查看: 2791|回復(fù): 0
MAX30100模塊介紹
ID:608001 發(fā)表于 2019-9-5 16:32 | 顯示全部樓層 |閱讀模式
希望可以對大家有用。!
General Description
The MAX30100 is an integrated pulse oximetry and heart-rate monitor sensor solution. It combines two LEDs, a
photodetector, optimized optics, and low-noise analog signal processing to detect pulse oximetry and heart-rate signals.
The MAX30100 operates from 1.8V and 3.3V power sup-
plies and can be powered down through software with negligible standby current, permitting the power supply to remain connected at all times.
MAX30100.pdf
874.83 KB, 下載次數(shù): 7, 下載積分: 黑幣 -5
英文完整版
