這其中包括1602驅(qū)動(dòng)頭文件,和解析主程序,使用時(shí)分開(kāi)粘貼到對(duì)應(yīng)的 文件中
/* LCD1602驅(qū)動(dòng),兼容LCD2402 */
sbit LCD_DB0= P0^0;
sbit LCD_DB1= P0^1;
sbit LCD_DB2= P0^2;
sbit LCD_DB3= P0^3;
sbit LCD_DB4= P0^4;
sbit LCD_DB5= P0^5;
sbit LCD_DB6= P0^6;
sbit LCD_DB7= P0^7;
sbit LCD1602_RS=P2^4;
sbit LCD1602_RW=P2^5;
sbit LCD1602_EN=P2^6;
void LCD_write_char( unsigned char x,unsigned char y,unsigned char dat); //在指定位置顯示字符
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);//在指定位置顯示字符串
void LCD_cls(void);//清屏
void LCD_en_command(unsigned char command);
void LCD_en_dat(unsigned char temp);
void LCD_set_xy( unsigned char x, unsigned char y );
void LCD_init(unsigned char bw);
void SET_LCD(unsigned char IO_temp);
void delayms(unsigned char ms);
void lcddelay(void);
unsigned char LCDIO;
unsigned char BitWidth;
void LCD_cls(void)
LCD_en_command(0x01); //0x01 清屏
delayms(2);
LCD1602_RS=0;
LCD1602_RW=0;
LCD1602_EN=0;
switch(BitWidth)
case 4: LCDIO=(command & 0xf0); //取高4位
break;
case 8: LCDIO=command;
break;
SET_LCD(LCDIO);
LCD1602_EN=1;
lcddelay();
LCD1602_EN=0;
if (BitWidth==4)
LCDIO=(command & 0x0f)<<4; //取低4位
SET_LCD(LCDIO);
LCD1602_EN=1;
lcddelay();
LCD1602_EN=0;
{ //高4位
LCD_DB7=IO_temp&0x80;
LCD_DB6=IO_temp&0x40;
LCD_DB5=IO_temp&0x20;
LCD_DB4=IO_temp&0x10; //低4位
if (BitWidth==8)
LCD_DB3=IO_temp&0x08;
LCD_DB2=IO_temp&0x04;
LCD_DB1=IO_temp&0x02;
LCD_DB0=IO_temp&0x01;
void LCD_en_dat(unsigned char dat)
LCD1602_RS=1;
LCD1602_RW=0;
LCD1602_EN=0;
switch(BitWidth)
case 4: LCDIO=(dat & 0xf0); //取高4位
break;
case 8: LCDIO=dat;
break;
SET_LCD(LCDIO);
LCD1602_EN=1;
lcddelay();
LCD1602_EN=0;
if (BitWidth==4)
LCDIO=(dat & 0x0f)<<4; //取低4位
SET_LCD(LCDIO);
LCD1602_EN=1;
lcddelay();
LCD1602_EN=0;
*1602
* 輸入?yún)?shù):x、y : 顯示字符串的坐標(biāo),X:0-15,Y:0-1
*LCD第一行顯示寄存器地址:0X80-0X8F
*LCD第二行顯示寄存器地址:0XC0-0XCF
*2404 *LCD第1行顯示地址:1~20(0x80~0x93)
*LCD第2行顯示地址:1~20(0xc0~0xd3)
*LCD第3行顯示地址:1~20(0x94~0xa7)
*LCD第4行顯示地址:1~20(0xd4~0xe7)
unsigned char address;
if (y ==0)
address = 0x80 + x;
if(y==1)
address = 0xC0 + x;
if(y==2)
address = 0x94 + x;
if(y==3)
address = 0xD4 + x;
LCD_en_command(address);
void LCD_write_char( unsigned x,unsigned char y,unsigned char dat)
LCD_set_xy( x, y );
LCD_en_dat(dat);
LCD_set_xy( X, Y ); //set address
while (*s) // write character
LCDIO=*s;
SET_LCD(LCDIO);
LCD_en_dat(*s);
s ++;
BitWidth=bw;
switch(BitWidth)
case 4: LCD_en_command(0x33); //
delayms(20);
LCD_en_command(0x32); //
delayms(20);
break;
case 8: LCD_en_command(0x38); //
delayms(20);
delayms(20);
break;
LCD_en_command(0x08); //0x08 令顯示器off
delayms(5);
LCD_en_command(0x01); //0x01 清屏 清屏指令
delayms(5);
LCD_en_command(0x06); //0x06 光標(biāo)模式設(shè)置 進(jìn)入模式設(shè)置指令 寫入數(shù)據(jù)后光標(biāo)右移
delayms(5);
LCD_en_command(0x0c); //0x0c 顯示開(kāi) 令光標(biāo),0x0c=不顯示,0x0d=顯示閃動(dòng)
delayms(5);
unsigned char i;
while(ms--)
for(i = 0; i < 115; i++);
void lcddelay(void)
unsigned char i;
for(i = 0; i < 2; i++);
GPS解碼顯示程序,
#include<reg52.h>
#include "1602.h" //
#include"math.h" //
#include <stdlib.h>
sbit GPS_SPD=P3^2; //GPS模塊速率設(shè)置
sbit KEY1=P3^3; //顯示內(nèi)容分屏切換,(T0,T1引腳 的第二功能為計(jì)數(shù)器。)
char code TIME_AREA= 8; //時(shí)區(qū)
這是做的部分更改
unsigned long maxspeed,b;
unsigned int count=0;
unsigned int a[5];
unsigned char hspeed[5];
unsigned int dot_count; //小數(shù)點(diǎn)計(jì)數(shù)器
unsigned char x;
//GPS數(shù)據(jù)存儲(chǔ)數(shù)組
unsigned char JD[10]; //經(jīng)度
unsigned char JD_a; //經(jīng)度方向
unsigned char WD[9]; //緯度
unsigned char WD_a; //緯度方向
unsigned char date[6]; //日期
unsigned char time[6]; //時(shí)間
unsigned char speed[5]={'0','0','0','.','0'}; //速度
unsigned char high[6]; //高度
unsigned char angle[5]={'0','0','0','0','0'}; //方位角
unsigned char use_sat[2]; //使用的衛(wèi)星數(shù)
unsigned char total_sat[2]; //天空中總衛(wèi)星數(shù)
unsigned char lock; //定位狀態(tài)
//串口中斷需要的變量
unsigned char seg_count; //逗號(hào)計(jì)數(shù)器
unsigned char byte_count; //位數(shù)計(jì)數(shù)器
unsigned char cmd_number; //命令類型
unsigned char mode; //0:結(jié)束模式,1:命令模式,2:數(shù)據(jù)模式
unsigned char buf_full; //1:整句接收完成,相應(yīng)數(shù)據(jù)有效。0:緩存數(shù)據(jù)無(wú)效
unsigned char cmd[5]; //命令類型存儲(chǔ)數(shù)組
//顯示需要的變量
unsigned int dsp_count; //刷新次數(shù)計(jì)數(shù)器
unsigned char time_count;
bit page;
void sys_init(void);
bit chk_key(void);
main()
unsigned char i;
char Bhour;
sys_init();
ock=1;
use_sat[0]='0';
use_sat[1]='0';
total_sat[0]='0';
total_sat[1]='0';
if(buf_full==0) //無(wú)GPS信號(hào)時(shí)
dsp_count++;
if(dsp_count>=65000)
LCD_cls(); //清屏
LCD_write_string(0,0,"No GPS connect..");
LCD_write_string(0,1,"Please Check..");
while(buf_full==0);
LCD_cls();
dsp_count=0;
else{ //有GPS信號(hào)時(shí)
if(chk_key())
//檢測(cè)到按鍵切換顯示
page=!page;
LCD_cls();
if(!page)
{ //頁(yè)面1
if(buf_full|0x01)
{ //GGA語(yǔ)句
if(lock==0)
{ //如果未定位
LCD_write_string(0,0,"*---.--.---- ");
LCD_write_string(0,1,"* --.--.---- ");
{ //如果已定位
LCD_write_char(0,0,JD_a); //顯示經(jīng)度
for(i=0;i<3;i++)
LCD_write_char(i+1,0,JD[i]);
LCD_write_char(4,0,'.');
for(i=3;i<10;i++)
LCD_write_char(i+2,0,JD[i]);
LCD_write_char(0,1,WD_a); //顯示緯度
LCD_write_char(1,1,' ');
for(i=0;i<2;i++)
LCD_write_char(i+2,1,WD[i]);
LCD_write_char(4,1,'.');
for(i=2;i<9;i++)
LCD_write_char(i+3,1,WD[i]);
LCD_write_char(14,1,use_sat[0]); //顯示接收衛(wèi)星數(shù)
LCD_write_char(15,1,use_sat[1]);
buf_full&=~0x01;
dsp_count=0;
if(buf_full|0x02)
{ //GSV語(yǔ)句
LCD_write_char(14,1,total_sat[0]);
LCD_write_char(15,1,total_sat[1]);
buf_full&=~0x02;
dsp_count=0;
if(buf_full|0x04)
if(lock==0)
{ //如果未定位
{ //如果已定位
for(i=0;i<3;i++)
for(i=3;i<10;i++)
for(i=0;i<2;i++)
for(i=2;i<9;i++)
LCD_write_char(14,0,use_sat[0]); //顯示接收衛(wèi)星數(shù)
LCD_write_char(15,0,use_sat[1]);
buf_full&=~0x04;
dsp_count=0;
{ //頁(yè)面2
if(buf_full|0x01)
{ //GGA語(yǔ)句
buf_full&=~0x01;
dsp_count=0;
if(buf_full|0x02)
buf_full&=~0x02;
dsp_count=0;
if(buf_full|0x04)
{ //RMC語(yǔ)句
Bhour=((time[0]-0x30)*10+time[1]-0x30)+TIME_AREA;
if(Bhour>=24)
Bhour-=24;
else if(Bhour<0)
Bhour+=24;
LCD_write_char(0,1,date[4]);
LCD_write_char(1,1,date[5]);
LCD_write_char(2,1,date[2]);
LCD_write_char(3,1,date[3]);
LCD_write_char(4,1,date[0]);
LCD_write_char(5,1,date[1]);
LCD_write_char(8,1,Bhour/10+0x30);
LCD_write_char(9,1,Bhour%10+0x30);
LCD_write_char(10,1,':');
LCD_write_char(11,1,time[2]);
LCD_write_char(12,1,time[3]);
LCD_write_char(13,1,':');
LCD_write_char(14,1,time[4]);
LCD_write_char(15,1,time[5]);
LCD_write_string(5,0,"knot A"); //在此處做的更改
if(lock=='0'){ //如果未定位
LCD_write_string(0,0,"---.-");
LCD_write_string(11,0,"---.-");
//已經(jīng)定位,在此處做的改動(dòng)。 /*******************************************************************************
最大速度處理
dot_count=0;
b=0;
for(i=0;i<5;i++)
if(speed[i]!='.')
dot_count++;
break;
switch(dot_count)
case 1:
b=((speed[0]-'0')*10+(speed[2]-'0'))*1.852;
break;
case 2:
b=((speed[0]-'0')*100+(speed[1]-'0')*10+(speed[4]-'0'))*1.852;
break;
case 3:
b=((speed[0]-'0')*1000+(speed[1]-'0')*100+(speed[2]-'0')*10+(speed[4]-'0'))*1.852;
break;
if(b>maxspeed)
maxspeed=b;
最大速度處理
if(count<10)
for(i=0;i<5;i++)
LCD_write_char(i,0,speed[i]);//knot顯示
count++;
if(count>15)
count=0;
hspeed[0]=maxspeed/1000+0x30; //把小數(shù)轉(zhuǎn)成字符數(shù)組
hspeed[1]=(maxspeed/100)%10+0x30;
hspeed[2]=(maxspeed/10)%10+0x30;
hspeed[3]='.';
hspeed[4]= maxspeed%10+0x30;
count++;
LCD_write_string(5,0,"Km/h A");
LCD_write_char(0,0,hspeed[0]);
LCD_write_char(1,0,hspeed[1]);
LCD_write_char(2,0,hspeed[2]);
LCD_write_char(3,0,hspeed[3]);
LCD_write_char(4,0,hspeed[4]); //最大速度顯 */
for(i=0;i<5;i++)
LCD_write_char(11+i,0,angle[i]);
buf_full&=~0x04;
dsp_count=0;
bit chk_key(void)
if(!KEY1)
delayms(10);
if(!KEY1)
while(!KEY1);
delayms(10);
return(1);
LCD_cls(); //清屏
return(0);
//系統(tǒng)初始化
void sys_init()
unsigned char i;
SCON = 0x50;
/* SCON: mode 1, 8-bit UART, enable rcvr */
TMOD = 0x21; /* TMOD: timer 1, mode 2, 8-bit reload */
if(GPS_SPD)
TH1 = 0xfa; /* TH1: reload value for 9600 baud @ 11.059MHz */
TH1 = 0xfd; /* TH1: reload value for 4800 baud @ 11.059MHz */
TR1 = 1; /* TR1: timer 1 run */
LCD_init(8); //初始化LCD
LCD_write_string(0,0," GPS SIRF II 2 ");
LCD_write_string(0,1," 11-11-23 1342 ");
for(i=1;i<4;i++)
delayms(250);
//LCD_cls();
IE=0x90; //開(kāi)總中斷、串口中斷
//串口接收中斷
void uart(void) interrupt 4
unsigned char tmp;
if(RI)
tmp=SBUF;
switch(tmp)
case '$':
cmd_number=0; //命令類型清空
mode=1; //接收命令模式
byte_count=0; //接收位數(shù)清空
break;
case ',':
seg_count++; //逗號(hào)計(jì)數(shù)加1
byte_count=0;
break;
case '*':
switch(cmd_number)
case 1:
buf_full|=0x01;
break;
case 2:
buf_full|=0x02;
break;
case 3:
buf_full|=0x04;
break;
mode=0;
break;
default:
if(mode==1)
{ //命令種類判斷
cmd[byte_count]=tmp; //接收字符放入類型緩存
if(byte_count>=4)
{ //如果類型數(shù)據(jù)接收完畢,判斷類型
if(cmd[0]=='G')
if(cmd[1]=='P')
if(cmd[2]=='G')
if(cmd[3]=='G')
if(cmd[4]=='A')
cmd_number=1;
mode=2;
seg_count=0;
byte_count=0;
if(cmd[3]=='S')
if(cmd[4]=='V')
cmd_number=2;
mode=2;
seg_count=0;
byte_count=0;
if(cmd[2]=='R')
if(cmd[3]=='M')
if(cmd[4]=='C')
cmd_number=3;
mode=2;
seg_count=0;
byte_count=0;
else if(mode==2)
//接收數(shù)據(jù)處理
switch (cmd_number)
case 1: //類型1數(shù)據(jù)接收。GPGGA
switch(seg_count)
case 2: //緯度處理
if(byte_count<9)
WD[byte_count]=tmp;
break;
case 3: //緯度方向處理
if(byte_count<1)
WD_a=tmp;
break;
case 4: //經(jīng)度處理
if(byte_count<10)
JD[byte_count]=tmp;
break;
case 5: //經(jīng)度方向處理
if(byte_count<1)
JD_a=tmp;
break;
case 6: //定位判斷
if(byte_count<1)
lock=tmp;
break;
case 7: //定位使用的衛(wèi)星數(shù)
if(byte_count<2)
use_sat[byte_count]=tmp;
break;
case 9: //高度處理
if(byte_count<6)
high[byte_count]=tmp;
break;
break;
case 2: //類型2數(shù)據(jù)接收。GPGSV
switch(seg_count)
case 3: //天空中的衛(wèi)星總數(shù)
if(byte_count<2)
total_sat[byte_count]=tmp;
break;
break;
case 3: //類型3數(shù)據(jù)接收。GPRMC
switch(seg_count)
case 1: //時(shí)間處理
if(byte_count<6)
time[byte_count]=tmp;
break;
case 2: //定位判斷
if(byte_count<1)
if (tmp=='A')
lock=1;
lock=0;
break;
case 3: //緯度處理
if(byte_count<9)
WD[byte_count]=tmp;
break;
case 4: //緯度方向處理
if(byte_count<1)
WD_a=tmp;
break;
case 5: //經(jīng)度處理
if(byte_count<10)
JD[byte_count]=tmp;
break;
case 6: //經(jīng)度方向處理
if(byte_count<1)
JD_a=tmp;
break;
case 7: //速度處理
if(byte_count<5)
speed[byte_count]=tmp;
break;
case 8: //方位角處理
if(byte_count<5)
angle[byte_count]=tmp;
break;
case 9: //方位角處理
if(byte_count<6)
date[byte_count]=tmp;
break;
break;
byte_count++; //接收數(shù)位加1
break;
RI=0;
