查看: 3954|回復(fù): 0
關(guān)于驅(qū)動(dòng)中調(diào)用內(nèi)核函數(shù)實(shí)現(xiàn)gpio寄存器的設(shè)置
ID:85109 發(fā)表于 2015-7-8 22:06 | 顯示全部樓層 |閱讀模式
系列函數(shù)
系列函數(shù)的定義在arch/arm/mach-s3c2410/gpio.c,相關(guān)的宏定義在include/asm-arm/arch-s3c2410/regs-gpio.h
(1)void s3c2410_gpio_setpin(unsigned int pin, unsigned intto);
設(shè)置相應(yīng)GPIO口的輸出值,例如:
pin=S3C2410_GPG2,to=0,則設(shè)置S3C2410_GPG2的輸出值為0;
pin=S3C2410_GPG2,to=1,則設(shè)置S3C2410_GPG2的輸出值為1。
函數(shù)定義:
viewplain
  • void s3c2410_gpio_setpin(unsigned int pin, unsigned int to)
  •     void __iomem *base = S3C2410_GPIO_BASE(pin);
  •     unsigned long offs = S3C2410_GPIO_OFFSET(pin);
  •     unsigned long flags;
  •     unsigned long dat;
  •     local_irq_save(flags);
  •     dat = __raw_readl(base + 0x04);
  •     dat &= ~(1 << offs);
  •     dat |= to << offs;
  •     __raw_writel(dat, base + 0x04);
  •     local_irq_restore(flags);
  • EXPORT_SYMBOL(s3c2410_gpio_setpin);
(2)unsigned int s3c2410_gpio_getpin(unsigned intpin);
獲取相應(yīng)GPIO口的值。
函數(shù)定義:
viewplain
  • unsigned int s3c2410_gpio_getpin(unsigned int pin)
  •     return __raw_readl(base + 0x04) & (1<< offs);
  • EXPORT_SYMBOL(s3c2410_gpio_getpin);
(3)void s3c2410_gpio_cfgpin(unsigned int pin, unsigned intfunction);
設(shè)置相應(yīng)GPIO口的工作模式,輸入、輸出、中斷等。
函數(shù)定義:
viewplain
  • void s3c2410_gpio_cfgpin(unsigned int pin, unsigned int function)
  •     unsigned long mask;
  •     unsigned long con;
  •     if (pin < S3C2410_GPIO_BANKB) {
  •         mask = 1 << S3C2410_GPIO_OFFSET(pin);
  •     } else {
  •         mask = 3 << S3C2410_GPIO_OFFSET(pin)*2;
  •     con  = __raw_readl(base + 0x00);
  •     con &= ~mask;
  •     con |= function;
  •     __raw_writel(con, base + 0x00);
  • EXPORT_SYMBOL(s3c2410_gpio_cfgpin);
(4)unsigned int s3c2410_gpio_getcfg(unsigned intpin);
獲取相應(yīng)GPIO口的工作模式,輸入、輸出、中斷等。
函數(shù)定義:
viewplain
  • unsigned int s3c2410_gpio_getcfg(unsigned int pin)
  •     } else {
  •     return __raw_readl(base) & mask;
  • EXPORT_SYMBOL(s3c2410_gpio_getcfg);
(5)voids3c2410_gpio_pullup(unsigned int pin, unsigned intto);
設(shè)置相應(yīng)的GPIO口的電平,例如:
pin=S3C2410_GPG2,to=0,則拉低S3C2410_GPG2,也就是設(shè)置S3C2410_GPG2的值為0;
pin=S3C2410_GPG2,to=1,則拉高S3C2410_GPG2,也就是設(shè)置S3C2410_GPG2的值為1。
函數(shù)定義:
viewplain
  • void s3c2410_gpio_pullup(unsigned int pin, unsigned int to)
  •     unsigned long up;
  •         return;
  •     up = __raw_readl(base + 0x08);
  •     up &= ~(1L << offs);
  •     up |= to << offs;
  •     __raw_writel(up, base + 0x08);
  • EXPORT_SYMBOL(s3c2410_gpio_pullup);
(6)unsigned int s3c2410_modify_misccr(unsigned int clear,unsigned int change);
雜項(xiàng)設(shè)置,設(shè)置寄存器MISCCR,具體看函數(shù)定義。
函數(shù)定義:
viewplain
  • unsigned int s3c2410_modify_misccr(unsigned int clear, unsigned int change)
  •     unsigned long misccr;
  •     misccr = __raw_readl(S3C2410_MISCCR);
  •     misccr &= ~clear;
  •     misccr ^= change;
  •     __raw_writel(misccr, S3C2410_MISCCR);
  •     return misccr;
  • EXPORT_SYMBOL(s3c2410_modify_misccr);
(7)int s3c2410_gpio_getirq(unsigned intpin);
獲取相應(yīng)的GPIO口所對應(yīng)的中斷號。
函數(shù)定義:
viewplain
  • int s3c2410_gpio_getirq(unsigned int pin)
  •     if (pin < S3C2410_GPF0 || pin > S3C2410_GPG15_EINT23)
  •         return -1;
  •     if (pin < S3C2410_GPG0 && pin > S3C2410_GPF7)
  •         return -1;
  •     if (pin < S3C2410_GPF4)
  •         return (pin - S3C2410_GPF0) + IRQ_EINT0;
  •     if (pin < S3C2410_GPG0)
  •         return (pin - S3C2410_GPF4) + IRQ_EINT4;
  •     return (pin - S3C2410_GPG0) + IRQ_EINT8;
  • EXPORT_SYMBOL(s3c2410_gpio_getirq);
(8)int s3c2410_gpio_irqfilter(unsigned int pin, unsignedint on, unsigned int config);
中斷過濾配置,具體看函數(shù)定義。
函數(shù)定義:
viewplain
  • int s3c2410_gpio_irqfilter(unsigned int pin, unsigned int on,
  •                unsigned int config)
  •     void __iomem *reg = S3C2410_EINFLT0;
  •     unsigned long val;
  •     if (pin < S3C2410_GPG8 || pin > S3C2410_GPG15)
  •         return -1;
  •     config &= 0xff;
  •     pin -= S3C2410_GPG8_EINT16;
  •     reg += pin & ~3;
  •     val = __raw_readl(reg);
  •     val &= ~(0xff << ((pin & 3) * 8));
  •     val |= config << ((pin & 3) * 8);
  •     __raw_writel(val, reg);
  •     val = __raw_readl(S3C2410_EXTINT2);
  •     val &= ~(1 << ((pin * 4) + 3));
  •     val |= on << ((pin * 4) + 3);
  •     __raw_writel(val, S3C2410_EXTINT2);
  •     return 0;
  • EXPORT_SYMBOL(s3c2410_gpio_irqfilter);
