查看: 2692|回復: 1
stm32f407芯片模擬IIC
ID:954547 發(fā)表于 2021-7-29 17:45 | 顯示全部樓層 |閱讀模式
#include <stdio.h>
#include "stm32f4xx.h"
#include "sys.h"
#include <string.h>
static GPIO_InitTypeDef                GPIO_InitStruct;
static NVIC_InitTypeDef                NVIC_InitStructure;
static USART_InitTypeDef         USART_InitStructure;
void delay_us(uint32_t nus)
        SysTick->CTRL = 0;                                                        // 關閉系統(tǒng)定時器
        SysTick->LOAD = nus*(SystemCoreClock/1000000);         // nus *1us延時,這個計數(shù)值
        SysTick->VAL = 0;                                                         // 清空標志位
        SysTick->CTRL = 5;                                                         // 使能系統(tǒng)定時器工作,時鐘源為系統(tǒng)時鐘168MHz
        while ((SysTick->CTRL & 0x00010000)==0);        // 檢查CTRL寄存器的16bit是否置1,若置1,就代表計數(shù)完畢
void delay_ms(uint32_t nms)
        while(nms--)
                SysTick->LOAD = (SystemCoreClock/1000);         // 1ms延時,這個計數(shù)值
int fputc(int ch,FILE *file)
        USART_SendData(USART1,ch);
        //等待發(fā)送完畢
        while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);
        return ch;
void usart1_init(uint32_t baud)
        //端口A硬件時鐘使能
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        //串口1硬件時鐘使能
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
        //配置硬件,配置GPIO,端口A,第9 10引腳
        GPIO_InitStruct.GPIO_Pin=GPIO_Pin_9|GPIO_Pin_10;//第9 10引腳
        GPIO_InitStruct.GPIO_Mode=GPIO_Mode_AF;                        //復用功能模式
        GPIO_InitStruct.GPIO_Speed=GPIO_High_Speed;                //引腳高速工作,收到指令立即工作;缺點:功耗高
        GPIO_InitStruct.GPIO_OType=GPIO_OType_PP;                //增加輸出電流的能力
        GPIO_InitStruct.GPIO_PuPd=GPIO_PuPd_NOPULL;                //不需要上下拉電阻
        GPIO_Init(GPIOA,&GPIO_InitStruct);
        //將PA9引腳連接到串口1
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_USART1);
        //將PA10引腳連接到串口1
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1);
        USART_InitStructure.USART_BaudRate = baud;                                        //波特率
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;        //8位數(shù)據(jù)位
        USART_InitStructure.USART_StopBits = USART_StopBits_1;                //1個停止位
        USART_InitStructure.USART_Parity = USART_Parity_No;                        //無校驗位
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//不需要流控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //允許串口接收和發(fā)送數(shù)據(jù)
        USART_Init(USART1, &USART_InitStructure);
        //接收數(shù)據(jù)后觸發(fā)中斷
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
        /* 配置串口1 */
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        USART_Cmd(USART1, ENABLE);
#define SCL_W        PBout(8)
#define SDA_W        PBout(9)
#define SDA_R        PBin(9)
void at24c02_init(void)
        //使能端口B的硬件時鐘
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
        GPIO_InitStruct.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9;                        //第 8 9 個引腳
        GPIO_InitStruct.GPIO_Mode=GPIO_Mode_OUT;                //輸出模式
        GPIO_Init(GPIOB,&GPIO_InitStruct);
        //只要是輸出模式,肯定會有初始電平狀態(tài),看時序圖,空閑狀態(tài)為高電平
        SCL_W=1;
        SDA_W=1;
void sda_pin_mode(GPIOMode_TypeDef pin_mode)
        //配置硬件,配置GPIO,端口F,第9個引腳
        GPIO_InitStruct.GPIO_Pin=GPIO_Pin_9;                        //第9 個引腳
        GPIO_InitStruct.GPIO_Mode=pin_mode;                //輸出模式
void i2c_start(void)
        //保證SDA引腳為輸出模式
        sda_pin_mode(GPIO_Mode_OUT);
        SDA_W=1;
        SCL_W=1;
        delay_us(5);
        SDA_W=0;
        delay_us(5);
        SCL_W=0;//總線進入忙狀態(tài)
        delay_us(5);
void i2c_stop(void)
        //保證SDA引腳為輸出模式
        SDA_W=0;
        SCL_W=1;
        delay_us(5);
        SDA_W=1;
        delay_us(5);
void i2c_send_byte(uint8_t byte)
        int32_t i=0;
        //保證SDA引腳為輸出模式
        SDA_W=0;
        SCL_W=0;
        delay_us(5);
        //最高有效位優(yōu)先傳輸,通過時序圖觀察到
        for(i=7; i>=0; i--)
                //檢測對應的bit位是1還是0
                if(byte & (1<<i))
                        SDA_W=1;
                        SDA_W=0;
                delay_us(5);
                //時鐘線拉高,數(shù)據(jù)有效
                SCL_W=1;
                delay_us(5);
                //時鐘線拉低,數(shù)據(jù)變更
                SCL_W=0;
                delay_us(5);
uint8_t i2c_recv_byte(void)
        uint8_t d=0;
        int32_t i;
        //保證SDA引腳為輸入模式
        sda_pin_mode(GPIO_Mode_IN);
        for(i=7; i>=0; i--)
                SCL_W=1;
                delay_us(5);
                //讀取SDA引腳電平
                if(SDA_R)
                        d|=1<<i;
                //時鐘線拉低,保持占用總線,總線是忙狀態(tài)
                SCL_W=0;
                delay_us(5);
        return d;
void i2c_ack(uint8_t ack)
        //保證SDA引腳為輸出模式
        SDA_W=0;
        SCL_W=0;
        delay_us(5);
        if(ack)
                SDA_W=1;
                SDA_W=0;
        delay_us(5);
        SCL_W=1;
        delay_us(5);
        SCL_W=0;
        delay_us(5);
uint8_t i2c_wait_ack(void)
        uint8_t ack=0;
        //保證SDA引腳為輸入模式
        SCL_W=1;
        delay_us(5);
        //讀取SDA引腳電平
        if(SDA_R)
                ack=1;//無應答
                ack=0;//有應答
        SCL_W=0;
        delay_us(5);
        return ack;
int32_t at24c02_write(uint8_t word_address,uint8_t *data,uint8_t len)
        uint8_t ack=0;
        uint8_t *p=data;
        //發(fā)送起始信號
        i2c_start();
        //發(fā)送設備尋址,從機地址寫訪問地址0xA0
        i2c_send_byte(0xA0);
        //等待對方應答
        ack=i2c_wait_ack();
        if(ack)
                printf("device address error\r\n");
                return -1;
        //發(fā)送訪問數(shù)據(jù)存儲地址
        i2c_send_byte(word_address);
        //等待對方應答
        ack=i2c_wait_ack();
        if(ack)
                printf("word address error\r\n");
                return -2;
        //連續(xù)寫入數(shù)據(jù)
        while(len--)
                //發(fā)送要寫入的數(shù)據(jù)
                i2c_send_byte(*p++);
                //等待對方應答
                ack=i2c_wait_ack();
                if(ack)
                        printf("write data error\r\n");
                        return -3;
        //結束通信
        i2c_stop();
        printf("write success\r\n");
        return 0;
int32_t at24c02_read(uint8_t word_address,uint8_t *data,uint8_t len)
        uint8_t ack=0;
        uint8_t *p=data;
        //發(fā)送起始信號
        i2c_start();
        //等待對方應答
        ack=i2c_wait_ack();
        if(ack)
                printf("device address with write error\r\n");
                return -1;
        //等待對方應答
        ack=i2c_wait_ack();
        if(ack)
                return -2;
        //重新發(fā)送起始信號
        i2c_start();
        //發(fā)送設備尋址,從機地址讀訪問地址0xA1
        i2c_send_byte(0xA1);
        //等待對方應答
        ack=i2c_wait_ack();
        if(ack)
                printf("device address with read error\r\n");
                return -3;
        len=len-1;
        while(len--)
                //讀取數(shù)據(jù)
                *p++=i2c_recv_byte();
                //主動發(fā)應答信號
                i2c_ack(0);
        //讀取最后一個數(shù)據(jù)
        *p=i2c_recv_byte();
        //主動發(fā)無應答信號
        i2c_ack(1);
        //結束通信
        i2c_stop();
        printf("read success\r\n");
        return 0;
//主函數(shù)
int main(void)
        uint8_t buf[8]={1,2,3,4,5,6,7,8};
        uint32_t i;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        //使能端口F的硬件時鐘,端口F才能工作,說白了就是對端口F上電
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE);
        GPIO_Init(GPIOF,&GPIO_InitStruct);
        //配置串口1波特率為115200bps
        usart1_init(115200);
        at24c02_init();
        printf("This is at24c02 test\r\n");
        printf("at24c02:write addr at 0,data is 1 ~ 8\r\n");
        at24c02_write(0,buf,8);
        delay_ms(10);
        memset(buf,0,sizeof buf);
        at24c02_read(0,buf,8);
        printf("read data is:");
        for(i=0; i<8; i++)
                printf("%02X ",buf[i]);
        printf("\r\n");
void USART1_IRQHandler(void)
        uint8_t d;
        //檢查串口1是否接收到數(shù)據(jù)
        if(USART_GetITStatus(USART1,USART_IT_RXNE) == SET)
                //讀取數(shù)據(jù)
                d = USART_ReceiveData(USART1);
                //清空標志位
                USART_ClearITPendingBit(USART1,USART_IT_RXNE);
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 共享資料的黑幣獎勵!
ID:632424 發(fā)表于 2021-7-29 22:27 | 顯示全部樓層
優(yōu)秀,感謝分享,剛學,我模仿學習
