查看: 8204|回復(fù): 6
請(qǐng)教大神:GY-VL53L0X激光模塊ARDUINO源碼串口輸出數(shù)據(jù)的意義?
18黑幣
GY-VL53L0X激光模塊
在串口輸出一下數(shù)據(jù):
----- START TEST ----
Revision ID: 16
Device ID: 238
PRE_RANGE_CONFIG_VCSEL_PERIOD=7
decode: 16
FINAL_RANGE_CONFIG_VCSEL_PERIOD=5
decode: 12
ready
ambient count: 30
signal count: 569
distance 1800
status: 11
----- END TEST ----
其中distance 指的應(yīng)該是距離,請(qǐng)教各位大神:其它量“ambient coun”、“signal count”、“status”、” decode“指的是什么?
附Arduino源碼:
//the original code by Ted Meyers
//posted here: https://groups.google.com/d/msg/ ... ZYuJOg/ICPrYNJGBgAJ
#include <Wire.h>
#define VL53L0X_REG_IDENTIFICATION_MODEL_ID         0xc0
#define VL53L0X_REG_IDENTIFICATION_REVISION_ID      0xc2
#define VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD   0x50
#define VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD 0x70
#define VL53L0X_REG_SYSRANGE_START                  0x00
#define VL53L0X_REG_RESULT_INTERRUPT_STATUS         0x13
#define VL53L0X_REG_RESULT_RANGE_STATUS             0x14
#define address 0x29
byte gbuf[16];
void setup() {
  // put your setup code here, to run once:
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Serial.println("VLX53LOX test started.");
void loop() {
  Serial.println("----- START TEST ----");
  test();
  Serial.println("----- END TEST ----");
  Serial.println("");
  delay(1000);
void test() {
  byte val1 = read_byte_data_at(VL53L0X_REG_IDENTIFICATION_REVISION_ID);
  Serial.print("Revision ID: "); Serial.println(val1);
  val1 = read_byte_data_at(VL53L0X_REG_IDENTIFICATION_MODEL_ID);
  Serial.print("Device ID: "); Serial.println(val1);
  val1 = read_byte_data_at(VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD);
  Serial.print("PRE_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
  Serial.print(" decode: "); Serial.println(VL53L0X_decode_vcsel_period(val1));
  val1 = read_byte_data_at(VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD);
  Serial.print("FINAL_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
  write_byte_data_at(VL53L0X_REG_SYSRANGE_START, 0x01);
  byte val = 0;
  int cnt = 0;
  while (cnt < 100) { // 1 second waiting time max
    delay(10);
    val = read_byte_data_at(VL53L0X_REG_RESULT_RANGE_STATUS);
    if (val & 0x01) break;
    cnt++;
  if (val & 0x01) Serial.println("ready"); else Serial.println("not ready");
  read_block_data_at(0x14, 12);
  uint16_t acnt = makeuint16(gbuf[7], gbuf[6]);
  uint16_t scnt = makeuint16(gbuf[9], gbuf[8]);
  uint16_t dist = makeuint16(gbuf[11], gbuf[10]);
  byte DeviceRangeStatusInternal = ((gbuf[0] & 0x78) >> 3);
  Serial.print("ambient count: "); Serial.println(acnt);
  Serial.print("signal count: ");  Serial.println(scnt);
  Serial.print("distance ");       Serial.println(dist);
  Serial.print("status: ");        Serial.println(DeviceRangeStatusInternal);
uint16_t bswap(byte b[]) {
  // Big Endian unsigned short to little endian unsigned short
  uint16_t val = ((b[0] << 8) & b[1]);
  return val;
uint16_t makeuint16(int lsb, int msb) {
    return ((msb & 0xFF) << 8) | (lsb & 0xFF);
void write_byte_data(byte data) {
  Wire.beginTransmission(address);
  Wire.write(data);
  Wire.endTransmission();
void write_byte_data_at(byte reg, byte data) {
  // write data word at address and register
  Wire.write(reg);
  Wire.write(data);
void write_word_data_at(byte reg, uint16_t data) {
  byte b0 = (data &0xFF);
  byte b1 = ((data >> 8) && 0xFF);
  Wire.write(reg);
  Wire.write(b0);
  Wire.write(b1);
byte read_byte_data() {
  Wire.requestFrom(address, 1);
  while (Wire.available() < 1) delay(1);
  byte b = Wire.read();
  return b;
byte read_byte_data_at(byte reg) {
  //write_byte_data((byte)0x00);
  write_byte_data(reg);
  return b;
uint16_t read_word_data_at(byte reg) {
  Wire.requestFrom(address, 2);
  while (Wire.available() < 2) delay(1);
  gbuf[0] = Wire.read();
  gbuf[1] = Wire.read();
  return bswap(gbuf);
void read_block_data_at(byte reg, int sz) {
  int i = 0;
  Wire.requestFrom(address, sz);
  for (i=0; i<sz; i++) {
    gbuf = Wire.read();
uint16_t VL53L0X_decode_vcsel_period(short vcsel_period_reg) {
  // Converts the encoded VCSEL period register value into the real
  // period in PLL clocks
  uint16_t vcsel_period_pclks = (vcsel_period_reg + 1) << 1;
  return vcsel_period_pclks;
相關(guān)帖子
ID:212906 發(fā)表于 2017-6-21 17:26 | 只看該作者
請(qǐng)問(wèn),你的問(wèn)題得到解決了么?最近也在搞這個(gè),現(xiàn)在我測(cè)得的距離不太對(duì),distance在距離近時(shí)直接變成20,status也在11和8之間跳。。。。。沒(méi)法用啊
ID:218037 發(fā)表于 2017-7-8 09:20 | 只看該作者
會(huì)灰的魚 發(fā)表于 2017-6-21 17:26
請(qǐng)問(wèn),你的問(wèn)題得到解決了么?最近也在搞這個(gè),現(xiàn)在我測(cè)得的距離不太對(duì),distance在距離近時(shí)直接變成20,st ...
您好,我想請(qǐng)教一下,這款傳感器的x和G接口需要接嗎   還有是直接用帶的針插進(jìn)去就可以了么
ID:237173 發(fā)表于 2017-10-7 16:44 | 只看該作者
您好,我也想問(wèn)一些,這些引腳是怎么連的。我的串口輸出不了這些數(shù)據(jù)
ID:246093 發(fā)表于 2017-11-6 20:48 | 只看該作者
兄弟,你會(huì)濾波嗎  QQ390643675
留下你的聯(lián)系方式行嗎
ID:288954 發(fā)表于 2018-3-7 22:29 | 只看該作者
是這款模塊嗎?注意PS這個(gè)針腳,接地是IIC模式,不接地是串口模式!
ID:137100 發(fā)表于 2018-4-11 17:40 | 只看該作者
請(qǐng)問(wèn)是怎么接線呢
