int LCD1602_RS=12;
int LCD1602_RW=11;
int LCD1602_EN=10;
int DB[] = { 6, 7, 8, 9};
char str1[]="Welcome to";
char str2[]="geek-workshop";
char str3[]="this is the";
char str4[]="4-bit interface";
void LCD_Command_Write(int command)
int i,temp;
digitalWrite( LCD1602_RS,LOW);
digitalWrite( LCD1602_RW,LOW);
digitalWrite( LCD1602_EN,LOW);
temp=command & 0xf0;
for (i=DB[0]; i <= 9; i++)
digitalWrite(i,temp & 0x80);
temp <<= 1;
digitalWrite( LCD1602_EN,HIGH);
delayMicroseconds(1);
temp=(command & 0x0f)<<4;
temp <<= 1;
void LCD_Data_Write(int dat)
int i=0,temp;
digitalWrite( LCD1602_RS,HIGH);
temp=dat & 0xf0;
temp <<= 1;
temp=(dat & 0x0f)<<4;
temp <<= 1;
void LCD_SET_XY( int x, int y )
int address;
if (y ==0) address = 0x80 + x;
else address = 0xC0 + x;
LCD_Command_Write(address);
void LCD_Write_Char( int x,int y,int dat)
LCD_SET_XY( x, y );
LCD_Data_Write(dat);
void LCD_Write_String(int X,int Y,char *s)
LCD_SET_XY( X, Y ); //設(shè)置地址
while (*s) //寫(xiě)字符串
LCD_Data_Write(*s);
s ++;
void setup (void)
int i = 0;
for (i=6; i <= 12; i++)
pinMode(i,OUTPUT);
delay(100);
LCD_Command_Write(0x28);//4線(xiàn) 2行 5x7
delay(50);
LCD_Command_Write(0x06);
delay(50);
LCD_Command_Write(0x0c);
delay(50);
LCD_Command_Write(0x80);
delay(50);
LCD_Command_Write(0x01);
delay(50);
void loop (void)
delay(50);
LCD_Write_String(3,0,str1);//第1行,第4個(gè)地址起
delay(50);
LCD_Write_String(1,1,str2);//第2行,第2個(gè)地址起
delay(5000);
delay(50);
LCD_Write_String(0,0,str3);
delay(50);
LCD_Write_String(0,1,str4);
delay(5000);
_1602.rar
2017-7-20 20:05 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
860 Bytes, 下載次數(shù): 18, 下載積分: 黑幣 -5
