本帖最后由 xiaos 于 2015-4-2 23:39 編輯
程序:ICC-AVR
功能:波特率9600 串口發(fā)送溫濕度數(shù)據(jù)
數(shù)據(jù)格式:濕度 溫度 校驗和
例如串口發(fā)送數(shù)據(jù) 59 00 24 00 53 則濕度為59 溫度為24 校驗和為53
公司:DHT11
芯片:M8
晶振:外部 7.3728Mhz
#include <iom8v.h>
#include <macros.h>
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號8位整型變量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符號8位整型變量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號16位整型變量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符號16位整型變量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號32位整型變量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符號32位整型變量 */
typedef float F32; /* single precision floating point variable (32bits) 單精度浮點數(shù)(32位長度) */
typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點數(shù)(64位長度) */
I/O空間定義
// B0_IN DDRB &= ~(1 << PB0) /*設(shè)置輸入*/
// B0_OUT DDRB |= (1 << PB0) /*設(shè)置輸出*/
// B0_CLR PORTB &= ~(1 << PB0) /*置低電平*/
// B0_SET PORTB |= (1 << PB0) /*置高電平*/
// B0_R PINB & (1 <<PB0) /*讀了電平*/
#define C4_IN DDRC &= ~(1 << PC4) /*設(shè)置輸入*/
#define C4_OUT DDRC |= (1 << PC4) /*設(shè)置輸出*/
#define C4_CLR PORTC &= ~(1 << PC4) /*置低電平*/
#define C4_SET PORTC |= (1 << PC4) /*置高電平*/
#define C4_R PINC & (1 <<PC4) /*讀了電平*/
通訊I/O空間定義
#define COM_IN C4_IN
#define COM_OUT C4_OUT
#define COM_CLR C4_CLR
#define COM_SET C4_SET
#define COM_R C4_R
全局變量定義區(qū)
U8 i;
U8 U8FLAG,k;
U8 U8count,U8temp;
U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8 U8comdata;
U16 ReceiveHighByte;
U16 ReceiveLowByte;
void port_init(void)
PORTB = 0x00;
DDRB = 0xFF;
PORTC = 0x03;
DDRC = 0x0C;
PORTD = 0x00;
DDRD = 0xF0;
void watchdog_init(void)
//WDR(); //this prevents a timout on enabling
//WDTCR = 0x0F; //WATCHDOG ENABLED - dont forget to issue WDRs
void Delay(unsigned int i)
while(i--);
void DelaymS (U16 dly)
U16 i;
for ( ; dly>0; dly--)
WDR();
for (i=0; i<1032; i++);
void Delay_10us(void)
U8 i;
i++;i++;i++;i++;i++;i++;i++;i++;i++;
i++;i++;
void COM(void)
U8 i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!(COM_R))&&U8FLAG++);
if(U8FLAG==1)break;
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
U8temp=0;
if(COM_R)U8temp=1;
U8FLAG=2;
while((COM_R)&&U8FLAG++);
//超時則跳出for循環(huán)
if(U8FLAG==1)break;
//判斷數(shù)據(jù)位是0還是1
// 如果高電平高過預(yù)定0高電平值則數(shù)據(jù)位為 1
U8comdata<<=1;
U8comdata|=U8temp; //0
}//rof
//-----濕度讀取子程序 ------------
//----以下變量均為全局變量--------
//----溫度高8位== U8T_data_H------
//----溫度低8位== U8T_data_L------
//----濕度高8位== U8RH_data_H-----
//----濕度低8位== U8RH_data_L-----
//----校驗 8位 == U8checkdata-----
//----調(diào)用相關(guān)子程序如下----------
//---- Delay();, Delay_10us();,COM();
void RH(void)
//主機拉低18ms
COM_OUT;
COM_CLR;
DelaymS(18);
COM_IN;
COM_SET;
//總線由上拉電阻拉高 主機延時20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
//主機設(shè)為輸入 判斷從機響應(yīng)信號
//P2_0=1;
//判斷從機是否有低電平響應(yīng)信號 如不響應(yīng)則跳出,響應(yīng)則向下運行
// if(!P2_0) //T !
if(COM_R)U8FLAG=1;
while(!(COM_R))
U8FLAG=2;
//判斷從機是否發(fā)出 80us 的低電平響應(yīng)信號是否結(jié)束
//while((!P2_0)&&U8FLAG++);
if(U8FLAG==1)break;
U8FLAG=2;
//判斷從機是否發(fā)出 80us 的高電平,如發(fā)出則進入數(shù)據(jù)接收狀態(tài)
//while((P2_0)&&U8FLAG++);
if(U8FLAG==1)break;
//數(shù)據(jù)接收狀態(tài)
COM();
if(U8FLAG==1)break;
U8T_data_H_temp=U8comdata;
COM();
if(U8FLAG==1)break;
U8T_data_L_temp=U8comdata;
COM();
if(U8FLAG==1)break;
U8RH_data_H_temp=U8comdata;
COM();
if(U8FLAG==1)break;
U8RH_data_L_temp=U8comdata;
COM();
if(U8FLAG==1)break;
U8checkdata_temp=U8comdata;
break;
}//while
//P2_0=1;
COM_IN;
COM_SET;
//數(shù)據(jù)校驗
U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
if(U8temp==U8checkdata_temp)
U8RH_data_H=U8T_data_H_temp;
U8RH_data_L=U8T_data_L_temp;
U8T_data_H=U8RH_data_H_temp;
U8T_data_L=U8RH_data_L_temp;
U8checkdata=U8checkdata_temp;
}//fi
COM_IN;
COM_SET;
串口初始化函數(shù)
系統(tǒng)頻率:2MHz
停止位:1
波特率:9600
數(shù)據(jù)長度:8
void Uart_Init(void) {
UCSRA = 0x02; /*2倍速 */
UCSRB = 0x18; /*允許接收和發(fā)送*/
UCSRC = 0x06; /*8位數(shù)據(jù) */
UBRRH = 0x00;
//UBRRL = 47; /*9600 3.6864M */
UBRRL = 95; /*9600 7.3728M */
串?dāng)?shù)據(jù)發(fā)送
查詢方式發(fā)送
void Uart_Transmit(unsigned char i) {
/* 等待發(fā)送緩沖器為空*/
while (!(UCSRA & (1<<UDRE)));
/* 將數(shù)據(jù)放入緩沖器,發(fā)送數(shù)據(jù)*/
UDR = i;
串?dāng)?shù)據(jù)接收
查詢方式接收
unsigned char Uart_Receive( void ) {
/* 等待接收數(shù)據(jù)*/
while (!(UCSRA & (1<<RXC)));
/* 從緩沖器中獲取并返回數(shù)據(jù)*/
// Uart_Transmit(UDR);
return UDR;
void init_devices(void)
unsigned char i;
CLI();
port_init();
watchdog_init();
Uart_Init();
MCUCR = 0x03;
GICR = 0x00; //關(guān)外部中斷0
TIMSK = 0x00; //關(guān)定時器1中斷
SEI(); //re-enable interrupts
主函數(shù)
void main(void)
init_devices() ;
COM_IN;
COM_SET;
//讀DHT11
RH();
//把DHT11的十六進制數(shù)據(jù)轉(zhuǎn)換成10進制
//格式 濕度 溫度 校驗和
//例如串口發(fā)送數(shù)據(jù) 59 00 24 00 53 則濕度為59 溫度為24 校驗和為53
U8temp=U8RH_data_H/10;
U8temp<<=4;
U8temp|=U8RH_data_H%10;
U8RH_data_H=U8temp;
Uart_Transmit(U8RH_data_H);
Uart_Transmit(U8RH_data_L);
U8temp=U8T_data_H/10;
U8temp<<=4;
U8temp|=U8T_data_H%10;
U8T_data_H=U8temp;
Uart_Transmit(U8T_data_H);
Uart_Transmit(U8T_data_L);
Uart_Transmit(U8checkdata);
//延時2S
for(U8temp=0;U8temp<200;U8temp++)
DelaymS(10);
}//rof
