#include<reg51.h>
#include"lcd.h"//此頭文件見下面的附件,沒有錯(cuò)誤
#include <intrins.h>
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號8位整型變量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符號8位整型變量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號16位整型變量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符號16位整型變量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號32位整型變量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符號32位整型變量 */
typedef float F32; /* single precision floating point variable (32bits) 單精度浮點(diǎn)數(shù)(32位長度) */
typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點(diǎn)數(shù)(64位長度) */
//----------------IO口定義區(qū)--------------------//
sbit P2_0 = P2^0 ;
//----------------定義區(qū)--------------------//
U8 U8FLAG,k;
U8 U8count,U8temp;
U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8 U8comdata;
U16 U16temp1,U16temp2;
void LcdDisplay();
unsigned char SetState,SetPlace;
void Delay(U16 j)
{ U8 i;
for(;j>0;j--)
for(i=0;i<27;i++);
void Delay_10us(void)
U8 i;
i--;
i--;
i--;
i--;
i--;
i--;
void COM(void)
U8 i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!P2_0)&&U8FLAG++);
Delay_10us();
Delay_10us();
Delay_10us();
U8temp=0;
if(P2_0)U8temp=1;
U8FLAG=2;
while((P2_0)&&U8FLAG++);
//超時(shí)則跳出for循環(huán)
if(U8FLAG==1)break;
//判斷數(shù)據(jù)位是0還是1
// 如果高電平高過預(yù)定0高電平值則數(shù)據(jù)位為 1
U8comdata<<=1;
U8comdata|=U8temp; //0
}//rof
//-----濕度讀取子程序 ------------
//----以下變量均為全局變量--------
//----溫度高8位== U8T_data_H------
//----溫度低8位== U8T_data_L------
//----濕度高8位== U8RH_data_H-----
//----濕度低8位== U8RH_data_L-----
//----校驗(yàn) 8位 == U8checkdata-----
//----調(diào)用相關(guān)子程序如下----------
//---- Delay();, Delay_10us();,COM();
void RH(void)
//主機(jī)拉低18ms
P2_0=0;
Delay(180);
P2_0=1;
//總線由上拉電阻拉高 主機(jī)延時(shí)20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
//主機(jī)設(shè)為輸入 判斷從機(jī)響應(yīng)信號
P2_0=1;
//判斷從機(jī)是否有低電平響應(yīng)信號 如不響應(yīng)則跳出,響應(yīng)則向下運(yùn)行
if(!P2_0) //T !
U8FLAG=2;
//判斷從機(jī)是否發(fā)出 80us 的低電平響應(yīng)信號是否結(jié)束
U8FLAG=2;
//判斷從機(jī)是否發(fā)出 80us 的高電平,如發(fā)出則進(jìn)入數(shù)據(jù)接收狀態(tài)
//數(shù)據(jù)接收狀態(tài)
COM();
U8RH_data_H_temp=U8comdata;
COM();
U8RH_data_L_temp=U8comdata;
COM();
U8T_data_H_temp=U8comdata;
COM();
U8T_data_L_temp=U8comdata;
COM();
U8checkdata_temp=U8comdata;
P2_0=1;
//數(shù)據(jù)校驗(yàn)
U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
if(U8temp==U8checkdata_temp)
U8RH_data_H=U8RH_data_H_temp;
U8RH_data_L=U8RH_data_L_temp;
U8T_data_H=U8T_data_H_temp;
U8T_data_L=U8T_data_L_temp;
U8checkdata=U8checkdata_temp;
}//fi
}//fi
* 函數(shù)名 : main
* 函數(shù)功能 : 主函數(shù)
* 輸入 : 無
* 輸出 : 無
LcdInit();
LcdWriteCom(0x80+0x00); //寫地址 80表示初始地址
LcdWriteData('R');
LcdWriteCom(0x80+0x01);
LcdWriteData('H');
LcdWriteCom(0x80+0x40);
LcdWriteData('T');
RH();
LcdDisplay();
* 函數(shù)名 : LcdDisplay()
* 函數(shù)功能 : 顯示函數(shù)
* 輸入 : 無
* 輸出 : 無
void LcdDisplay()
unsigned char datas[] = {0, 0, 0, 0, 0}; //定義數(shù)組
datas[1] = U8RH_data_H / 10;
datas[2] = U8RH_data_L % 10;
datas[3] = U8T_data_H / 10;
datas[4] = U8T_data_L % 10;
LcdWriteCom(0x80+0X03); //寫地址 80表示初始地址
LcdWriteData('0'+datas[1]); //溫度十位
LcdWriteCom(0x80+0X04); //寫地址 80表示初始地址
LcdWriteData('0'+datas[2]); //個(gè)位
LcdWriteCom(0x80+0X42); //寫地址 80表示初始地址
LcdWriteData('0'+datas[3]); //顯示濕度十位
LcdWriteCom(0x80+0X43); //寫地址 80表示初始地址
LcdWriteData('0'+datas[4]); //個(gè)位
