查看: 2352|回復: 0
(文件共享)改良矩陣鍵盤檢測
ID:78517 發(fā)表于 2015-5-7 17:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
uchar code table[]={
    0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
    0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8e
,0};
uchar num,temp,num1,aa;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
dispaly(uchar aa);
uchar keyscan();
        num=13;
                dispaly(keyscan());
dispaly(uchar aa)
        P2=0;
        P0=table[aa-1];
uchar keyscan()
        P1=0xfe;
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(5);
                        temp=P1;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P1;
                                switch(temp)
                                        case 0xee:num=1;
                                        break;
                                        case 0xde:num=2;
                                        break;
                                        case 0xbe:num=3;
                                        break;
                                        case 0x7e:num=4;
                                        break;
                 P1=0xfd;
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(5);
                        temp=P1;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P1;
                                switch(temp)
                                        case 0xed:num=5;
                                        break;
                                        case 0xdd:num=6;
                                        break;
                                        case 0xbd:num=7;
                                        break;
                                        case 0x7d:num=8;
                                        break;
                P1=0xfb;
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(5);
                        temp=P1;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P1;
                                switch(temp)
                                        case 0xeb:num=9;
                                        break;
                                        case 0xdb:num=10;
                                        break;
                                        case 0xbb:num=11;
                                        break;
                                        case 0x7b:num=12;
                                        break;
                P1=0xfe;
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(5);
                        temp=P1;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P1;
                                switch(temp)
                                        case 0xe7:num=13;
                                        break;
                                        case 0xd7:num=14;
                                        break;
                                        case 0xb7:num=15;
                                        break;
                                        case 0x77:num=16;
                                        break;
        return num;
admin + 50 共享資料的積分獎勵!
