查看: 12045|回復(fù): 22
自制nRF24L01無(wú)線(xiàn)小車(chē)
ID:76127 發(fā)表于 2015-4-17 22:30 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
直接上圖:
以下是編譯后的收發(fā)一體程序可以自行更改:
1.無(wú)線(xiàn)子程序文件nRF24L01.h
// nRF24L01.h
#ifndef _NRF_24L01_
#define _NRF_24L01_
#define TX_ADR_WIDTH    5  // 5 bytes TX address width
#define RX_ADR_WIDTH    5  // 5 bytes RX address width
#define TX_PLOAD_WIDTH  20  //20 bytes TX payload
#define RX_PLOAD_WIDTH  20  //20 bytes TX payload
typedef unsigned char BYTE;
typedef unsigned char uchar;
// SPI(nRF24L01) commands
#define READ_REG        0x00 // Define read command to register
#define WRITE_REG       0x20 // Define write command to register
#define RD_RX_PLOAD     0x61 // Define RX payload register address
#define WR_TX_PLOAD     0xA0 // Define TX payload register address
#define FLUSH_TX        0xE1 // Define flush TX register command
#define FLUSH_RX        0xE2 // Define flush RX register command
#define REUSE_TX_PL     0xE3 // Define reuse TX payload register command
#define NOP             0xFF  // Define No Operation, might be used to readstatus register
// SPI(nRF24L01) registers(addresses)
#define CONFIG          0x00 // 'Config' register address
#define EN_AA           0x01 // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR       0x02 // 'Enabled RX addresses' register address
#define SETUP_AW        0x03 // 'Setup address width' register address
#define SETUP_RETR      0x04 // 'Setup Auto. Retrans' register address
#define RF_CH           0x05 // 'RF channel' register address
#define RF_SETUP        0x06 // 'RF setup' register address
#define STATUS          0x07 // 'Status' register address
#define OBSERVE_TX      0x08 // 'Observe TX' register address
#define CD              0x09  // 'Carrier Detect' register address
#define RX_ADDR_P0      0x0A // 'RX address pipe0' register address
#define RX_ADDR_P1      0x0B // 'RX address pipe1' register address
#define RX_ADDR_P2      0x0C // 'RX address pipe2' register address
#define RX_ADDR_P3      0x0D // 'RX address pipe3' register address
#define RX_ADDR_P4      0x0E // 'RX address pipe4' register address
#define RX_ADDR_P5      0x0F // 'RX address pipe5' register address
#define TX_ADDR         0x10 // 'TX address' register address
#define RX_PW_P0        0x11 // 'RX payload width, pipe0' register address
#define RX_PW_P1        0x12 // 'RX payload width, pipe1' register address
#define RX_PW_P2        0x13 // 'RX payload width, pipe2' register address
#define RX_PW_P3        0x14 // 'RX payload width, pipe3' register address
#define RX_PW_P4        0x15 // 'RX payload width, pipe4' register address
#define RX_PW_P5        0x16 // 'RX payload width, pipe5' register address
#define FIFO_STATUS     0x17 // 'FIFO Status Register' register address
//                   FUNCTION's PROTOTYPES  //
// void SPI_Init(BYTE Mode);     // Init HW or SW SPI
BYTESPI_RW(BYTE byte);                                // Single SPIread/write
BYTESPI_Read(BYTE reg);                               // Read one bytefrom nRF24L01
BYTESPI_RW_Reg(BYTE reg, BYTE byte);                  // Write one byte to register'reg'
BYTESPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes);  // Writes multiply bytes to one register
BYTESPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes);   // Read multiply bytes from one register
void inerDelay_us(unsigned char n);
void init_io(void) ;
void SetRX_Mode(void);
unsigned char nRF24L01_RxPacket(unsignedchar* rx_buf);
void nRF24L01_TxPacket(unsigned char *tx_buf);
extern uchar constTX_ADDRESS[TX_ADR_WIDTH];//TX address
extern uchar constRX_ADDRESS[RX_ADR_WIDTH];//;RX address
#endif  //_NRF_24L01_
2.接口設(shè)定文件://def.h
#ifndef _DEF_
#define _DEF_
#include <reg52.h>
#include <intrins.h>
//hard pin mapping
sbit        MISO     =P1^3;
sbit        MOSI     =P1^4;
sbit  SCK          =P1^5;
sbit  CE       =P1^6;
sbit  CSN              =P3^7;
sbit  IRQ        =P1^2;
sbit   LED2    =P3^5;
sbit   LED1    =P3^4;
sbit   LED3    =P3^6;
sbit   LED4    =P3^7;
sbit   KEY1    =P3^0;
sbit   KEY2    =P3^1;
sbit   KEY3    =P3^2;
sbit   KEY4    =P3^3;
#endif //_DEF_
3.頭文件:REG52.H
#ifndef __REG52_H__
#define __REG52_H__
/* BYTE Registers  */
sfr P0   = 0x80;
sfr P1   = 0x90;
sfr P2   = 0xA0;
sfr P3   = 0xB0;
sfr PSW  = 0xD0;
sfr ACC  = 0xE0;
sfr B    = 0xF0;
sfr SP   = 0x81;
sfr DPL  = 0x82;
sfr DPH  = 0x83;
sfr PCON = 0x87;
sfr TCON = 0x88;
sfr TMOD = 0x89;
sfr TL0  = 0x8A;
sfr TL1  = 0x8B;
sfr TH0  = 0x8C;
sfr TH1  = 0x8D;
sfr IE   = 0xA8;
sfr IP   = 0xB8;
sfr SCON = 0x98;
sfr SBUF = 0x99;
/* 8052 Extensions  */
sfr T2CON = 0xC8;
sfr RCAP2L = 0xCA;
sfr RCAP2H = 0xCB;
sfr TL2   = 0xCC;
sfr TH2   = 0xCD;
/* BIT Registers  */
/* PSW  */
sbit CY   = PSW^7;
sbit AC   = PSW^6;
sbit F0   = PSW^5;
sbit RS1  = PSW^4;
sbit RS0  = PSW^3;
sbit OV   = PSW^2;
sbit P    = PSW^0; //8052 only
/* TCON  */
sbit TF1  = TCON^7;
sbit TR1  = TCON^6;
sbit TF0  = TCON^5;
sbit TR0  = TCON^4;
sbit IE1  = TCON^3;
sbit IT1  = TCON^2;
sbit IE0  = TCON^1;
sbit IT0  = TCON^0;
/* IE  */
sbit EA   = IE^7;
sbit ET2  = IE^5; //8052 only
sbit ES   = IE^4;
sbit ET1  = IE^3;
sbit EX1  = IE^2;
sbit ET0  = IE^1;
sbit EX0  = IE^0;
/* IP  */
sbit PT2  = IP^5;
sbit PS   = IP^4;
sbit PT1  = IP^3;
sbit PX1  = IP^2;
sbit PT0  = IP^1;
sbit PX0  = IP^0;
/* P3  */
sbit RD   = P3^7;
sbit WR   = P3^6;
sbit T1   = P3^5;
sbit T0   = P3^4;
sbit INT1 = P3^3;
sbit INT0 = P3^2;
sbit TXD  = P3^1;
sbit RXD  = P3^0;
/* SCON  */
sbit SM0  = SCON^7;
sbit SM1  = SCON^6;
sbit SM2  = SCON^5;
sbit REN  = SCON^4;
sbit TB8  = SCON^3;
sbit RB8  = SCON^2;
sbit TI   = SCON^1;
sbit RI   = SCON^0;
/* P1  */
sbit T2EX = P1^1; // 8052 only
sbit T2   = P1^0; // 8052 only
/* T2CON  */
sbit TF2   = T2CON^7;
sbit EXF2  = T2CON^6;
sbit RCLK  = T2CON^5;
sbit TCLK  = T2CON^4;
sbit EXEN2 = T2CON^3;
sbit TR2   = T2CON^2;
sbit C_T2  = T2CON^1;
sbit CP_RL2 = T2CON^0;
#endif
4.子程序文件INTRINS.H
#ifndef __INTRINS_H__
#define __INTRINS_H__
extern void          _nop_     (void);
extern bit           _testbit_ (bit);
extern unsigned char _cror_    (unsigned char, unsigned char);
extern unsigned int  _iror_   (unsigned int,  unsigned char);
extern unsigned long _lror_    (unsigned long, unsigned char);
extern unsigned char _crol_    (unsigned char, unsigned char);
extern unsigned int  _irol_   (unsigned int,  unsigned char);
extern unsigned long _lrol_    (unsigned long, unsigned char);
extern unsigned char _chkfloat_(float);
extern void          _push_    (unsigned char _sfr);
extern void          _pop_     (unsigned char _sfr);
#endif
無(wú)線(xiàn)程序文件nRF24L01.c
#include "nRF24L01.h"
#include "..\\def.h"
uchar const TX_ADDRESS[TX_ADR_WIDTH]  = {0x34,0x43,0x10,0x10,0x01}; // Define astatic TX address
uchar const RX_ADDRESS[RX_ADR_WIDTH]  = {0x34,0x43,0x10,0x10,0x01}; // Define astatic RX address
uchar      bdatasta;
sbit  RX_DR   =sta^6;
sbit  TX_DS   =sta^5;
sbit  MAX_RT       =sta^4;
       for(;n>0;n--)
              _nop_();
void init_io(void)
   inerDelay_us(100);
      CE=0;  // chip enable
      CSN=1;  // Spi disable
      SCK=0;  // Spi clock line init high
Function: SPI_RW();
Description:
Writes one byte to nRF24L01, and return the byte read
from nRF24L01 during write, according to SPI protocol
uchar SPI_RW(uchar byte)
       ucharbit_ctr;
     for(bit_ctr=0;bit_ctr<8;bit_ctr++) //output 8-bit
              MOSI= (byte & 0x80);         // output'byte', MSB to MOSI
              byte= (byte << 1);           // shiftnext bit into MSB..
              SCK= 1;                      // Set SCKhigh..
              byte|= MISO;                  // capture currentMISO bit
              SCK= 0;                      // ..then set SCK lowagain
   return(byte);                         // return read byte
Function: SPI_RW_Reg();
Description:
Writes value 'value' to register 'reg'
uchar SPI_RW_Reg(BYTE reg, BYTE value)
       ucharstatus;
       CSN= 0;                   // CSN low, initSPI transaction
       status= SPI_RW(reg);      // select register
       SPI_RW(value);             // ..and write value to it..
       CSN= 1;                   // CSN high again
       return(status);            // return nRF24L01 status byte
Function: SPI_Read();
Description:
Read one byte from nRF24L01 register, 'reg'
BYTE SPI_Read(BYTE reg)
       BYTEreg_val;
       CSN= 0;                // CSN low,initialize SPI communication...
       SPI_RW(reg);            // Select register to read from..
       reg_val= SPI_RW(0);    // ..then readregistervalue
       CSN= 1;                // CSN high,terminate SPI communication
       return(reg_val);        // return register value
Function: SPI_Read_Buf();
Description:
uchar SPI_Read_Buf(BYTE reg, BYTE *pBuf,BYTE bytes)
       ucharstatus,byte_ctr;
       CSN= 0;                            // Set CSN low, init SPI tranaction
       status= SPI_RW(reg);                   // Select register to write to and readstatus byte
       for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
              pBuf[byte_ctr]= SPI_RW(0);    //
       CSN= 1;
       return(status);                    // return nRF24L01 statusbyte
Function: SPI_Write_Buf();
Description:
Writes contents of buffer '*pBuf' to nRF24L01
Typically used to write TX payload, Rx/Tx address
uchar SPI_Write_Buf(BYTE reg, BYTE *pBuf,BYTE bytes)
       CSN= 0;
       for(byte_ctr=0;byte_ctr<bytes; byte_ctr++) //
              SPI_RW(*pBuf++);
       CSN= 1;                 // Set CSN highagain
       return(status);          //
Function: RX_Mode();
Description:
       CE=0;
       SPI_Write_Buf(WRITE_REG+ RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // Use the same address on the RXdevice as the TX device
       SPI_RW_Reg(WRITE_REG+ EN_AA, 0x01);      //
       SPI_RW_Reg(WRITE_REG+ EN_RXADDR, 0x01);  //
       SPI_RW_Reg(WRITE_REG+ RF_CH, 0);        //
       SPI_RW_Reg(WRITE_REG+ RX_PW_P0, RX_PLOAD_WIDTH);
       SPI_RW_Reg(WRITE_REG+ RF_SETUP, 0x07);
       SPI_RW_Reg(WRITE_REG+ CONFIG, 0x0f);
       CE= 1;
       inerDelay_us(130);
   unsigned char revale=0;
       //SetRX_Mode();
       sta=SPI_Read(STATUS);       // read register STATUS's value
       if(RX_DR)                          // if receive dataready (RX_DR) interrupt
           CE = 0;
              SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);//read receive payload from RX_FIFO buffer
              revale=1;//we have receive data
       SPI_RW_Reg(WRITE_REG+STATUS,sta);//clear RX_DR or TX_DS or MAX_RT interrupt flag
       returnrevale;
Function: nRF24L01_TxPacket();
Description:
This function initializes one nRF24L01 device to
  TXmode, set TX address, set RX address for auto.ack,
fill TX payload, select RF channel, datarate & TX pwr.
PWR_UP is set, CRC(2 bytes) is enabled, & PRIM:TX.
       ToDo:One high pulse(>10us) on CE will now send this
       packetand expext an acknowledgment from the RX device.
       CE=0;
       SPI_Write_Buf(WRITE_REG+ TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);   //
       SPI_Write_Buf(WRITE_REG+ RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);
       SPI_Write_Buf(WR_TX_PLOAD,tx_buf, TX_PLOAD_WIDTH);
       SPI_RW_Reg(WRITE_REG+ SETUP_RETR, 0x1a); //
       SPI_RW_Reg(WRITE_REG+ RF_SETUP, 0x07);   //
       SPI_RW_Reg(WRITE_REG+ CONFIG, 0x0e);     //
       CE=1;
       inerDelay_us(10);
       //sta=SPI_Read(STATUS);     // read register STATUS's value
       //SPI_RW_Reg(WRITE_REG+STATUS,SPI_Read(READ_REG+STATUS));   // clear interrupt flag(TX_DS)
       主程序文件main.c
#include".\\nRF24L01\\nRF24L01.h"
#include "def.h"
void Delay(unsigned int s)
       unsignedint i;
       for(i=0;i<s; i++);
       for(i=0;i<s; i++);
void main(void)
       unsignedchar leng =0;
       unsignedchar tf =0;
       unsignedchar TxBuf[20]={0};      //
       unsignedchar RxBuf[20]={0};
   init_io() ;
       LED1= 0;
       LED2= 0;
LED3 = 0;
LED4 = 0;
       //TxBuf[0]= 8 ;
       TxBuf[1]= 1 ;
       TxBuf[2]= 1 ;
TxBuf[3] = 1 ;
TxBuf[4] = 1 ;
       nRF24L01_TxPacket(TxBuf);       // Transmit Tx buffer data
       Delay(6000);
LED1 = 1
   LED2 = 1;
LED3 = 1;
LED4 =1;
           //SetRX_Mode();
           if(KEY1 ==0 )
                   LED1= 0;
                  TxBuf[1] = 1 ;
                  tf = 1 ;
                     //while(KEY1==0);
          if(KEY2 ==0 )
                     LED2= 0;
                     TxBuf[2]= 1 ;
                     tf= 1 ;
                     //while(KEY2==0);
if(KEY3 ==0 )
                     LED3= 0;
                     TxBuf[3]= 1 ;
                     tf= 1 ;
                     //while(KEY3==0);
if(KEY4 ==0 )
                     LED4= 0;
                     TxBuf4]= 1 ;
                     tf= 1 ;
                     //while(KEY4==0);
          if (tf==1)
                     TxBuf[1]= 0x00;
                     TxBuf[2]= 0x00;
                     tf=0;
                     Delay(1000);
                     LED1= 1;
                     LED2= 1;
LED3 = 1;
LED4 =1;
                     //setRxMode();
              SetRX_Mode();
            if(nRF24L01_RxPacket(RxBuf))
                     if(    RxBuf[1]==1)
                            LED1= 0;
                     if(    RxBuf[2]==1)
                            LED2= 0;
if(    RxBuf[3]==1)
                            LED3=0;
if(     RxBuf[4]==1)
                            LED4= 0;
                     Delay(1000);
                     LED1= 1;
                     LED2= 1;
LED3 = 1;
LED4 =1;
              RxBuf[1]= 0x00;
              RxBuf[2]= 0x00;
RxBuf[3] = 0x00;
              RxBuf[4]= 0x00;
收藏收藏8 分享淘帖 頂2 踩
相關(guān)帖子
ID:78370 發(fā)表于 2015-4-29 18:02 | 只看該作者
謝謝樓主分享
ID:26628 發(fā)表于 2015-5-7 16:16 | 只看該作者
前些天找沒(méi)找到,現(xiàn)在出來(lái)了,謝謝分享
ID:79544 發(fā)表于 2015-9-28 16:39 | 只看該作者
謝謝分享,樓主這是單通道還多通道的呀,謝謝
ID:44267 發(fā)表于 2015-10-18 15:32 | 只看該作者
多謝分享,學(xué)習(xí)了
ID:44267 發(fā)表于 2015-10-18 15:35 | 只看該作者
樓主,能不能上傳包啊
ID:103834 發(fā)表于 2016-1-21 21:14 來(lái)自觸屏版 | 只看該作者
謝謝樓主分享
ID:105120 發(fā)表于 2016-2-6 10:05 | 只看該作者
謝謝樓主分享,下次 STEP BY STEP
ID:29972 發(fā)表于 2016-2-12 09:50 | 只看該作者
請(qǐng)問(wèn)你的無(wú)線(xiàn)車(chē)遙控距離是多少?能上視頻嗎?
ID:105437 發(fā)表于 2016-3-16 22:38 | 只看該作者
樓主能否寫(xiě)個(gè)注釋
ID:105437 發(fā)表于 2016-3-16 22:39 | 只看該作者
樓主能否寫(xiě)個(gè)注釋
ID:110243 發(fā)表于 2016-3-22 20:22 | 只看該作者
馬曉軍 發(fā)表于 2016-3-16 22:39
樓主能否寫(xiě)個(gè)注釋
NRF24L01的無(wú)線(xiàn)溫度檢測(cè)系統(tǒng)
ID:110243 發(fā)表于 2016-3-22 20:33 | 只看該作者
馬曉軍 發(fā)表于 2016-3-16 22:38
樓主能否寫(xiě)個(gè)注釋
ID:107418 發(fā)表于 2016-8-22 10:28 | 只看該作者
ID:137396 發(fā)表于 2016-8-23 15:18 | 只看該作者
無(wú)限真的蠻酷的,但尚未使用....
ID:144022 發(fā)表于 2016-10-23 11:00 | 只看該作者
好厲害!!
ID:48413 發(fā)表于 2017-2-21 14:41 | 只看該作者
樓主有詳細(xì)的資料吧
ID:192650 發(fā)表于 2017-4-23 13:20 | 只看該作者
把發(fā)送和接受分開(kāi)發(fā)吧   多弄點(diǎn)中文注釋吧!謝謝樓主分享
ID:192650 發(fā)表于 2017-4-23 13:21 | 只看該作者
能把發(fā)送和接收 分開(kāi)發(fā)么    在多弄帶你中文注釋  謝謝樓主分享
ID:227888 發(fā)表于 2017-8-28 13:41 | 只看該作者
謝謝分享
ID:234498 發(fā)表于 2017-9-20 21:17 | 只看該作者
謝謝分享
ID:235537 發(fā)表于 2017-9-25 16:53 | 只看該作者
樓主能給  個(gè) 完整的原理圖嗎
