查看: 2760|回復(fù): 4
求這個c程序的最詳細(xì)解釋
ID:73480 發(fā)表于 2015-4-1 20:20 | 顯示全部樓層 |閱讀模式
這是一個計時器
#include<reg51.h>
sbit lcden=P0^5;//1602的使能端
sbit lcdrs=P0^7;
sbit lcdrw=P0^6;
sbit k1=P3^5;//功能按鍵
sbit k2=P3^4;//加按鍵
sbit k3=P3^3;//減按鍵
sbit bz=P0^4;//蜂鳴器
uchar code table[]="countdown...";
uchar code table1[]="00:00:00";
uchar num,aa,k1num,k2num,k3num;
char shi,fen,miao,qian,bai,beepz;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void beep()        //控制無源蜂鳴器響函
     bz=1;
         delay(2);
         bz=0;
         delay(2);
void write_com(uchar com)//1602寫命令函數(shù)
        lcdrs=0;
        lcdrw=0;
        P2=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)//1602寫數(shù)據(jù)函數(shù)
        lcdrs=1;
        lcdrw=0;
        P2=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_sfm(uchar add,uchar date)//寫時分秒函數(shù)
        uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+shi);
        write_date(0x30+ge);
void init()//初始化函數(shù)
        miao=59;
        fen=59;
        shi=23;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
    write_com(0x80);
        for(num=0;num<12;num++)
                        write_date(table[num]);
                        delay(5);
                write_com(0x80+0x40);
                for(num=0;num<8;num++)
                        write_date(table1[num]);
                        delay(5);
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        write_sfm(6,miao);
        write_sfm(3,fen);
        write_sfm(0,shi);
void keyscan()//按鍵函數(shù)
        if(k1==0)        //檢測K1按鍵按下
                delay(5);        //延時
                if(k1==0)        //再次檢測K1按鍵按下
                        k1num++;
                        while(!k1);
                      if(k1num==1) //第一次按K1
                                                TR0=0;//關(guān)閉定時器
                                        write_com(0x80+0x40+7);//光標(biāo)閃爍的位置
                                        write_com(0x0f);//開啟光標(biāo)閃爍
                                if(k1num==2)//第二次按K1
                                        write_com(0x80+0x40+4);//光標(biāo)閃爍的位置
                                if(k1num==3)//第三次按K1
                                        write_com(0x80+0x40+1);//光標(biāo)閃爍的位置
                                                if(k1num==4)//第四次按K1
                                        TR0=1;//開定時器
                                        k1num=0;//按清零鍵次數(shù)
                                        write_com(0x0c);//關(guān)閉光標(biāo)閃爍
        if(k1num!=0)//K1沒有按下的時候
                                if(k2==0)
                                                delay(5);
                                                if(k2==0)
                                                        while(!k2);
        if(k1num==1)
        miao++;
        if(miao==60)
        miao=0;
        //s1=0;
        write_sfm(6,miao);
        if(k1num==2)
        fen++;
        if(fen==60)
        fen=0;
        //s1=0;
        write_sfm(3,fen);
        if(k1num==3)
        shi++;
        if(shi==24)
        shi=0;
        //s1=0;
        write_sfm(0,shi);
                                        if(k3==0)
                                                delay(5);
                                                if(k3==0)
                                                        while(!k3);
                                                        if(k1num==1)
        miao--;
        if(miao==-1)
        miao=59;
        write_sfm(6,miao);
                                                        if(k1num==2)
        fen--;
        if(fen==-1)
        fen=59;
        write_sfm(3,fen);
                                                        if(k1num==3)
        shi--;
        if(shi==-1)
        shi=23;
        write_sfm(0,shi);
void main()        //主函數(shù)
        init();//初始化
                keyscan();//等待檢測是否有按鍵按下
void timer0() interrupt 1 //中斷函數(shù)
        aa++;
                if(aa==18)
                        aa=0;
                        miao--;
                        if((miao==-1)&&(fen==1)&&(shi==0))         //判斷到計時一分鐘一秒鐘報警
        for(beepz=0;beepz<110;beepz++)         //一秒鐘報警
                                beep();
                        if((miao==-1)&&(fen==0)&&(shi==0))         //判斷倒計時到時長響報警
                                  TR0=0;
                                  miao=0;
                                  fen=0;
                                  shi=0;
                                  while(1) //長報警
                                          beep();
                        if(miao==-1)
                                miao=59;
                                fen--;
                                if(fen==-1)
                                        fen=59;
                                        shi--;
        write_sfm(0,shi);
                                   write_sfm(3,fen);
                          write_sfm(6,miao);
ID:75077 發(fā)表于 2015-4-2 09:51 | 顯示全部樓層
ID:73833 發(fā)表于 2015-4-2 20:23 | 顯示全部樓層
ID:29301 發(fā)表于 2015-4-3 10:00 | 顯示全部樓層
自己先看,看不懂了再問,這個都是模塊的東西,一個一個看總會懂的
ID:76287 發(fā)表于 2015-4-7 18:53 | 顯示全部樓層
想要畫一個點(diǎn)火芯片的封裝,可是一到pcb就出錯。這個芯片的底部也作為一個焊盤。我的思路是,用一個多層的焊盤作為引腳11,然后上面加幾個過孔從而可以從下面走線,可是這樣在pcb中顯示出錯
