查看: 6210|回復(fù): 13
關(guān)于單片機(jī)UART和IIC EEPROM的應(yīng)用,有一些疑惑,請(qǐng)各位朋友幫忙指點(diǎn)一下
ID:415088 發(fā)表于 2020-5-27 23:00 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
60黑幣
用串口調(diào)試助手,將數(shù)據(jù)通過UART下發(fā)到單片機(jī)當(dāng)中, 并且存儲(chǔ)到EEPROM中, 然后將電源關(guān)掉, 重新上電讀取EEPROM的數(shù)據(jù)并數(shù)碼管上顯示出來,但是我現(xiàn)在數(shù)據(jù)發(fā)送單片機(jī)也接收了,就是無法存儲(chǔ)到EEPROM中,望各位朋友幫忙指點(diǎn)一下,謝謝!
以下是單片機(jī)代碼:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. sbit I2C_SCL = P0^6;
  4. sbit I2C_SDA = P0^7;
  5. #define I2CDelay() {_nop_();_nop_();_nop_();_nop_();}
  6. /* 595控制數(shù)碼管時(shí)鐘信號(hào)線引腳定義 */
  7. sbit HC595CLK  = P1^1;
  8. /* 595控制數(shù)碼管片選信號(hào)線引腳定義 */
  9. sbit HC595RCK  = P1^0;
  10. /* 595控制數(shù)碼管數(shù)據(jù)輸入引腳定義 */
  11. sbit HC595DATA = P1^4;
  12. unsigned char ucDataOneTab[10] = {0x3f,0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f,0x6f};
  13. unsigned char ucDataTwoTab[8] = {0xFE, 0xFD, 0xFB, 0xF7, 0xEF, 0xDF, 0xBF, 0x7F};
  14. unsigned char led_buf[8] = {0x3f,0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07};
  15. unsigned char RxdByte = 0;
  16. void send_dat(unsigned char uiDataOne,unsigned int uiDataTwo)
  17. {
  18.         unsigned char i;
  19.
  20.         HC595RCK = 0;
  21.         for(i=0; i<8; i++)
  22.         {
  23.                 HC595CLK = 0;
  24.                 if(0 != (uiDataOne&0x80))
  25.                 {
  26.                         HC595DATA = 1;
  27.                 }
  28.                 else
  29.                 {
  30.                         HC595DATA = 0;
  31.                 }
  32.                 uiDataOne <<= 1;
  33.                 HC595CLK = 1;
  34.         }
  35.         for(i=0; i<8; i++)
  36.         {
  37.                 HC595CLK = 0;
  38.                 if(0 != (uiDataTwo&0x80))
  39.                 {
  40.                         HC595DATA = 1;
  41.                 }
  42.                 else
  43.                 {
  44.                         HC595DATA = 0;
  45.                 }
  46.                 uiDataTwo <<= 1;
  47.                 HC595CLK = 1;
  48.         }
  49.         HC595RCK = 1;
  50. }
  51. void Delay1ms(int i)
  52. {
  53.     int j;
  54.     for(; i > 0; i--)
  55.           {
  56.          for(j = 0; j < 110; j++);
  57.     }
  58. }
  59. /* 串口配置函數(shù),baud-通信波特率 */
  60. void ConfigUART(unsigned int baud)
  61. {
  62.     SCON  = 0x50;  //配置串口為模式1
  63.     TMOD &= 0x0F;  //清零T1的控制位
  64.     TMOD |= 0x20;  //配置T1為模式2
  65.     TH1 = 256 - (11059200/12/32)/baud;  //計(jì)算T1重載值
  66.     TL1 = TH1;     //初值等于重載值
  67.     ET1 = 0;       //禁止T1中斷
  68.     ES  = 1;       //使能串口中斷
  69.     TR1 = 1;       //啟動(dòng)T1
  70. }
  71. void main()
  72. {
  73.         unsigned char dat,i;
  74.         unsigned char str[5];
  75.
  76.         EA = 1;
  77.         ConfigUART(9600);
  78.
  79.         RxdByte = E2ReadByte(0x02);
  80.         str[0] = (RxdByte/100); //轉(zhuǎn)換為十進(jìn)制字符串格式
  81.         str[1] = (RxdByte/10%10);
  82.         str[2] = (RxdByte%10);
  83.
  84.         dat++; //將其數(shù)值+1
  85.         //E2WriteByte(0x02, dat); //再寫回到對(duì)應(yīng)的地址上
  86.         E2WriteByte(0x02, RxdByte); //再寫回到對(duì)應(yīng)的地址上
  87.
  88.         led_buf[2] = ucDataOneTab[str[2]];
  89.         led_buf[1] = ucDataOneTab[str[1]];
  90.         led_buf[0] = ucDataOneTab[str[0]];
  91.
  92.         while(1)
  93.         {
  94.                 for(i=0; i<8; i++)
  95.                 {
  96.                         send_dat(led_buf[i],ucDataTwoTab[i]);
  97.                         Delay1ms(1);
  98.                 }
  99.         }
  100. }
  101. void InterruptUart() interrupt 4
  102. {
  103.         if(RI)
  104.         {
  105.                 RI = 0;
  106.                 RxdByte = SBUF;
  107.                 SBUF = RxdByte + 1;
  108.         }
  109.         if(TI)
  110.         {
  111.                 TI = 0;
  112.         }
  113. }
ID:415088 發(fā)表于 2020-5-27 23:02 | 只看該作者
望各位朋友幫忙指點(diǎn)一下,感激不盡。
ID:282850 發(fā)表于 2020-5-28 09:17 | 只看該作者
沒有看eeprom程序,既然UART正確,問題就出在EEPROM程序上,加適當(dāng)延時(shí),EEPROM讀寫速度不快。
參與人數(shù) 1黑幣 +10 收起 理由
八月初 + 10
ID:65956 發(fā)表于 2020-5-28 09:26 | 只看該作者
因?yàn)槟愕拇a不全,在這肯定無法幫到你,我想應(yīng)是IIC通訊時(shí)序上有問題,特別注意IIC通訊時(shí)序上的時(shí)間,這個(gè)沒作到就會(huì)造成通訊無效的問題,建議你再查查
八月初 + 10
ID:762472 發(fā)表于 2020-5-28 10:55 | 只看該作者
eeprom沒寫一個(gè)字節(jié)要delay,等待eeprom自己操作完才能開始下面的操作,沒看到你這有延時(shí)
八月初 + 10
ID:481073 發(fā)表于 2020-5-28 10:59 | 只看該作者
建議還是檢查下iic的通訊
ID:415088 發(fā)表于 2020-5-28 16:43 | 只看該作者
void I2C_Start()
        I2C_SDA = 1;
        I2C_SCL = 1;
        I2CDelay();
        I2C_SDA = 0;
        I2CDelay()
        I2C_SCL = 0;//I2C拉低,為下一次發(fā)送數(shù)據(jù)做準(zhǔn)備
void I2C_Stop()
        I2C_SCL = 0;
        I2C_SDA = 0;
        I2CDelay();
        I2C_SCL = 1;
        I2CDelay();
        I2C_SDA = 1;
        I2CDelay();
//I2C 總線寫操作,dat-待寫入字節(jié),返回值-從機(jī)應(yīng)答位的值
bit I2CWrite(unsigned char dat)
        bit ack;
        unsigned char mask;
        for(mask=0x80; mask!=0; mask>>=1)//I2C發(fā)送數(shù)據(jù)從高位到低位 1000 0000
                if((mask&dat) != 0)
                        I2C_SDA = 1;
                        I2C_SDA = 0;
                I2CDelay();
                I2C_SCL = 1;
                I2CDelay();
                I2C_SCL = 0;
        I2C_SDA = 1;//釋放主機(jī)
        I2CDelay();
        I2C_SCL = 1;
        ack = I2C_SDA;
        I2CDelay();
        I2C_SCL = 0;
        return (~ack);
/* I2C 總線讀操作,并發(fā)送非應(yīng)答信號(hào),返回值-讀到的字節(jié) */
unsigned char I2CReadNAK()
        unsigned char mask;
        unsigned char dat;
                I2CDelay();
                I2C_SCL = 1;
                if(I2C_SDA == 0)
                        dat &= ~mask;
                        dat |= mask;
                I2CDelay();
                I2C_SCL = 0;
        I2C_SDA = 1;//發(fā)送NACK應(yīng)答信號(hào)
        I2CDelay();
        I2C_SCL = 1;
        I2CDelay();
        I2C_SCL = 0;
        return dat;
/* I2C 總線讀操作,并發(fā)送應(yīng)答信號(hào),返回值-讀到的字節(jié) */
unsigned char I2CReadACK()
        unsigned char mask;
        unsigned char dat;
                I2CDelay();
                I2C_SCL = 1;//SCL在高電平的時(shí)候開始讀取數(shù)據(jù)
                if(I2C_SDA == 0)
                        dat &= ~mask;
                        dat |= mask;
                I2CDelay();
                I2C_SCL = 0;
        I2C_SDA = 0;//發(fā)送NACK應(yīng)答信號(hào)
        I2CDelay();
        I2C_SCL = 1;
        I2CDelay();
        I2C_SCL = 0;
        return dat;
// 讀取 EEPROM 中的一個(gè)字節(jié), addr-字節(jié)地址
unsigned char E2ReadByte(unsigned char addr)
        unsigned char dat;
        I2C_Start();
        I2CWrite(0x50<<1); //0101 0000 << 1 == 1010 0000
        I2CWrite(addr);
        I2C_Start();
        I2CWrite((0x50<<1) | 0x01);
        dat = I2CReadNAK();
        I2C_Stop();
        return dat;
/* 向 EEPROM 中寫入一個(gè)字節(jié), addr-字節(jié)地址 */
void E2WriteByte(unsigned char addr, unsigned char dat)
        I2C_Start();
        I2CWrite(0x50<<1); //尋址器件,后續(xù)為寫操作
        I2CWrite(addr); //寫入存儲(chǔ)地址
        I2CWrite(dat); //寫入一個(gè)字節(jié)數(shù)據(jù)
        I2C_Stop();
這是IIC時(shí)序
ID:415088 發(fā)表于 2020-5-28 16:44 | 只看該作者
f556 發(fā)表于 2020-5-28 09:17
我先試試加延時(shí)
ID:415088 發(fā)表于 2020-5-28 16:56 | 只看該作者
364326786 發(fā)表于 2020-5-28 10:55
延時(shí)的話要延時(shí)多久呢?
ID:415088 發(fā)表于 2020-5-28 17:19 | 只看該作者
嘗試在E2PROMRead()的函數(shù)后面加100ms延時(shí),但是依然沒有用
        unsigned char dat = 0x05;
        unsigned char i;
        EA = 1;
        ConfigUart(9600);
        RxdByte = E2ReadByte(0x20);
        Delay1ms(100);
        //dat++;
        E2WriteByte(0x20,RxdByte);//將數(shù)據(jù)存儲(chǔ)到E2PROM中
        disbuf[2] = ucDataOneTab[str[2]];
        disbuf[1] = ucDataOneTab[str[1]];
        disbuf[0] = ucDataOneTab[str[0]];
                for(i=0; i<8; i++)
                        Send_data_smg(disbuf[i],ucDataTwoTab[i]);
                        Delay1ms(1);
ID:415088 發(fā)表于 2020-5-28 18:23 | 只看該作者
流星2019 發(fā)表于 2020-5-28 10:59
建議還是檢查下iic的通訊
今天評(píng)分上限了,明天再給你評(píng)分,時(shí)序我嘗試把別人已經(jīng)驗(yàn)證過的IIC的時(shí)序加進(jìn)來,但是還是不行
ID:732506 發(fā)表于 2020-5-28 21:06 | 只看該作者
用仿真,看i2c debug提供的數(shù)據(jù),就可以找到原因了。只看代碼沒有驗(yàn)證是猜測(cè),不準(zhǔn)的。
ID:760904 發(fā)表于 2020-5-28 21:06 | 只看該作者
ID:592807 發(fā)表于 2020-5-29 08:32 | 只看該作者
IIC通訊時(shí)外部設(shè)備的設(shè)備地址沒弄,你和誰通訊呢?iic發(fā)送數(shù)據(jù)指令前要先發(fā)送設(shè)備地址
