
51單片機用IIC通訊讀AM2320溫濕度數(shù)據(jù),并顯示在LCD1602上 讀不到數(shù)據(jù)
ID:174305 發(fā)表于 2017-4-19 14:41 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
小弟新手,做了個溫濕度檢測,但是一直讀不到AM2320的數(shù)據(jù),求大神解惑;
另:AM2320的sda和scl兩根引腳要求接4.7千歐電阻,小弟沒有,給接了1千歐的;
下面是小弟寫的代碼;
#include<reg52.h>
sbit RS=P2^3;//LCD 三個引腳
sbit RW=P2^5;
sbit E=P2^7;//。
sbit scl=P2^0; //IIC 總線引腳
sbit sda=P2^1;  //  .
uchar code table[]="Tem:     Hum:  ";
uchar code table1[]="     *c        %";
uchar wenh,wenl,shih,shil;
char *p;// 保存2320數(shù)據(jù)的變量
int newnum(char ha,char lb)  //兩個字節(jié)合并
  int c;
  c=(ha<<8)+lb;
  return c;
void delay0()
void delay(uint xms)
  uint i,j;
for(i=xms;i>0;i--)
  for(j=110;j>0;j--);
void write_com(comm)  //LCD 寫命令函數(shù)
   RS=0;
  RW=0;
  E=0;
  P1=comm;
  delay(5);
  E=1;
  delay(5);
  E=0;
void write_date(datee) //LCD寫數(shù)據(jù)函數(shù)
   RS=1;
  RW=0;
  E=0;
  P1=datee;
  delay(5);
  E=1;
  delay(5);
  E=0;
void display(int num,uchar w)//LCD 顯示溫度 濕度數(shù)字
   uchar shi,ge,fushi;
  shi=num/100;
  ge=(num%100)/10;
  fushi=num%10;
  write_com(0x80+0x40+w);
  delay(5);
  write_date(0x30+shi);
  delay(5);
  write_date(0x30+ge);
  delay(5);
  write_date(0x2e);
  delay(5);
  write_date(0x30+fushi);
void init()  //初始化
uint a;             //LCD 初始化
  write_com(0x38);
delay(5);
write_com(0x0c);
delay(5);
write_com(0x06);
delay(5);
write_com(0x01);
delay(5);
write_com(0x80);
for(a=0;a<16;a++)
      write_date(table[a]);
    delay(5);
  write_com(0x80+0x40);
  for(a=0;a<16;a++)
      write_date(table1[a]);
    delay(5);
  scl=1;  //IIC初始化
  sda=1;
  delay0();  //.
void star()   //IIC 開始函數(shù)
   sda=1;
  delay0();
  scl=1;
  sda=0;
  delay0();
  scl=0;
void stop()  //IIC 停止函數(shù)
   sda=0;
  delay0();
  scl=1;
  delay0();
  sda=1;
void write_ack(uchar acknum)  //IIC 主機讀取數(shù)據(jù)后發(fā)送應(yīng)答0或1
   scl=0;
  delay0();
  sda=acknum;
  scl=1;
  delay0();
  scl=0;
  delay0();
   sda=1;
void read_ack()    //IIC  主機發(fā)送數(shù)據(jù)后讀取從機應(yīng)答
uchar b;
  scl=0;
  delay0();
  sda=1;
delay0();
scl=1;
while((sda==1)&&b<255)
  b++;
void write_byte(uchar dat) //IIC  寫一個字節(jié)
  uchar temp,i;
temp=dat;
for(i=0;i<8;i++)
      scl=0;
    delay0();
    temp=temp<<1;
    sda=CY;
    delay0();
    scl=1;
    delay0();
  scl=0;
  delay0();
  sda=1;
  delay0();
uchar read_byte()  //IIC 讀一個字節(jié)
  uchar i,a;
  scl=0;
  delay0();
sda=1;
for(i=0;i<8;i++)
     scl=1;
     delay0();
     a=(a<<1)|sda;
     delay0();
     scl=0;
     delay0();
  delay0();
  return a;
void write_add(uchar add)  //寫2320 讀命令
   star();
  write_byte(add);
  read_ack();
  write_byte(0x03);
  read_ack();
  write_byte(0x00);
  read_ack();
  write_byte(0x04);
  read_ack();
  stop();
void read_add(uchar add)//  讀2320數(shù)據(jù)
uchar i;
  write_byte((add)|0x01);
read_ack();
delay(1);
for(i=0;i>8;i++)
    *(p+i)=read_byte();
  write_ack(0);
write_ack(1);
stop();
void hxing2320()  //喚醒2320
star();
  write_byte(0xB8);
read_ack();
delay(15);
stop();
void AM2320()//  使用2320
int wen,shi;
  hxing2320();
delay0();
write_add(0xB8);
delay(20);
read_add(0xB8);
wen=newnum(*(p+2),*(p+3));
shi=newnum(*(p+4),*(p+5));
display(wen,1);
display(shi,10);
/*unsigned short crc16(unsigned char *ptr, unsigned char len)  //計算*ptr內(nèi)前l(fā)en個字節(jié)的CRC碼
unsigned short crc=0xFFFF;
unsigned char i;
while(len--)
    crc ^=*ptr++;
    for(i=0;i<8;i++)
      if(crc & 0x01)
          crc>>=1;
          crc^=0xA001;
        }else
            crc>>=1;
return crc;
void main()    //主函數(shù)
  init();
   AM2320();
相關(guān)帖子
ID:174305 發(fā)表于 2017-4-19 15:04 | 只看該作者
自頂,要被淹了嗎?
ID:174305 發(fā)表于 2017-4-19 14:46 | 只看該作者
大神在哪里?
ID:174305 發(fā)表于 2017-4-19 14:42 | 只看該作者
求大神?
