查看: 3714|回復(fù): 0
Matlab與C語(yǔ)言的接口
ID:77367 發(fā)表于 2015-4-18 21:33 | 顯示全部樓層 |閱讀模式
%Matlab R2009a
Matlab可以將C程序編譯為MEX文件供Matlab調(diào)用,第一步是在Matlab的Command Window下輸入命令mex- setup,并根據(jù)Matlab的提示選擇合適的選項(xiàng),如下所示(加粗部分為用戶輸入)。
>> mex -setup
Please choose your compiler for building external interface (MEX) files:
Would you like mex to locate installed compilers [y]/n? y
Select a compiler:
[1] Lcc-win32 C 2.4.1 in D:\PROGRA~1\MATLAB\R2009a\sys\lcc
[2] Microsoft Visual C++ 6.0 in C:\Program Files\Microsoft Visual Studio
[0] None
Compiler: 2
Please verify your choices:
Compiler: Microsoft Visual C++ 6.0
Are these correct [y]/n? y
Trying to update options file: C:\Documents and Settings\yjsjf\Application Data\MathWorks\MATLAB\R2009a\mexopts.bat
From template:              D:\PROGRA~1\MATLAB\R2009a\bin\win32\mexopts\msvc60opts.bat
Done . . .
  Warning: The MATLAB C and Fortran API has changed to support MATLAB
           variables with more than 2^32-1 elements.  In the near future
           you will be required to update your code to utilize the new
           API. You can find more information about this at:
           http://www.mathworks.com/support ... l?solution=1-5C27B9
           Building with the -largeArrayDims option enables the new API.
接下來(lái)是寫(xiě)C文件,在Matlab的Command Window下輸入命令
>>edit hello.c
編輯文件內(nèi)容并保存。
/*hello.c*/
#include "mex.h"
void mexFunction(int nlhs,mxArray* plhs[],int nrhs,const mxArray* prhs[])
    mexPrintf("Hello World!\n");
下一步就是將C語(yǔ)言文件編譯為MEX文件
>> mex hello.c
編譯成功后可以在與hello.c文件相同的目錄下找到hello.mexw32文件,這就是編譯成功的MEX文件。
Tips:程序輸入錯(cuò)誤的話,編譯不能成功,如將hello.c里面的
寫(xiě)成了
mexPrint("Hello World!\n");
就會(huì)出現(xiàn)錯(cuò)誤。。。像下面一樣
>> mex hello.c
Microsoft (R) Incremental Linker Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
C:\DOCUME~1\YJSJF\LOCALS~1\TEMP\MEX_XN~1\hello.obj
   Creating library C:\DOCUME~1\YJSJF\LOCALS~1\TEMP\MEX_XN~1\templib.x and object C:\DOCUME~1\YJSJF\LOCALS~1\TEMP\MEX_XN~1\templib.exp
hello.obj : error LNK2001: unresolved external symbol _mexPrint
hello.mexw32 : fatal error LNK1120: 1 unresolved externals
  D:\PROGRA~1\MATLAB\R2009A\BIN\MEX.PL: Error: Link of 'hello.mexw32' failed.
??? Error using ==> mex at 218
Unable to complete successfully.
====================================分割線=============================================
MEX文件結(jié)構(gòu)說(shuō)明
用C語(yǔ)言編寫(xiě)MEX文件源代碼時(shí),需要包含"mex.h"頭文件,像單片機(jī)要包含 "reg51.h"、"reg52.h"這些文件一樣,例外,代碼不是main函數(shù)作為入口函數(shù),而是mexFunction這個(gè)函數(shù),,即MEX源代碼基本結(jié)構(gòu)就是這樣子。
#include "mex.h"
其中,mexFunction函數(shù)的參數(shù)含義如下
int nlhs  輸出參數(shù)的個(gè)數(shù)
mxArray* plhs[]   輸出參數(shù)的mxArray數(shù)組
int nrhs   輸入?yún)?shù)的個(gè)數(shù)
const mxArray* prhs[]   輸入?yún)?shù)的mxArray數(shù)組
在Matlab中,所有的數(shù)據(jù)類型都使用mxArray結(jié)構(gòu)來(lái)表示,通過(guò)接口函數(shù)mexFunction可以與Matlab環(huán)境進(jìn)行數(shù)據(jù)交換。C語(yǔ)言的基本數(shù)據(jù)類型轉(zhuǎn)換為
mxArray類型是Matlab提供的一系列的操作mxArray的API函數(shù)完成的。其中以mx開(kāi)頭的Matlab API函數(shù)主要提供對(duì)mxArray進(jìn)行操作,以mex開(kāi)頭的Matlab API函數(shù)提供Matlab環(huán)境后臺(tái)操作的函數(shù)。mex開(kāi)頭的Matlab API函數(shù)只能在MEX文件中使用。
