查看: 3552|回復(fù): 1
基于51單片機(jī)和DS18B20的溫度計(jì)設(shè)計(jì)
ID:213028 發(fā)表于 2017-6-20 18:29 | 顯示全部樓層 |閱讀模式
  • //proteus仿真論壇
  • #include<reg51.h>
  • #include<intrinS.h>
  • #include<absacc.h>
  • #define uchar unsigned char
  • #define C02_write 0xa0
  • #define C02_read  0xa1
  • #define no0 0x28
  • #define no1 0x14
  • #define no2 0x24
  • #define no3 0x44
  • #define no4 0x12
  • #define no5 0x22
  • #define no6 0x42
  • #define no7 0x11
  • #define no8 0x21
  • #define no9 0x41
  • #define enter 0x88
  • #define backspace 0x81
  • #define lcm_write_cmd_add XBYTE[0x80FF]
  • #define lcm_write_data_add XBYTE[0x81FF]
  • #define lcm_read_busy_add XBYTE[0x82FF]
  • #define lcm_read_data_add XBYTE[0x83FF]
  • uchar idata temp5_password[6]={0x00,0x00,0x00,0x00,0x00,0x00};
  • uchar idata key_code[]={no0,no1,no3,no4,no5,no6,no7,no8,no9};
  • sbit SCL=P3^0;
  • sbit SDA=P3^1;
  • sbit i=P3^2;
  • bit ack;
  • uchar        int_counter_1;
  • unsigned int int_counter_2;
  • void delayms(uchar i)
  •         uchar j;
  •         for(;i>0;i--)
  •         for(j=124;j>0;j--);
  • void longdelay(uchar i)
  •         unsigned int j;
  •         for(;i>0;i--)
  •         for(j=10000;j>0;j--);
  • void lcm_wait()
  •         while(lcm_read_busy_add&0x80);
  • void lcm_write_cmd(uchar lcm_cmd)
  •         lcm_wait();
  •         lcm_write_cmd_add=lcm_cmd;
  • void lcm_write_data(uchar lcm_data)
  •         lcm_wait();
  •         lcm_write_data_add=lcm_data;
  • uchar lcm_read_data(void)
  •         uchar lcm_data;
  •         lcm_wait();
  •         lcm_data=lcm_read_data_add;
  •         return(lcm_data);
  • void lcm_setxy(uchar x,uchar y)
  •         if(y==1) lcm_write_cmd(x|0x80);
  •         if(y==2) lcm_write_cmd(x|0xc0);
  • void lcm_write_string(uchar *string)
  •         uchar i=0;
  •         while(string!='\0')
  •                 lcm_write_data(string);
  •                 i++;
  • void lcm_roll_display(uchar *string,uchar y)
  •         uchar counter;
  •         lcm_write_cmd(0x06);
  •         lcm_setxy(0,y);
  •         while(string[counter]!='\0')
  •                 lcm_write_data(string[counter]);
  •                 counter++;
  •                 if (counter==19) lcm_setxy(19,y);
  •                 longdelay(2);
  •         lcm_write_cmd(0x07);
  •         lcm_setxy(19,y);
  •                 counter++;
  •                 longdelay(2);
  • void lcm_init()
  •         delayms(20);
  •         lcm_write_cmd_add=0x38;
  •         delayms(4);
  •         delayms(1);
  •         lcm_write_cmd(0x38);
  •         lcm_write_cmd(0x0f);
  •         lcm_write_cmd(0x01);
  • void I2C_start(void)
  •         SDA=1;
  •         SCL=1;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         SDA=0;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         SCL=0;
  •         _nop_();
  •         _nop_();
  • void I2C_stop(void)
  •         SDA=0;
  •         SCL=1;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         SDA=1;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         SCL=0;
  •         _nop_();
  •         _nop_();
  • void I2C_ackownledge(void)
  •         SDA=0;
  •         _nop_();
  •         _nop_();
  •         SCL=1;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         SCL=0;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  • void I2C_no_ackownledge(void)
  •         SDA=1;
  •         _nop_();
  •         _nop_();
  •         SCL=1;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         SCL=0;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  • void I2C_sendB(uchar byte)
  •         uchar counter;
  •         for(counter=0;counter<8;counter++)
  •                 if(byte&0x80)        SDA=1;
  •                 else        SDA=0;
  •                 _nop_();
  •                 SCL=1;
  •                 _nop_();
  •                 _nop_();
  •                 _nop_();
  •                 _nop_();
  •                 _nop_();
  •                 SCL=0;
  •                 _nop_();
  •                 _nop_();
  •                 byte<<=1;
  •         _nop_();
  •         _nop_();
  •         SDA=1;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         SCL=1;
  •         _nop_();
  •         _nop_();
  •         _nop_();
  •         if(SDA==0)        ack=1;
  •         else         ack=0;
  •         SCL=0;
  •         _nop_();
  •         _nop_();
  • uchar I2C_receiveB(void)
  •         uchar temp;
  •         uchar counter;
  •         temp=0;
  •         SDA=1;
  •         _nop_();
  •         _nop_();
  •                  _nop_();
  •                  _nop_();
  •                  _nop_();
  •                  _nop_();
  •                  _nop_();
  •                  SCL=1;
  •                  _nop_();
  •                  _nop_();
  •                  if(SDA==1)        temp=(temp<<1)|0x01;
  •                  else        temp=temp<<1;
  •                  _nop_();
  •                  _nop_();
  •                  SCL=0;
  •                  _nop_();
  •                  _nop_();
  •                  _nop_();
  •         _nop_();
  •         _nop_();
  •         return(temp);
  • /*bit I2C_write_byte(uchar byte,uchar address)
  •         I2C_sendB(address);
  •         if(ack=0)
  •                 I2C_stop();
  •                 return(0);
  •         else        I2C_sendB(byte);  */
  • bit I2C_send_string(uchar *string,uchar no,uchar address)
  •         uchar counter;
  •         for(counter=0;counter<no;counter++)
  •                 I2C_start();
  •                 I2C_sendB(C02_write);
  •                 if(ack==0) return(0);
  •                 I2C_sendB(address+counter);
  •                 I2C_sendB(string[counter]);
  •                 I2C_stop();
  •                 delayms(20);
  •         return(1);
  • bit I2C_receive_string(uchar *string,uchar no,uchar address)
  •         uchar counter;
  •                 I2C_start();
  •                 I2C_start();
  •                 I2C_sendB(C02_read);
  •                 *(string+counter)=I2C_receiveB();
  •                 I2C_no_ackownledge();
  •                 I2C_stop();
  • uchar get_key()
  •         uchar row_code;
  •         uchar col_code;
  •         P1=0xf0;
  •         if(P1!=0xf0)
  •                 delayms(10);
  •                 if(P1!=0xf0)
  •                         row_code=0xfe;
  •                         while(row_code!=0x7f)
  •                                 P1=row_code;
  •                                 if(P1!=row_code)
  •                                         col_code=(P1&0xf0)|0x0f;
  •                                         return(        (~col_code)|(~row_code));
  •                                 row_code=((row_code<<1)|0x01);
  •         return(0x00);
  • void convert_code(uchar *string)
  •         uchar counter=0;
  •         for(counter=0;counter<6;counter++)
  •                 switch(*string)
  •                         case no0:
  •                                                 *string=0x00;
  •                                                 break;
  •                         case no1:
  •                                                 *string=0x01;
  •                                                 break;
  •                         case no2:
  •                                                 *string=0x02;
  •                                                 break;
  •                         case no3:
  •                                                 *string=0x03;
  •                                                 break;
  •                         case no4:
  •                                                 *string=0x04;
  •                                                 break;
  •                         case no5:
  •                                                 *string=0x05;
  •                                                 break;
  •                         case no6:
  •                                                 *string=0x06;
  •                                                 break;
  •                         case no7:
  •                                                 *string=0x07;
  •                                                 break;
  •                         case no8:
  •                                                 *string=0x08;
  •                                                 break;
  •                         case no9:
  •                                                 *string=0x09;
  •                                                 break;
  •                         default:
  •                                                 break;
  •                 string++;
  • bit compare_string(uchar *string1,uchar *string2)
  •         uchar counter;
  •                 if(string1[counter]!=string2[counter]) return(0);
  •         return(1);
  • uchar step_choose(void)
  •         unsigned int i;
  •         uchar key;
  •         do{
  •                 lcm_setxy(0,1);
  •                 lcm_write_string("input password");
  •                 lcm_setxy(0,2);
  •                 lcm_write_string("please press 1");
  •                 for(i=0;i<30000;i++)
  •                         key=get_key();
  •                         if((key==no1)||(key==no2))        break;
  •                 if((key!=no1)&&(key!=no2))
  •                         lcm_setxy(0,1);
  •                         lcm_write_string("change password");
  •                         lcm_setxy(0,2);
  •                         lcm_write_string("please press 2");
  •                                 key=get_key();
  •         while((key!=no1)&&(key!=no2));
  •         return(key);
  • bit input_password(uchar *password)
  •         uchar counter;
  •         uchar key;
  •         lcm_setxy(0,2);
  •         for(counter=0;counter<7;counter++)
  •                 longdelay(3);
  •                 if(counter<6)
  •                         do{
  •                                 key=get_key();
  •                     while(key==0x00);
  •                         if((key!=backspace)&&(key!=enter))
  •                                 lcm_write_data('*');
  •                                 password[counter]=key;
  •                         if(key==backspace)
  •                                 if(counter>0)
  •                                         lcm_setxy(--counter,2);
  •                                         lcm_write_data(' ');
  •                                         password[counter]=0x00;
  •                                         lcm_setxy(counter,2);
  •                                         counter--;
  •                         if(key==enter)
  •                                 lcm_setxy(0,1);
  •                                 return(        0);
  •                 if(counter==6)
  •                         do{
  •                                 key=get_key();
  •                         while((key!=backspace)&&(key!=enter));
  •                                 counter--;
  •                         if(key==enter)
  •                                 return(1);
  • void mima()
  •         uchar key;
  •         uchar idata temp1_password[6]={0,0,0,0,0,0};
  •         uchar idata temp3_password[6]={0,0,0,0,0,0};
  •         uchar idata temp2_password[6]={0,0,0,0,0,0};
  •         uchar idata temp4_password[6]={0,0,0,0,0,0};
  •         key=step_choose();
  •         if(key==no1)
  •                 I2C_receive_string(temp1_password,6,0x00);
  •                 lcm_setxy(2,0);
  •                 if(input_password(temp2_password))
  •                         convert_code(temp2_password);
  •                         if(compare_string(temp1_password,temp2_password))
  •                                 lcm_setxy(0,2);
  •                                 lcm_write_string("correct!");
  •                                 longdelay(6);
  •                                 return;
  •                         else
  •                                 lcm_setxy(0,2);
  •                                 lcm_write_string("wrong password");
  •                                 longdelay(6);
  •                                 return;
  •                 else
  •                         lcm_setxy(0,2);
  •                         lcm_write_string("error!  ");
  •                         longdelay(6);
  •         else
  •                 lcm_setxy(0,0);
  •                 lcm_write_string("input old password");
  •                                 lcm_setxy(0,2);
  •                                 lcm_write_string("password correct!");
  •                                 longdelay(6);
  •                                 lcm_setxy(0,1);
  •                                 lcm_write_string("input new password");
  •                                 if(input_password(temp3_password))
  •                                         lcm_setxy(0,1);
  •                                         lcm_write_string("input password again");
  •                                         if(input_password(temp4_password))
  •                                                 if(compare_string(temp3_password,temp4_password))
  •                                                         convert_code(temp3_password);
  •                                                         I2C_send_string(temp3_password,6,0x00);
  •                                                         lcm_setxy(0,1);
  •                                                         lcm_write_string("password has");
  •                                                         lcm_setxy(0,2);
  •                                                         lcm_write_string("been changed");
  •                                                         longdelay(10);
  •                                                         return;
  •                                                 else
  •                                                    lcm_setxy(0,1);
  •                                                    lcm_write_string("twice input");
  •                                                    lcm_setxy(0,2);
  •                                                    lcm_write_string("is different");
  •                                                    longdelay(10);
  •                                                    return;
  •                                         else
  •                                                 lcm_setxy(0,2);
  •                                                 longdelay(10);
  •                                                 return;
  •                                 else
  •                                         lcm_setxy(0,2);
  •                                         longdelay(10);
  •                                         return;
  •                         else
  •                                 lcm_setxy(0,2);
  •                                 longdelay(6);
  •                                 return;
  •                 else
  •                         lcm_setxy(0,2);
  •                         longdelay(6);
  •                         return;
  • void        int_service(void)        using 0 interrupt        0
  •         EA=0;
  •         EX0=0;
  •         for(int_counter_1=10;int_counter_1>0;int_counter_1--)
  •                 for(int_counter_2=0xffff;int_counter_2>0;int_counter_2--)
  •                         if(i)
  •                                 EA=1;
  •                                 EX0=1;
  •                                 return;
  •         lcm_write_string("rest success!");
  •         longdelay(12);
  •         I2C_send_string(temp5_password,6,0x00);
  •         (*(void(*)())0)();
  • void main(void)
  •         IT0=1;
  •         EX0=1;
  •         EA=1;
  •         lcm_init();
  •     while(1)
  •                 mima();
相關(guān)帖子
ID:269228 發(fā)表于 2017-12-30 17:13 | 顯示全部樓層
有人試過嗎?能不能用
