查看: 9451|回復(fù): 25
Proteus仿真C51單片機(jī)的電子密碼鎖程序 24C02C
回帖獎勵 10 黑幣 回復(fù)本帖可獲得 1 黑幣獎勵! 每人限 1 次
ID:751649 發(fā)表于 2020-5-22 22:41 | 顯示全部樓層 |閱讀模式
本帖最后由 lxl_51h 于 2020-5-22 23:14 編輯
分享電子密碼鎖項目
第一次發(fā)帖,分享電子密碼鎖項目。關(guān)鍵代碼段注釋詳盡。
仿真視頻如下連接:
Proteus仿真電路圖
Proteus仿真電路圖
工程結(jié)構(gòu)
工程結(jié)構(gòu)
源碼文件
源碼文件
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include "lxl_24C02C.h"
  4. #include "uart.h"
  5. #include "LCD1602.h"
  6. #include <keypad44.h>
  7. sbit greenled=P2^3;                                                //Enter the right passwords,green led will lighting.
  8. sbit lock=P2^4;        //Enter the right passwords,electronic lock will unlock.
  9. sbit redled=P2^5;                                                        //Enter the wrong passwords,red led will lighting.
  10. void show_base_infromation()        //show something personal information on the screen of LCD1206.just delay for a moment than cleanning all screen.
  11. {
  12.         uchar i;
  13.         LCMDisplayString(0,0,"Design:LiXinLong");
  14.         LCMDisplayString(1,0,"My ID:208171421");
  15.         for(i=0;i<4;i++)keypad_delay(65535);                //delay for a moment
  16.         LCMClear();        //clean all screen.
  17. }
  18. void set_init_password()                        //set users' initialize passwords.
  19. {
  20.         Master_writeByte(1,1);                        //The user 1 ,password:0001,password saved in register 1 of 24C02C.
  21.         Master_writeByte(2,2);                        //The user 2 ,password:0002,password saved in register 2 of 24C02C.
  22.         Master_writeByte(3,3);                        //The user 3 ,password:0003,password saved in register 3 of 24C02C.
  23. }
  24. int get_user_password(uchar i)//Get users' password ,i is the register number of the specific user.
  25. {
  26.         int read=Master_readByte(i);//read the appointed register.
  27.         return _cror_(read,8);                        //translated the value to int,and return the value.
  28. }
  29. void main()
  30. {
  31.
  32.         uchar presstimes=0;                                        //the register keep user's press times,maximum are 4,because the munber of password bits are defined as 4.
  33.         uchar enter_times=0;                                //if user enter wrong password ,the register keep user's press times of "Enter",maximum are 3,beyond 3 account will locked(forbid to enter any number.).
  34.         bit changepswd_state=0;                        //flage bit of user pressed "Reset password" key,1:pressed,0:not pressed.
  35.         bit change_use1=0;                                        //flage bit of user1 entered the old password correctly,and input the new passwords done.
  36.         bit change_use2=0;                                        //*****************************similar to change_use1***********************************
  37.         bit change_use3=0;                                        //*****************************similar to change_use1***********************************
  38.         bit beyond3times=1;                                        //flage bit of users' entered the wrong password beyond 3 times.1: not beyond,0:beyond.
  39.
  40.         int readkeypad;        //the register keep the keypad return value.
  41.         int keypadvalue=0;        //the register keep the value when 4 times pressed.
  42.         int press1,press2,press3,press4;                                        //press1:the value of 1st keypad return value multiple oppointed scale.press2-3 are similar to this.
  43.         UartInit();        //initialize the USART for printf() to debug.
  44.         LCMInit();        //initialize the LCD1206.
  45.         printf("\nshow some \npersonal \ninfromation!\n");
  46.         show_base_infromation();
  47.         printf("\nplease enter your\npassword\n");
  48.         keypad_delay(65535);
  49.         set_init_password();
  50.         LCMDisplayString(0,0,"Input pswd:");
  51.         LCMDisplayString(1,0,"You error 0 Time");
  52.
  53.         while(1)
  54.         {
  55.                 readkeypad=key_scan();
  56.                 if(((readkeypad<10)||(readkeypad==14)||(readkeypad==13))&&beyond3times)//allowed press 0-9,"clean" or "enter" when account not lock(wrong password not beyond 3 times).
  57.                 {
  58.                         presstimes=presstimes+1;
  59.                         switch(presstimes)
  60.                         {
  61.                                 case 1:        //the 1st bit of 4bits password.
  62.                                         {
  63.                                                 press1=readkeypad*1000;
  64.                                                 LCMDisplayString(0,11,"*");
  65.                                                 printf("pressed %d\n",readkeypad);
  66.                                         }break;
  67.                                 case 2:        //the 2nd bit of 4bits password.
  68.                                         {
  69.                                                 press2=readkeypad*100;
  70.                                                 LCMDisplayString(0,11,"**");
  71.                                                 printf("pressed %d\n",readkeypad);
  72.                                         }break;
  73.                                 case 3:        //the 3rd bit of 4bits password.
  74.                                         {
  75.                                                 press3=readkeypad*10;
  76.                                                 LCMDisplayString(0,11,"***");
  77.                                                 printf("pressed %d\n",readkeypad);
  78.                                         }break;
  79.                                 case 4:        //the 4th bit of 4bits password.
  80.                                         {
  81.                                                 press4=readkeypad;
  82.                                                 LCMDisplayString(0,11,"****");
  83.                                                 printf("pressed %d\n\n",readkeypad);
  84.                                         }break;
  85.                                 default:break;
  86.                         }
  87.                 }
  88.
  89.                 if((presstimes<=5)&&(readkeypad>11))                //Entered 4bits password,checking whether "Enter" or "Clean" pressed.
  90.                         {
  91.                                 switch(readkeypad)
  92.                                 {
  93.                                         case 14:        //pressed 'Enter' key
  94.                                         {
  95.                                                 keypadvalue=press1+press2+press3+press4;
  96.                                                 presstimes=0;
  97.                                                 if(enter_times<3)LCMDisplayString(0,11,"    ");
  98.                                                 if(change_use1)
  99.                                                         {
  100.        Master_writeByte(1,keypadvalue);
  101.        change_use1=0;
  102.        LCMClear();
  103.        LCMDisplayString(0,0,"Input pswd:");
  104.        LCMDisplayString(1,0,"You error 0 Time");
  105.                                                         }
  106.                                                 if(change_use2)
  107.                                                         {
  108.        Master_writeByte(2,keypadvalue);
  109.        change_use2=0;LCMClear();
  110.        LCMDisplayString(0,0,"Input pswd:");
  111.        LCMDisplayString(1,0,"You error 0 Time");
  112.                                                         }
  113.                                                 if(change_use3)
  114.                                                         {
  115.        Master_writeByte(3,keypadvalue);
  116.        change_use3=0;
  117.        LCMClear();
  118.        LCMDisplayString(0,0,"Input pswd:");
  119.        LCMDisplayString(1,0,"You error 0 Time");
  120.                                                         }//printf("pswd changed!\n");
  121.
  122.                                                 if((keypadvalue==get_user_password(1))||(keypadvalue==get_user_password(2))||(keypadvalue==get_user_password(3)))//matching password saved in 24C02C,only password are correct can match successful.
  123.                                                 {
  124.                                                         greenled=0;
  125.                                                         lock=0;
  126.                                                         redled=1;
  127.                                                         printf("\nWelcome You to\nGo Home!\n");
  128.                                                         enter_times=0;
  129.                                                         LCMDisplayChar(1,10,'0');
  130.                                                 }else        //match password failed.
  131.                                                 {
  132.                                                         greenled=1;
  133.                                                         lock=1;
  134.                                                         redled=0;
  135.                                                         printf("\nPasswords error\nplease try\nagain!\n");
  136.                                                         enter_times++;
  137.                                                         switch(enter_times)                                                //show times of enter wrong password.
  138.                                                         {
  139.        case 0:LCMDisplayChar(1,10,'0');break;
  140.        case 1:LCMDisplayChar(1,10,'1');break;
  141.        case 2:LCMDisplayChar(1,10,'2');break;
  142.        default:        //enter wrong password 3 times,lock the account!
  143.        {
  144.        beyond3times=0;
  145.        LCMClear();
  146.        LCMDisplayString(0,0,"Account Locked!");
  147.        LCMDisplayString(1,0,"Call 1401856153");
  148.        printf("\nInput error\nbeyond 3 times\nthe account\nlocked!\nplease Contact \nadministrator\n");
  149.        }break;
  150.                                                         }
  151.                                                 }
  152.                                         }break;
  153.                                         case 13:        //press 'Clean' key,clean all entered numbers.
  154.                                         {
  155.                                                 presstimes=0;
  156.                                                 LCMDisplayString(0,11,"    ");
  157.                                                 greenled=1;
  158.                                                 lock=1;
  159.                                                 printf("\nPressed Clean!\n");
  160.
  161.                                         }break;
  162.                                         default:break;
  163.                                 }
  164.
  165.                         }
  166.
  167.                         if((presstimes==5)&&(readkeypad<10))//if 5th entered is a number of 0-9.clean all entered passwords,because passwords were designed 4bits.
  168.                         {
  169.                                 presstimes=0;
  170.                                 LCMDisplayString(0,11,"    ");
  171.                                 printf("\nPlease Reenter Your\nPassword\n");
  172.                         }
  173.
  174.                         if(readkeypad==12)        //Press "reset password" key,enter to reset passwords process while loop.
  175.                         {
  176.                                 changepswd_state=1;
  177.                                 LCMClear();
  178.                                 LCMDisplayString(0,0,"Enter Old pswd:");
  179.                                 printf("\nEnter your old\npswd now:\n");
  180.                         }else changepswd_state=0;
  181.
  182.                         while(changepswd_state)                                                        //Reset passwords while loop
  183.                         {
  184.                                 readkeypad=key_scan();
  185.                                         if((readkeypad<10)||(readkeypad==14)||(readkeypad==13))
  186.                                         {
  187.                                                 presstimes=presstimes+1;
  188.                                                 switch(presstimes)
  189.                                                 {
  190.                                                         case 1:
  191.        {
  192.        press1=readkeypad*1000;
  193.        LCMDisplayString(1,0,"*");
  194.        printf("pressed %d\n",readkeypad);
  195.        }break;
  196.                                                         case 2:
  197.        {
  198.        press2=readkeypad*100;
  199.        LCMDisplayString(1,0,"**");
  200.        printf("pressed %d\n",readkeypad);
  201.        }break;
  202.                                                         case 3:
  203.        {
  204.        press3=readkeypad*10;
  205.        LCMDisplayString(1,0,"***");
  206.        printf("pressed %d\n",readkeypad);
  207.        }break;
  208.                                                         case 4:
  209.        {
  210.        press4=readkeypad;
  211.        LCMDisplayString(1,0,"****");
  212.        printf("pressed %d\n\n",readkeypad);
  213.        }break;
  214.                                                         default:break;
  215.                                                 }
  216.                                         }
  217.
  218.                                         if((presstimes<=5)&&(readkeypad>11))
  219.                                         {
  220.                                                 switch(readkeypad)
  221.                                                 {
  222.                                                         case 14:        //press 'enter' key
  223.        {
  224.        keypadvalue=press1+press2+press3+press4;
  225.        presstimes=0;
  226.        LCMDisplayString(1,0,"    ");
  227.        if(keypadvalue==get_user_password(1))                                //matched user1's passwords.
  228.        {
  229.        LCMClear();
  230.        LCMDisplayString(1,0,"Enter New pswd:");
  231.        presstimes=0;
  232.        change_use1=1;
  233.        changepswd_state=0;
  234.        }else if(keypadvalue==get_user_password(2))        //matched user2's passwords.
  235.        {
  236.        LCMClear();
  237.        LCMDisplayString(1,0,"Enter New pswd:");
  238.        presstimes=0;
  239.        change_use2=1;
  240.        changepswd_state=0;
  241. ……………………
  242. …………限于本文篇幅 余下代碼請從51黑下載附件…………
仿真文件
仿真文件
PASSWORDLOCK.zip (642.67 KB, 下載次數(shù): 220)
admin + 50 共享資料的黑幣獎勵!
相關(guān)帖子
ID:524698 發(fā)表于 2020-5-28 15:40 | 顯示全部樓層
特別好用,有紅外功能就好了
ID:755919 發(fā)表于 2020-5-28 16:15 | 顯示全部樓層
特別好用,收藏收藏,感謝分享
ID:763926 發(fā)表于 2020-5-29 03:34 | 顯示全部樓層
感覺不錯啊,樓樓,就是不知道用起來如何,一會下載試一試
ID:302325 發(fā)表于 2020-6-1 01:54 | 顯示全部樓層
感謝分享
ID:766915 發(fā)表于 2020-6-8 21:40 | 顯示全部樓層
樓主這個有i2c嗎
ID:751649 發(fā)表于 2020-6-9 10:20 | 顯示全部樓層
項目樹中的“l(fā)xl_24C02C.c”就是軟件模擬I2C通信協(xié)議
ID:774738 發(fā)表于 2020-6-10 10:13 | 顯示全部樓層
不錯,我先試試能不能行
ID:775010 發(fā)表于 2020-6-11 21:48 | 顯示全部樓層
感謝大佬分享
ID:768868 發(fā)表于 2020-6-14 14:33 | 顯示全部樓層
如果把C52改成C51得話這個得怎么改啊
ID:776555 發(fā)表于 2020-6-14 15:57 | 顯示全部樓層
ID:778494 發(fā)表于 2020-6-14 17:02 | 顯示全部樓層
感謝分享,有個想法,如果那個輸入部分換成那種獨立按鍵的怎么樣
ID:751649 發(fā)表于 2020-6-15 08:11 | 顯示全部樓層
sdsfsade 發(fā)表于 2020-6-14 15:57
把<reg52.h>改一下就行了。
ID:751649 發(fā)表于 2020-6-15 08:12 | 顯示全部樓層
jiafangyuan 發(fā)表于 2020-6-14 17:02
可以的,本質(zhì)上沒變,僅僅是外觀變了
ID:777893 發(fā)表于 2020-6-15 08:57 | 顯示全部樓層
這個真的可以牛批
ID:781759 發(fā)表于 2020-6-24 11:23 | 顯示全部樓層
謝謝樓主
ID:789099 發(fā)表于 2020-6-25 00:59 | 顯示全部樓層
感謝樓主
ID:495287 發(fā)表于 2020-6-27 13:46 | 顯示全部樓層
馬克,后面再仔細(xì)學(xué)習(xí),謝謝分享。
ID:782689 發(fā)表于 2020-6-29 02:34 | 顯示全部樓層
lxl_51h 發(fā)表于 2020-6-15 08:11
把改一下就行了。
改完之后可以直接實現(xiàn)這個功能嗎?新手求告知
ID:751649 發(fā)表于 2020-6-29 17:36 | 顯示全部樓層
aaabbbcd 發(fā)表于 2020-6-29 02:34
項目中未用到定時器T和中斷,所以51系列的微控器都可以實現(xiàn)此功能。僅僅改一下頭文件就信了。
ID:795233 發(fā)表于 2020-7-3 16:53 | 顯示全部樓層
不會用啊,誰能教教我
ID:771985 發(fā)表于 2020-8-7 17:53 | 顯示全部樓層
樓主,這程序是不是可以實現(xiàn)多個密碼開鎖
ID:595237 發(fā)表于 2020-8-8 10:09 | 顯示全部樓層
4位密碼?
ID:1097230 發(fā)表于 2023-10-25 12:36 | 顯示全部樓層
真的很牛的!
ID:1063561 發(fā)表于 2023-11-5 09:18 | 顯示全部樓層
MAAAAAARK學(xué)習(xí),謝謝分享。
ID:1103460 發(fā)表于 2023-12-9 21:01 | 顯示全部樓層
宿舍可以使用嗎
