附件內(nèi)有上位機(jī)VB源碼和上位機(jī)安裝程序,圖片左上角的小界面是上位機(jī)程序,可獲取電腦的時間和日期發(fā)送到16*64LED上顯示(需要安裝虛擬串口)。
單片機(jī)16*64LED條屏仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
- #include "reg51.h" //包含51單片機(jī)的端口和內(nèi)部寄存器定義的頭文件
- typedef unsigned char uint8; //定義字符型
- typedef unsigned int uint16; //定義整型
- typedef unsigned long uint32; //定義長整型
- uint32 dx,dxx; //字符顯示偏移量
- uint8 brk,flag;
- uint8 BUFFER[22];
- sbit RTC_RST = P3^5;
- sbit RTC_SCLK = P3^6;
- sbit RTC_IO = P3^7;
- uint8 bdata AA; //brk延時用
- uint8 const code dat_bit_up[]={0xF7,0xFB,0xFD,0xFE,0x7F,0xBF,0xDF,0xEF}; //列高位掃描數(shù)據(jù)
- uint8 const code dat_bit_down[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F}; //列低位掃描數(shù)據(jù)
- sbit AA7 = AA^7;
- #define READ_SECOND 0x81
- #define WRITE_SECOND 0x80
- #define READ_MINE 0x83
- #define WRITE_MINE 0x82
- #define READ_HOUR 0x85
- #define WRITE_HOUR 0x84
- #define READ_DAY 0x87
- #define WRITE_DAY 0x86
- #define READ_MONTH 0x89
- #define WRITE_MONTH 0x88
- #define READ_WEEK 0x8b
- #define WRITE_WEEK 0x8a
- #define READ_YEAR 0x8d
- #define WRITE_YEAR 0x8c
- uint8 const code NUM[][16]=
- {0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,0x00},/*"0",0*/
- {0x00,0x00,0x10,0x81,0x28,0xC2,0x21,0x44,0x21,0x24,0x22,0x00,0x3E,0xFF,0x22,0x44,0x22,0x44,0x22,0x7C,0x3E,0x44,0x22,0x7C,0x22,0x44,0x22,0xFE,0x3E,0x44,0x00,0x44},/*"期",4*/
- {0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00},/*":",0*/
- / 端口定義
- #define LED_PORTH P0 //列高位
- #define LED_PORTL P2 //列低位
- sbit SER_CP=P3^4; //串行時鐘線
- sbit SER_SDA=P3^3; //串行數(shù)據(jù)線
- sbit SER_EN=P3^2; //74595數(shù)據(jù)有效線
- / 函數(shù)名稱:Delay
- / 作用: 延時子程序主要用于LED的消隱
- void Delay() //延時子程序
- uint16 i,j;
- for(i=0;i<0x14;i++)
- for(j=0;j<0x05;j++);
- / 函數(shù)名稱:LED_Ser
- / 作用: 發(fā)送串行數(shù)據(jù)到74LS595
- / 入口參數(shù):dat 為要發(fā)送的數(shù)據(jù)8位
- void LED_Ser(uint16 dat)
- uint8 i;
- for(i=0;i<16;i++) //共8BYTE
- SER_SDA=dat&0x01; //把數(shù)據(jù)的最后一位放在數(shù)據(jù)線上
- dat>>=1; //向右移位共8下這樣可以發(fā)送8位數(shù)據(jù)
- SER_CP=0; //
- SER_CP=1; //產(chǎn)生上升沿發(fā)送數(shù)據(jù)1BYTE
- void LED_Ser_8(uint8 dat)
- uint8 i;
- for(i=0;i<8;i++) //共8BYTE
- SER_CP=0; //
- / 函數(shù)名稱:LED_Ser_EN
- / 作用: 用于在SER_EN口線上產(chǎn)生上長沿使74595發(fā)送的數(shù)據(jù)有效
- void LED_Ser_EN()
- SER_EN=0; //
- SER_EN=1; //產(chǎn)生上升沿脈沖用于使74595發(fā)的數(shù)據(jù)有效
- / 函數(shù)名稱:LED_Disp
- / 作用: 在LED上顯示字符或BMP
- / 入口參數(shù):*dat 為要顯示的字符或BMP的數(shù)據(jù)的首地址指針
- void LED_Disp(uint16 *dat)
- uint16 tmp;
- uint8 a,j,i;
- for(j=0;j<16;)
- for(i=0;i<16;i++)
- for(a=0;a<4;a++) //共四個字
- if(dx>15){dxx+=16;dx=0;} //dx,dxx為顯示偏移量
- tmp=((dat[i+dxx+a*16]>>dx)|(dat[i+dxx+(a+1)*16]<<(16-dx)));//移動一位最大可移動八位左
- if(dat[i+(a+1)*16+dxx]==0x55aa){dxx=0;tmp=0;flag=1;}
- LED_Ser(~tmp); //發(fā)送右
- LED_Ser_EN(); //使發(fā)送的數(shù)據(jù)顯示
- if(j<8){LED_PORTH=dat_bit_up[j];LED_PORTL=0XFF;} //上半列掃描
- else{LED_PORTL=dat_bit_down[j-8];LED_PORTH=0XFF;} //下半列掃描
- Delay(); //延時
- LED_PORTL=0XFF; //消隱
- LED_PORTH=0XFF; //消隱
- j++;
- void RTC_Write(uint8 dat)
- uint8 i;
- for(i=0;i<8;i++)
- RTC_IO=(bit)(dat&0x01);
- RTC_SCLK=1;
- RTC_SCLK=0;
- dat>>=1;
- uint8 RTC_Read()
- uint8 i;
- for(i=0; i<8; i++)
- AA >>=1; //相當(dāng)于匯編中的 RRC
- AA7 = RTC_IO;
- RTC_SCLK = 1;
- RTC_SCLK = 0;
- return AA;
- void RTC_Write_Byte(uint8 addr,uint8 dat)
- RTC_RST=0;
- RTC_SCLK=0;
- RTC_RST=1;
- RTC_Write(addr);
- RTC_Write(dat);
- RTC_SCLK=1;
- RTC_RST=0;
- uint8 RTC_Read_Byte(uint8 addr)
- uint8 dat;
- RTC_RST=0;
- RTC_SCLK=0;
- RTC_RST=1;
- RTC_Write(addr|0x01);
- dat=RTC_Read();
- RTC_SCLK=1;
- RTC_RST=0;
- return dat;
- typedef struct __SYSTEMTIME__
- uint8 Second;
- uint8 Mine;
- uint8 Hour;
- uint8 Day;
- uint8 Month;
- uint8 Week;
- uint8 Year;
- }SYSTEMTIME;
- SYSTEMTIME TIMETYPE;
- void CurrentTime(SYSTEMTIME *dat)
- uint8 TimeValue;
- TimeValue=RTC_Read_Byte(READ_SECOND);
- dat->Second=(((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
- TimeValue=RTC_Read_Byte(READ_MINE);
- dat->Mine= (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
- TimeValue=RTC_Read_Byte(READ_HOUR);
- dat->Hour= (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
- TimeValue=RTC_Read_Byte(READ_DAY);
- dat->Day= (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
- TimeValue=RTC_Read_Byte(READ_MONTH);
- dat->Month= (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
- TimeValue=RTC_Read_Byte(READ_WEEK);
- dat->Week= (TimeValue&0x0f);
- TimeValue=RTC_Read_Byte(READ_YEAR);
- dat->Year= (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
- void LED_Disp_Time_Year(SYSTEMTIME *dat)
- uint8 j,i;
- for(j=0;j<16;)
- for(i=0;i<16;i++)
- LED_Ser_8(~HZ[0][i]); //發(fā)送右
- LED_Ser_8(~NUM[2][i]); //發(fā)送右
- LED_Ser_8(~NUM[0][i]); //發(fā)送右
- LED_Ser_8(~NUM[(dat->Year)/10][i]); //發(fā)送右
- LED_Ser_8(~NUM[(dat->Year)%10][i]); //發(fā)送右
- LED_Ser_8(~Date[0][i*2+1]);
- LED_Ser_8(~Date[0][i*2]);
- Delay(); //延時
- j++;
- void LED_Disp_Time_Month(SYSTEMTIME *dat)
- uint8 j,i;
- for(j=0;j<16;)
- for(i=0;i<16;i++)
- LED_Ser_8(~NUM[dat->Month/10][i]); //發(fā)送右
- LED_Ser_8(~NUM[dat->Month%10][i]); //發(fā)送右
- LED_Ser_8(~Date[1][i*2+1]); //發(fā)送右
- LED_Ser_8(~Date[1][i*2]); //發(fā)送右
- LED_Ser_8(~NUM[dat->Day/10][i]); //發(fā)送右
- LED_Ser_8(~NUM[dat->Day%10][i]);
- LED_Ser_8(~Date[2][i*2+1]);
- LED_Ser_8(~Date[2][i*2]); //發(fā)送右
- Delay(); //延時
- j++;
- void LED_Disp_Time_Week(SYSTEMTIME *dat)
- uint8 j,i;
- for(j=0;j<16;)
- for(i=0;i<16;i++)
- LED_Ser_8(~Date[3][i*2+1]); //發(fā)送右
- LED_Ser_8(~Date[3][i*2]); //發(fā)送右
- LED_Ser_8(~Date[4][i*2+1]); //發(fā)送右
- LED_Ser_8(~Date[4][i*2]); //發(fā)送右
- LED_Ser_8(~WEEK[dat->Week-1][i*2+1]);
- LED_Ser_8(~WEEK[dat->Week-1][i*2]);
- Delay(); //延時
- j++;
- void LED_Disp_Time_Time(SYSTEMTIME *dat)
- uint8 j,i;
- for(j=0;j<16;)
- for(i=0;i<16;i++)
- LED_Ser_8(~NUM[dat->Hour/10][i]); //發(fā)送右
- LED_Ser_8(~NUM[dat->Hour%10][i]); //發(fā)送右
- LED_Ser_8(~Date[5][i]); //發(fā)送右
- LED_Ser_8(~NUM[dat->Mine/10][i]); //發(fā)送右
- LED_Ser_8(~NUM[dat->Mine%10][i]); //發(fā)送右
- LED_Ser_8(~NUM[dat->Second/10][i]);
- LED_Ser_8(~NUM[dat->Second%10][i]); //發(fā)送右
- Delay(); //延時
- j++;
- / 函數(shù)名稱:ET0_INT
- / 作用: 定時器T0的中斷服務(wù)程序用于延自加字符顯示偏移量以產(chǎn)生字符滾動顯示的效果
- void ET0_INT() interrupt 1 using 0 //中斷服務(wù)程序
- TH0=0x03;
- TL0=0x04;
- brk++;
- if(brk==10)
- brk=0; //brk延時用
- dx++; //字符顯示偏移量
- void Char_to_time(uint8 *dat)
- uint8 year,month,day,week,hour,mine;
- year=((dat[0]-'0')*16+(dat[1]-'0'));
- month=((dat[3]-'0')*16+(dat[4]-'0'));
- day=((dat[6]-'0')*16+(dat[7]-'0'));
- hour=((dat[9]-'0')*16+(dat[10]-'0'));
- mine=((dat[12]-'0')*16+(dat[13]-'0'));
- week=(dat[15]-'0');
- RTC_Write_Byte(0x8e,0x00); //寫入允許
- RTC_Write_Byte(0x80,WRITE_SECOND|0x80);
- RTC_Write_Byte(0x8e,0x80); //禁止寫入
- RTC_Write_Byte(WRITE_YEAR,year); //寫入新的秒數(shù)
- RTC_Write_Byte(WRITE_MONTH,month); //寫入新的秒數(shù)
- RTC_Write_Byte(WRITE_DAY,day); //寫入新的秒數(shù)
- RTC_Write_Byte(WRITE_HOUR,hour); //寫入新的秒數(shù)
- RTC_Write_Byte(WRITE_MINE,mine&0x7f); //寫入新的秒數(shù)
- RTC_Write_Byte(WRITE_WEEK,week); //寫入新的秒數(shù)
- RTC_Write_Byte(0x80,WRITE_SECOND&0x7f);
- RTC_Write_Byte(0x8E,0x80);
- void Serial_int() interrupt 4 using 0
- uint8 i;
- for(i=0;i<17;i++)
- // RI=0;
- while(RI==0);
- RI=0;
- BUFFER[i]=SBUF;
- Char_to_time(BUFFER);
- / 函數(shù)名稱:main
- / 作用: 主程序
- void main()
- // TMOD=0x01; //定時器方式1
- TH0=0x03;
- TL0=0x04;
- TMOD=0x20;
- TH1=0xfd;
- TL1=0xfd;
- SCON=0x50;
- PCON&=0xef;
- EA=1; //開總中斷
- ET0=1; //開定時器中斷
- TR0=1; //開始定時
- ES=1;
- TR1=1;
- RI=0;
- while(1)
- while(!flag)
- LED_Disp(HZ);
- while(dx!=0x14)
- CurrentTime(&TIMETYPE);
- LED_Disp_Time_Year(&TIMETYPE); //顯示主程序
- dx=0;
- while(dx!=0x14)
- LED_Disp_Time_Month(&TIMETYPE);
- dx=0;
- while(dx!=0x14)
- LED_Disp_Time_Week(&TIMETYPE);
- dx=0;
- while(dx!=0x6f)
- LED_Disp_Time_Time(&TIMETYPE);
- dx=0;
- flag=0;
- while(!flag)
- LED_Disp(HZ1);
- flag=0;
HBLED.rar
(3.53 MB, 下載次數(shù): 47)
2018-10-10 20:45 上傳
點(diǎn)擊文件名下載附件
