查看: 4183|回復(fù): 1
001.C(12): warning C206: 'WriteCom': missing function-prototype
ID:190848 發(fā)表于 2017-4-20 21:35 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
extern uchar disp_value[5];
extern uchar key_number;
extern uchar code  DC_disp3[];
uchar code AC_disp[]="AC VOL Measure ";
uchar code AC_disp2[]="value=        ";
void AC_VOL_measure(void)                                //交流電壓測(cè)量函數(shù)
                uchar  ADTemp,num;
                float ValueTemp;
                WriteCom(0x01);                                                        //清屏
               WriteCom(0x80);                                                    //顯示
                for(num=0;AC_disp[num]!='\0';num++)
                        WriteData(AC_disp[num]);
                        Delay(10);
                WriteCom(0x80+0x40);                                   //顯示
                for(num=0;AC_disp2[num]!='\0';num++)
                        WriteData(AC_disp2[num]);
                        Delay(10);
                do{
                             s1=0;                                         //選擇200v最高檔
                            s2=0;
                            s3=1;
                                Delay(50);
                ADTemp=ADSample(AC_VOL_adder);
                if(ADTemp>253)                                          //當(dāng)超過(guò)量程時(shí),顯示為1
                {         WriteCom(0x80+0x46);                                //顯示
                        for(num=0;DC_disp3[num]!='\0';num++)
                                WriteData(DC_disp3[num]);
                                         Delay(10);
                        ValueTemp=ValueConver(ADTemp);         //測(cè)量的電壓值轉(zhuǎn)換
                    ValueTemp=ValueTemp*100;                 //電壓值乘以檔位
                                FloatToChar(ValueTemp);                 //電壓值轉(zhuǎn)換為字符串
                           WriteCom(0x80+0x46);                        //第二行顯示電壓值
                                for(num=0;num<6;num++)
                                        WriteData(disp_value[num]);
                                        Delay(10);
                         WriteData('V');
                        WriteData(' ');
                }  while((ADTemp>20)&&(key_number==2));
                 do
                            s1=0;                                                   //選擇20v檔
                            s2=1;
                            s3=0;
                                Delay(50);
                ADTemp=ADSample(AC_VOL_adder);             //起動(dòng)AD進(jìn)行采樣
                ValueTemp=ValueConver(ADTemp);                 //AD進(jìn)行轉(zhuǎn)換
                ValueTemp=ValueTemp*10;                                 //電壓乘以檔位
                FloatToChar(ValueTemp);                                 //電壓轉(zhuǎn)換為字符串
             WriteCom(0x80+0x46);                                 //第二行顯示所測(cè)電壓值
                for(num=0;num<5;num++)
                                 Delay(10);
                WriteData('V');
                WriteData(' ');
            } while((ADTemp>24)&&(ADTemp<253)&&(key_number==2));
do
                            s1=1;                                                //選擇2V檔
                            s2=0;
                            s3=0;
                                Delay(50);
                ValueTemp=ValueConver(ADTemp);                 //電壓值轉(zhuǎn)換為字符串
                        Delay(15);
                WriteData('V');
                WriteData(' ');
         } while((ADTemp<253)&&(key_number==2));
001.C(12): error C267: 'WriteCom': requires ANSI-style prototype
這是怎麼回事,求改進(jìn)
ID:159015 發(fā)表于 2017-4-21 08:57 | 顯示全部樓層
完整的程序呢?WriteCom的函數(shù)呢?
