最近做服務器,需要獲取天氣信息,想到了Web Service,以前還沒有用過,這次用了之后感覺很不錯,就是相當于遠程的函數(shù)調用,記錄如下。
1. 添加winform工程MyTest01,在右邊“解決方案資源管理器”的工程文件上點擊右鍵,選擇“添加Web引用”.
2. 在彈出的“添加web引用”對話框中,URL地址里面輸入提供web Service的服務器地址,http://www.webxml.com.cn/WebServices/WeatherWebService.asmx,點擊“前往”按鈕,系統(tǒng)提示“找到1個服務:WeatherWebService”,將我們使用的Web引用名修改為weather,這樣子不用系統(tǒng)默認那么長的一大串名字。添加該引用。
3. 系統(tǒng)會自動打開“對象瀏覽器”,選擇MyTest01.Weather,看看這個WebService都有哪些方法吧。
4.Form1窗口界面上,添加如下控件:
5.在Form1.vb里面添加代碼,實現(xiàn)天氣預報的功能。
Imports MyTest01.Weather
Public Class Form1
Dim MyWeather As Weather.WeatherWebService = New Weather.WeatherWebService()
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim tmpStr(0 To 23) As String
tmpStr = MyWeather.getWeatherbyCityName(Cmb_City.Text.Substring(0, Cmb_City.Text.IndexOf(" ")))
If (tmpStr(8) = "") Then
MessageBox.Show("暫時不支持您查詢的城市")
Else
Label1.Text = "天氣概況:" & tmpStr(1) & " " & tmpStr(6)
TextBox1.Text = tmpStr(10)
TextBox2.Text = tmpStr(11)
TextBox3.Text = tmpStr(13) & "," & tmpStr(12) & "," & tmpStr(14) & vbCrLf & tmpStr(18) & "," & tmpStr(17) & "," & tmpStr(19)
TextBox4.Text = tmpStr(22)
End If
End Sub
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
Dim ProvinceStr() As String
Dim i As Integer
ProvinceStr = MyWeather.getSupportProvince()
For i = ProvinceStr.GetLowerBound(0) To ProvinceStr.GetUpperBound(0)
Cmb_Province.Items.Add(ProvinceStr(i))
Next
Cmb_Province.Text = ProvinceStr(0)
End Sub
Private Sub Cmb_Province_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cmb_Province.SelectedIndexChanged
Dim CityStr() As String
Dim i As Integer
CityStr = MyWeather.getSupportCity(Cmb_Province.Text)
For i = CityStr.GetLowerBound(0) To CityStr.GetUpperBound(0)
Cmb_City.Items.Add(CityStr(i))
Next
Cmb_City.Text = CityStr(0)
End Sub
End Class
6.運行結果:
好玩的實用的WebService還有很多,不過好多都需要掏錢了。
