查看: 5332|回復(fù): 7
基于MODBUS協(xié)議的單片機(jī)主程序 測試通過
ID:193861 發(fā)表于 2017-4-26 15:46 | 顯示全部樓層 |閱讀模式
基于MODBUS協(xié)議的單片機(jī)主程序,測試已通過
單片機(jī)源程序:
  1. #include"reg51.h"
  2. #include"lcd.h"
  3. #include"address.h"
  4. #include"intrins.h"
  5. #include"crc.h"
  6. #define uint unsigned int
  7. #define uchar unsigned char
  8. uchar code sendbuf[]={0x01,0x03,0x00,0x0b,0x00,0x01,0xf5,0xc8};
  9. //0x01 從站地址,0x03功能碼,0x00寄存器地址高位,0x09寄存器地址低位,0x00數(shù)據(jù)個數(shù)高位,0x01數(shù)據(jù)個數(shù)低位,0x54CRC校驗碼高位,0x08CRC校驗碼低位
  10. uchar code tab[]={'0','1','2','3','4','5','6','7','8','9'};
  11. uchar code error[]={"error!"};
  12. uchar tem[5],tem1[8];
  13. uchar resvbuf[7];
  14. int i,j;
  15. uchar resvend,temp2;
  16. uint crctemp,temp,temp1;
  17. void convert10(uint dat)
  18. {
  19.   uchar i;
  20.   tem1[0]='U';
  21.   tem1[1]='=';
  22.   tem1[7]='V';
  23.   tem[0]=dat/10000;
  24.   dat=dat%10000;
  25.   tem[1]=dat/1000;
  26.   dat=dat%1000;
  27.   tem[2]=dat/100;
  28.   dat=dat%100;
  29.   tem[3]=dat/10;
  30.   tem[4]=dat%10;
  31.   for (i=0;i<5;i++)
  32.   {
  33.     tem1[i+2]=tab[tem[i]];
  34.   }
  35. }
  36. void serial_int() interrupt 4         using 1
  37. {
  38. if(RI)
  39. {
  40.    RI=0;
  41.    //temp2=SBUF;
  42.     resvbuf[j++]=SBUF;
  43.    if(j==7)
  44.    {
  45.      j=0;
  46.          resvend=1;
  47.    }
  48. }
  49. }
  50. void initserial        ()
  51. {
  52. resvend=0;
  53. TMOD=0x20;
  54. PCON=0x00;
  55. SCON=0xd8;
  56. TL1=0xfd;
  57. TH1=0xfd;
  58. TR1=1;
  59. ES=1;
  60. }
  61. void displayout()
  62. {
  63.    crctemp=crccheck(resvbuf,5);
  64.    temp=resvbuf[5];
  65.    temp=temp << 8 | resvbuf[6];
  66.    if(temp==crctemp)
  67.    {
  68.         temp1=0;
  69.             temp1 |=resvbuf[3];
  70.                 temp1= temp1<<8 | resvbuf[4];
  71.                 convert10(temp1);
  72.                 printf(tem1,8);
  73.     }
  74.   else
  75.    {
  76.       printf(error,16);
  77.    }
  78. }
  79. void delay_10us(uchar n)
  80. {
  81.    do
  82.    {
  83.      _nop_();
  84.      _nop_();
  85.      _nop_();
  86.      _nop_();
  87.      _nop_();
  88.    }while(--n);
  89. }
  90. void delay_ms(uint n)
  91. {
  92.   do
  93.   {
  94.     delay_10us(131);
  95.    }while(--n);
  96. }
  97. void main()
  98. {
  99. initlcd();
  100. initserial();
  101. EA=1;
  102. while(1)
  103. {
  104.   i=0;
  105. …………限于本文篇幅 余下代碼請從51黑下載附件…………
下載:
modbus主機(jī)單片機(jī)程序.rar (35.81 KB, 下載次數(shù): 136)
相關(guān)帖子
ID:93224 發(fā)表于 2017-6-17 00:25 | 顯示全部樓層
實物測試通過了嗎
ID:337808 發(fā)表于 2021-1-17 17:39 | 顯示全部樓層
簡單,明了,可惜的是各種判斷都省略了,如果用在嚴(yán)謹(jǐn)?shù)牡膱龊,顯然是不適用的。
ID:385637 發(fā)表于 2021-1-18 08:39 | 顯示全部樓層
用在嚴(yán)謹(jǐn)場合不形,MODBUS最基本的一串?dāng)?shù)據(jù)接收完成的時間間隔判斷都沒有
ID:929006 發(fā)表于 2021-7-25 13:55 | 顯示全部樓層
大鍋,拷貝你得程序,LCD根本不顯示
ID:929006 發(fā)表于 2021-7-25 20:37 | 顯示全部樓層
為么我的程序,LCD不顯示
#include"reg51.h"
#include"address.h"
#include"intrins.h"
#include"crc.h"
#define LCD1602_DB  P0
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E  = P1^5;
void InitLcd1602();
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
uchar code sendbuf[]={0x01,0x03,0x02,0x00,0x00,0x03,0x04,0x73};
//0x01 從站地址,0x03功能碼,0x20寄存器地址高位,0x00寄存器地址低位,0x00數(shù)據(jù)個數(shù)高位,0x03數(shù)據(jù)個數(shù)低位,0x04CRC校驗碼高位,0x73CRC校驗碼低位
uchar resvbuf[10];
int i,j;
  uchar i;
  tem1[0]='U';
  tem1[1]='=';
  tem1[7]='V';
  tem[0]=dat/10000;
  dat=dat%10000;
  tem[1]=dat/1000;
  dat=dat%1000;
  tem[2]=dat/100;
  dat=dat%100;
  tem[3]=dat/10;
  tem[4]=dat%10;
  for (i=0;i<5;i++)
if(RI)
   RI=0;
   //temp2=SBUF;
    resvbuf[j++]=SBUF;
   if(j==7)
     j=0;
         resvend=1;
void initserial        ()
resvend=0;
TMOD=0x20;
PCON=0x00;
SCON=0xd8;
TL1=0xfd;
TH1=0xfd;
TR1=1;
ES=1;
void displayout()
   crctemp=crccheck(resvbuf,9);
   temp=resvbuf[9];
   temp=temp << 8 | resvbuf[10];
   if(temp==crctemp)
        temp1=0;
            temp1 |=resvbuf[3];
                convert10(temp1);
                LcdShowStr(0, 1, tem1);
                //printf(tem1,8);
                LcdShowStr(0, 1,error );
      //printf(error,16);
   do
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     _nop_();
   }while(--n);
  do
    delay_10us(131);
   }while(--n);
/* 等待液晶準(zhǔn)備好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //讀取狀態(tài)字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重復(fù)檢測直到其等于0為止
/* 向LCD1602液晶寫入一字節(jié)命令,cmd-待寫入命令值 */
void LcdWriteCmd(unsigned char cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 向LCD1602液晶寫入一字節(jié)數(shù)據(jù),dat-待寫入數(shù)據(jù)值 */
void LcdWriteDat(unsigned char dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 設(shè)置顯示RAM起始地址,亦即光標(biāo)位置,(x,y)-對應(yīng)屏幕上的字符坐標(biāo) */
void LcdSetCursor(unsigned char x, unsigned char y)
    unsigned char addr;
    if (y == 0)  //由輸入的屏幕坐標(biāo)計算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LcdWriteCmd(addr | 0x80);  //設(shè)置RAM地址
/* 在液晶上顯示字符串,(x,y)-對應(yīng)屏幕上的起始坐標(biāo),str-字符串指針 */
    LcdSetCursor(x, y);   //設(shè)置起始地址
    while (*str != '\0')  //連續(xù)寫入字符串?dāng)?shù)據(jù),直到檢測到結(jié)束符
        LcdWriteDat(*str++);  //先取str指向的數(shù)據(jù),然后str自加1
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2顯示,5*7點陣,8位數(shù)據(jù)接口
    LcdWriteCmd(0x0C);  //顯示器開,光標(biāo)關(guān)閉
    LcdWriteCmd(0x06);  //文字不動,地址自動+1
    LcdWriteCmd(0x01);  //清屏
InitLcd1602();
initserial();
EA=1;
  i=0;
  while(i<8)
   SBUF=sendbuf[i];
   while(!TI);
   delay_10us(50);
   TI=0;
   i++;
delay_ms(1000);
if(resvend)
    resvend=0;
        displayout();
ID:929006 發(fā)表于 2021-7-26 12:30 | 顯示全部樓層
上面程序有點錯誤,改了一下。還是不顯示
#include"reg51.h"
#include"intrins.h"
#include"crc.h"
void InitLcd1602();
uchar tem[5],tem1[9];
uchar resvbuf[11];
int i,j;
  uchar i;
  tem1[0]='U';
  tem1[1]='=';
  tem1[7]='V';
  tem1[8]='\0';
  tem[0]=dat/10000;
  dat=dat%10000;
  tem[1]=dat/1000;
  dat=dat%1000;
  tem[2]=dat/100;
  dat=dat%100;
  tem[3]=dat/10;
  tem[4]=dat%10;
  for (i=0;i<5;i++)
if(RI)
   RI=0;
   //temp2=SBUF;
    resvbuf[j++]=SBUF;
   if(j==11)
     j=0;
         resvend=1;
void initserial        ()
resvend=0;
TMOD=0x20;
PCON=0x00;
SCON=0xd8;
TL1=0xfd;
TH1=0xfd;
TR1=1;
ES=1;
void displayout()
   temp=resvbuf[9];
   if(temp==crctemp)
        temp1=0;
            temp1 |=resvbuf[3];
                convert10(temp1);
                //printf(tem1,8);
                LcdShowStr(0,1,error);
      //printf(error,16);
   do
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     _nop_();
   }while(--n);
  do
    delay_10us(131);
   }while(--n);
/* 等待液晶準(zhǔn)備好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        LCD1602_E = 0;
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
    unsigned char addr;
/* 初始化1602液晶 */
void InitLcd1602()
InitLcd1602();
initserial();
EA=1;
  i=0;
  while(i<8)
   SBUF=sendbuf[i];
   while(!TI);
   delay_10us(50);
   TI=0;
   i++;
delay_ms(1000);
if(resvend)
    resvend=0;
        displayout();
ID:768666 發(fā)表于 2021-8-6 21:59 | 顯示全部樓層
不知道這個程序能不能用,學(xué)飛一下
