- /* --- STC MCU Limited ------------------------------------------------*/
- /* --- STC15 系列 PCA輸出6/7/8位PWM舉例-------------------------*/
- /* 如果要在程序中使用此代碼,請在程序中注明使用了STC的資料及程序 */
- /* 如果要在文章中應(yīng)用此代碼,請在文章中注明使用了STC的資料及程序 */
- //本示例在Keil開發(fā)環(huán)境下請選擇Intel的8058芯片型號進(jìn)行編譯
- //若無特別說明,工作頻率一般為11.0592MHz
- #include "reg51.h"
- #include "intrins.h"
- #define FOSC 11059200L
- typedef unsigned char BYTE;
- typedef unsigned int WORD;
- sfr P0M1 = 0x93;
- sfr P0M0 = 0x94;
- sfr P1M1 = 0x91;
- sfr P1M0 = 0x92;
- sfr P2M1 = 0x95;
- sfr P2M0 = 0x96;
- sfr P3M1 = 0xb1;
- sfr P3M0 = 0xb2;
- sfr P4M1 = 0xb3;
- sfr P4M0 = 0xb4;
- sfr P5M1 = 0xC9;
- sfr P5M0 = 0xCA;
- sfr P6M1 = 0xCB;
- sfr P6M0 = 0xCC;
- sfr P7M1 = 0xE1;
- sfr P7M0 = 0xE2;
- sfr P_SW1 = 0xA2; //外設(shè)功能切換寄存器1
- #define CCP_S0 0x10 //P_SW1.4
- #define CCP_S1 0x20 //P_SW1.5
- sfr CCON = 0xD8; //PCA控制寄存器
- sbit CCF0 = CCON^0; //PCA模塊0中斷標(biāo)志
- sbit CCF1 = CCON^1; //PCA模塊1中斷標(biāo)志
- sbit CR = CCON^6; //PCA定時器運(yùn)行控制位
- sbit CF = CCON^7; //PCA定時器溢出標(biāo)志
- sfr CMOD = 0xD9; //PCA模式寄存器
- sfr CL = 0xE9; //PCA定時器低字節(jié)
- sfr CH = 0xF9; //PCA定時器高字節(jié)
- sfr CCAPM0 = 0xDA; //PCA模塊0模式寄存器
- sfr CCAP0L = 0xEA; //PCA模塊0捕獲寄存器 LOW
- sfr CCAP0H = 0xFA; //PCA模塊0捕獲寄存器 HIGH
- sfr CCAPM1 = 0xDB; //PCA模塊1模式寄存器
- sfr CCAP1L = 0xEB; //PCA模塊1捕獲寄存器 LOW
- sfr CCAP1H = 0xFB; //PCA模塊1捕獲寄存器 HIGH
- sfr CCAPM2 = 0xDC; //PCA模塊2模式寄存器
- sfr CCAP2L = 0xEC; //PCA模塊2捕獲寄存器 LOW
- sfr CCAP2H = 0xFC; //PCA模塊2捕獲寄存器 HIGH
- sfr PCA_PWM0 = 0xf2; //PCA模塊0的PWM寄存器
- sfr PCA_PWM1 = 0xf3; //PCA模塊1的PWM寄存器
- sfr PCA_PWM2 = 0xf4; //PCA模塊2的PWM寄存器
- void main()
- P0M0 = 0x00;
- P0M1 = 0x00;
- P1M0 = 0x00;
- P1M1 = 0x00;
- P2M0 = 0x00;
- P2M1 = 0x00;
- P3M0 = 0x00;
- P3M1 = 0x00;
- P4M0 = 0x00;
- P4M1 = 0x00;
- P5M0 = 0x00;
- P5M1 = 0x00;
- P6M0 = 0x00;
- P6M1 = 0x00;
- P7M0 = 0x00;
- P7M1 = 0x00;
- ACC = P_SW1;
- ACC &= ~(CCP_S0 | CCP_S1); //CCP_S0=0 CCP_S1=0
- P_SW1 = ACC; //(P1.2/ECI, P1.1/CCP0, P1.0/CCP1, P3.7/CCP2)
- // ACC = P_SW1;
- // ACC &= ~(CCP_S0 | CCP_S1); //CCP_S0=1 CCP_S1=0
- // ACC |= CCP_S0; //(P3.4/ECI_2, P3.5/CCP0_2, P3.6/CCP1_2, P3.7/CCP2_2)
- // P_SW1 = ACC;
- // ACC = P_SW1;
- // ACC &= ~(CCP_S0 | CCP_S1); //CCP_S0=0 CCP_S1=1
- // ACC |= CCP_S1; //(P2.4/ECI_3, P2.5/CCP0_3, P2.6/CCP1_3, P2.7/CCP2_3)
- // P_SW1 = ACC;
- CCON = 0; //初始化PCA控制寄存器
- //PCA定時器停止
- //清除CF標(biāo)志
- //清除模塊中斷標(biāo)志
- CL = 0; //復(fù)位PCA寄存器
- CH = 0;
- CMOD = 0x02; //設(shè)置PCA時鐘源
- //禁止PCA定時器溢出中斷
- PCA_PWM0 = 0x00; //PCA模塊0工作于8位PWM
- CCAP0H = CCAP0L = 0x20; //PWM0的占空比為87.5% ((100H-20H)/100H)
- CCAPM0 = 0x42; //PCA模塊0為8位PWM模式
- PCA_PWM1 = 0x40; //PCA模塊1工作于7位PWM
- CCAP1H = CCAP1L = 0x20; //PWM1的占空比為75% ((80H-20H)/80H)
- CCAPM1 = 0x42; //PCA模塊1為7位PWM模式
- PCA_PWM2 = 0x80; //PCA模塊2工作于6位PWM
- CCAP2H = CCAP2L = 0x20; //PWM2的占空比為50% ((40H-20H)/40H)
- CCAPM2 = 0x42; //PCA模塊2為6位PWM模式
- CR = 1; //PCA定時器開始工作
- while (1);
復(fù)制代碼 |
