123 132 213 231 312 321 這六個數(shù)字信息,
TTL通信輸入51單片機(jī)后,
顯示到4位串行595數(shù)碼管的程序如何寫?
并且串口通信和數(shù)碼管顯示的程序單獨運(yùn)行都沒問題。
關(guān)鍵是怎樣才能組合到一起用???
下面是數(shù)碼管顯示代碼,要在程序里改動j=231;switch(j)才能顯示。
#include <AT89X51.H>
unsigned char code fseg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char code segbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
unsigned char disbuf[4]={0,0,0,0};
// 函數(shù)原形定義
void main (void); // 主函數(shù)
void LED4_Display (void); // LED顯示
void LED_OUT(uchar X); // LED單字節(jié)串行移位函數(shù)
unsigned char code LED_0F[]; // LED字模表
sbit DIO = P1^0; //串行數(shù)據(jù)輸入
sbit RCLK = P1^1; //時鐘脈沖信號——上升沿有效
sbit SCLK = P1^2; //打入信號————上升沿有效
// 全局變量
uchar LED[8]; //用于LED的8位顯示緩存
// 主程序
void main (void)
LED[0]=1;
LED[1]=2;
LED[2]=3;
LED4_Display ();
unsigned char code *led_table; // 查表指針
uchar i;
uchar j;
j=231; // *****
switch(j)
case 123: //顯示第1位
led_table = LED_0F + LED[0];
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//顯示第2位
led_table = LED_0F + LED[1];
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//顯示第3位
led_table = LED_0F + LED[2];
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;break;
case 132: //顯示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//顯示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//顯示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;break;
case 213: //顯示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//顯示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;
//顯示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;break;
case 231: //顯示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;
//顯示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//顯示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;break;
case 312: //顯示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//顯示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;
//顯示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;break;
case 321: //顯示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;
//顯示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//顯示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;break;
/* //顯示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//顯示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//顯示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;*/
uchar i;
for(i=8;i>=1;i--)
if (X&0x80) DIO=1; else DIO=0;
X<<=1;
SCLK = 0;
SCLK = 1;
unsigned char code LED_0F[] =
{// 0 1 2 3 4 5 6 7 8 9 A b C d E F -
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x8C,0xBF,0xC6,0xA1,0x86,0xFF,0xbf
下面就是簡單的串口通信程序了。
* 串口通信實驗 *
實現(xiàn)現(xiàn)象:下載程序后打開串口調(diào)試助手,將波特率設(shè)置為4800,選擇發(fā)送的數(shù)據(jù)就可以顯示
在串口助手上。
注意事項:無。
#include "reg52.h" //此文件中定義了單片機(jī)的一些特殊功能寄存器
typedef unsigned int u16; //對數(shù)據(jù)類型進(jìn)行聲明定義
typedef unsigned char u8;
* 函數(shù)名 :UsartInit()
* 函數(shù)功能 :設(shè)置串口
* 輸入 : 無
* 輸出 : 無
void UsartInit()
SCON=0X50; //設(shè)置為工作方式1
TMOD=0X20; //設(shè)置計數(shù)器工作方式2
PCON=0X80; //波特率加倍
TH1=0XF3; //計數(shù)器初始值設(shè)置,注意波特率是4800的
TL1=0XF3;
ES=1; //打開接收中斷
EA=1; //打開總中斷
TR1=1; //打開計數(shù)器
* 函 數(shù) 名 : main
* 函數(shù)功能 : 主函數(shù)
* 輸 入 : 無
* 輸 出 : 無
UsartInit(); // 串口初始化
while(1);
* 函數(shù)名 : Usart() interrupt 4
* 函數(shù)功能 : 串口通信中斷函數(shù)
* 輸入 : 無
* 輸出 : 無
void Usart() interrupt 4
u8 receiveData;
receiveData=SBUF;//出去接收到的數(shù)據(jù)
RI = 0;//清除接收中斷標(biāo)志位
SBUF=receiveData;//將接收到的數(shù)據(jù)放入到發(fā)送寄存器
while(!TI); //等待發(fā)送數(shù)據(jù)完成
TI=0; //清除發(fā)送完成標(biāo)志位
求大佬指點怎樣把兩個程序合并。。。!- #include <AT89X51.H>
- unsigned char code fseg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- unsigned char code segbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
- unsigned char disbuf[4]={0,0,0,0};
- // 函數(shù)原形定義
- #define uchar unsigned char
- void main (void); // 主函數(shù)
- void LED4_Display (void); // LED顯示
- void LED_OUT(uchar X); // LED單字節(jié)串行移位函數(shù)
- unsigned char code LED_0F[]; // LED字模表
- sbit DIO = P1^0; //串行數(shù)據(jù)輸入
- sbit RCLK = P1^1; //時鐘脈沖信號——上升沿有效
- sbit SCLK = P1^2; //打入信號————上升沿有效
- // 全局變量
- uchar LED[8]; //用于LED的8位顯示緩存
- // 主程序
- void main (void)
- LED[0]=1;
- LED[1]=2;
- LED[2]=3;
- while(1)
- LED4_Display ();
- unsigned char code *led_table; // 查表指針
- uchar i;
- uchar j;
- j=231; // *****
- switch(j)
- case 123: //顯示第1位
- led_table = LED_0F + LED[0];
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x04);
- RCLK = 0;
- RCLK = 1;
- //顯示第2位
- led_table = LED_0F + LED[1];
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x02);
- RCLK = 0;
- RCLK = 1;
- //顯示第3位
- led_table = LED_0F + LED[2];
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x01);
- RCLK = 0;
- RCLK = 1;break;
- case 132: //顯示第1位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x02);
- RCLK = 0;
- RCLK = 1;
- //顯示第2位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x04);
- RCLK = 0;
- RCLK = 1;
- //顯示第3位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x01);
- RCLK = 0;
- RCLK = 1;break;
- case 213: //顯示第1位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x04);
- RCLK = 0;
- RCLK = 1;
- //顯示第2位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x01);
- RCLK = 0;
- RCLK = 1;
- //顯示第3位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x02);
- RCLK = 0;
- RCLK = 1;break;
- case 231: //顯示第1位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x01);
- RCLK = 0;
- RCLK = 1;
- //顯示第2位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x04);
- RCLK = 0;
- RCLK = 1;
- //顯示第3位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x02);
- RCLK = 0;
- RCLK = 1;break;
- case 312: //顯示第1位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x02);
- RCLK = 0;
- RCLK = 1;
- //顯示第2位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x01);
- RCLK = 0;
- RCLK = 1;
- //顯示第3位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x04);
- RCLK = 0;
- RCLK = 1;break;
- case 321: //顯示第1位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x01);
- RCLK = 0;
- RCLK = 1;
- //顯示第2位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x02);
- RCLK = 0;
- RCLK = 1;
- //顯示第3位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x04);
- RCLK = 0;
- RCLK = 1;break;
- /* //顯示第1位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x04);
- RCLK = 0;
- RCLK = 1;
- //顯示第2位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x02);
- RCLK = 0;
- RCLK = 1;
- //顯示第3位
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x01);
- RCLK = 0;
- RCLK = 1;*/
- uchar i;
- for(i=8;i>=1;i--)
- if (X&0x80) DIO=1; else DIO=0;
- X<<=1;
- SCLK = 0;
- SCLK = 1;
- unsigned char code LED_0F[] =
- {// 0 1 2 3 4 5 6 7 8 9 A b C d E F -
- 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x8C,0xBF,0xC6,0xA1,0x86,0xFF,0xbf
