查看: 3748|回復(fù): 3
單片機(jī)小白求教問(wèn)題—數(shù)碼管不顯示
ID:675269 發(fā)表于 2022-3-6 21:15 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
問(wèn)題:數(shù)碼管不顯示問(wèn)題
情況:加上Fuzzy模塊的函數(shù)后,數(shù)碼管不顯示
  1. void display_service();
  2. unsigned char ad_result = 0,ControlOut=0; // 0-255
  3. int ad_show = 0;
  4. void main()
  5. {
  6.         while(1)
  7.         {
  8.                 ad_result = ADC_Conv();
  9.                 ad_show = ad_result;  //5v - 500  255-份
  10.                 display_service();
  11.                 Display();
  12.                 ControlOut = Control_Fuzzy(ad_result);  //如果注釋掉這行代碼,不調(diào)用這個(gè)函數(shù)就會(huì)正常
  13.                 DAC0832_Conv(ControlOut);
  14.         }
  15. }
  16. void display_service()
  17. {
  18.         LEDBUF[0]=ad_show/1000%100;
  19.         LEDBUF[1]=ad_show/100%10;
  20.         LEDBUF[2]=ad_show/10%10;
  21.         LEDBUF[3]=ad_show%10;
  22. }
fuzzy模塊代碼
  1. const float code WaterLevel_FuzzyControl_table[7][7]=
  2.     // NL NM NS ZO PS PM PL
  3. {
  4.         3, 3, 3, 3, 2, 1, 0, //NL
  5.         3, 3, 3, 2, 1, 0, 0, //NM
  6.         3, 3, 2, 0, 0, 0, 0, //NS
  7.         0, 0, 0, 0, 0, 0, 0, //ZO
  8.         0, 0, 0, 0,-2,-3,-3, //PS
  9.         0, 0,-1,-2,-3,-3,-3, //PM
  10.         0,-1,-2,-3,-3,-3,-3        //PL
  11. };
  12. /*
  13. 函數(shù)名稱:隸屬度計(jì)算函數(shù)
  14. 參數(shù):x為清晰值對(duì)應(yīng)的模糊值,x0,x1,x2為端點(diǎn)中點(diǎn)值
  15.           a,b,c為過(guò)程隸屬度,u為最終隸屬度
  16. */
  17. float Membership( char x0, char x1, char x2, float x)
  18. {
  19.         float a,b,c,u;//r,
  20.         //r = x1-x0;                                        //相似三角形算法
  21.         //if(r == 0)
  22.         //        r = 0.001;                                //保證分母不為零
  23.         a = (x-x0)/(x1-x0);//r;
  24.         //r = x2-x1;
  25.         //if(r == 0)
  26.         //        r = 0.001;
  27.         b = (x2-x)/(x2-x1);//r;
  28. /*  tanx算法  tanx=1
  29.     a = x-x0;
  30.         b = x2-x;
  31. */
  32.
  33.         if(a <= b)                                        //比較取小
  34.                 c = a;
  35.         else
  36.                 c = b;
  37.         if(c < 0)                                        //若隸屬度小于零,則強(qiáng)制為零
  38.                 u = 0;                                        //隸屬度為什么等于零
  39.         else
  40.                 u = c;
  41.         return u;                                        //返回隸屬度
  42. }
  43. /*
  44. 函數(shù)名稱:控制函數(shù)
  45. 參數(shù):入口參數(shù)WL;WLE水位偏差;WLEC偏差變化;
  46.           WLFlag水位控制標(biāo)志;WL0上一次的水位值;
  47.           WLE0為上一次的水位偏差;WLOut為累計(jì)的水位控制輸出;
  48.           K為水位控制輸出比例因子。
  49. */
  50. unsigned int Control_Fuzzy(unsigned char WL)
  51. {
  52.         /*float ControlOut;
  53.         ControlOut = WL;*/
  54.         static unsigned char WL0 = 0, WLE0 = 0 ;//WLOut = 127 ,;
  55.         float ControlOut,WLE,WLEC;//,CG = 0
  56.         float code K = 2.67;
  57.         char i,j;//,k = 0
  58.         static char WLFlag = 0;
  59.         float MembershipE[7],MembershipEE[7];//        //定義隸屬度值緩沖區(qū)
  60.         if(WLFlag == 1) goto FC;                //滿足條件,進(jìn)入模糊控子程序
  61. //*************水位異常報(bào)警**************
  62.         if(WL <= 106)                                //水位超低
  63.                 {
  64.                 if(WL0 == 0)                        //第一次進(jìn)入程序不進(jìn)行控制
  65.                         {
  66.                                 ControlOut = 0;
  67.                                 WL0 = WL;
  68.                         }
  69.                 else                                        //否則報(bào)警
  70.                         {
  71.                                 ControlOut = 0xff;
  72.                                 //Alarm();
  73.                         }
  74.                 }
  75.         else if (WL >= 150)                        //水位超高
  76.                 {
  77.                 if(WL0 == 0)                        //第一次進(jìn)入程序不進(jìn)行控制
  78.                         {
  79.                                 ControlOut = 0;
  80.                                 WL0 = WL;
  81.                         }
  82.                 else                                        //否則報(bào)警
  83.                         {
  84.                                 ControlOut = 0;
  85.                                 //Alarm();
  86.                         }
  87.                 }
  88. //爆管與虛假水位報(bào)警
  89.         WLE = WL - WL0;                                //計(jì)算水位偏差及其變化
  90.         WLEC = WLE - WLE0;
  91.         WL0 = WL;
  92.         if(WLEC*10 <= -1)                        //爆管
  93.                 {
  94.                         ControlOut = 0xff;
  95.                         //Alarm();
  96.                 }
  97.         else if(WLEC*10 >= 3)
  98.                 {
  99.                         ControlOut = 0;                //虛假水位
  100.                         //Alarm();
  101.                 }
  102.         else
  103.         FC:
  104.                 {
  105.                         if(WLFlag == 0)                                //第一次進(jìn)入程序不進(jìn)行控制
  106.                                 {
  107.                                         WLFlag = 1;
  108.                                         //K = 2.67;
  109.                                         WLE = (WL - 127)*0.035;                //論域轉(zhuǎn)換
  110.                                         WL0 = WL;
  111.                                         WLE = WLE0;
  112.                                         ControlOut = 0;
  113.                                 }
  114.                         else
  115.                                 {
  116.                                         WLFlag = 1;
  117.                                         WLE = (WL - 127)*0.035;                //論域轉(zhuǎn)換
  118.                                         WL0 = WL;
  119.                                         WLEC = (WLE0 - WLE)*0.024;
  120.                                         WLEC = WLE;
  121.                                 }
  122.         //**************計(jì)算WLE的隸屬度************
  123.                 MembershipE[1] = Membership(-4,-3,-2,WLE);
  124.                 MembershipE[2] = Membership(-3,-2,-1,WLE);
  125.                 MembershipE[3] = Membership(-2,-1,-0,WLE);
  126.                 MembershipE[4] = Membership(-1,-0,1,WLE);
  127.                 MembershipE[5] = Membership(0,1,2,WLE);
  128.                 MembershipE[6] = Membership(1,2,3,WLE);
  129.                 MembershipE[7] = Membership(2,3,4,WLE);
  130.         //**************計(jì)算WLEC的隸屬度************
  131.                 MembershipEE[1] = Membership(-4,-3,-2,WLEC);
  132.                 MembershipEE[2] = Membership(-3,-2,-1,WLEC);
  133.                 MembershipEE[3] = Membership(-2,-1,-0,WLEC);
  134.                 MembershipEE[4] = Membership(-1,-0,1,WLEC);
  135.                 MembershipEE[5] = Membership(0,1,2,WLEC);
  136.                 MembershipEE[6] = Membership(1,2,3,WLEC);
  137.                 MembershipEE[7] = Membership(2,3,4,WLEC);
  138.
  139.         //**************求輸出************
  140.                 for(i=1;i<8;i++)
  141.                 {
  142.                         if(MembershipE[i]>0)
  143.                                 {
  144.                                         i=i;
  145.                                 }
  146.                 }
  147.                 for(j=1;j<8;j++)
  148.                 {
  149.                         if(MembershipEE[i]>0)
  150.                                 {
  151.                                         j=j;
  152.                                 }
  153.                 }
  154.                 ControlOut = WaterLevel_FuzzyControl_table[i][j]*K*16+127;        //計(jì)算結(jié)果并且轉(zhuǎn)化論域
  155.                 }
  156.                 return ControlOut;
  157. }
代碼仿真.zip
149 KB, 下載次數(shù): 5
相關(guān)帖子
ID:415064 發(fā)表于 2022-3-7 08:52 | 只看該作者
要么死循環(huán),要么崩了
ID:675269 發(fā)表于 2022-3-7 15:31 | 只看該作者
wojiaoguogai 發(fā)表于 2022-3-7 08:52
要么死循環(huán),要么崩了
謝謝解答,我模擬跑了一遍,發(fā)現(xiàn)每次經(jīng)過(guò)fuzzy模塊出來(lái)后,再display后有又從第一個(gè)switch語(yǔ)句開(kāi)始。死循環(huán)了,不知道是什么原因,現(xiàn)在我用定時(shí)中斷刷新display后可以顯示了。
ID:161164 發(fā)表于 2022-3-7 17:37 | 只看該作者
fuzzy.c :
行64:float MembershipE[7],MembershipEE[7];//        //定義隸屬度值緩沖區(qū)
行128~144:
[]內(nèi)只能是0~6,MembershipEE[7] 指向了不知明地址
當(dāng)中可能包含了display內(nèi)的i
而當(dāng)你把display放進(jìn)定時(shí)中斷內(nèi)
display內(nèi)的i的地址改變了
于是顯示就正常了
但依然存某地址不斷被MembershipEE[7] = Membership(2,3,4,WLEC);覆寫(xiě)的危險(xiǎn)
而且display內(nèi)的i應(yīng)定義為靜態(tài)變數(shù)
