在STM32固件庫(kù)中,當(dāng)你使用RCC_GetClocksFreq()這個(gè)函數(shù)的時(shí)候,需要注意一下。
(比如,你在使用串口的USART_Init的時(shí)候,就無(wú)形中使用到這個(gè)函數(shù))。
當(dāng)你使用外部晶振做為系統(tǒng)時(shí)鐘的時(shí)候,而且外部晶振不是標(biāo)準(zhǔn)8MHz的時(shí)候,
你需要留意一下STM32的固件庫(kù),里面的stm32f10x_rcc.c這個(gè)文件,
在它的RCC_GetClocksFreq()這個(gè)函數(shù)中,有這么一段
void RCC_GetClocksFreq(RCC_ClocksTypeDef* RCC_Clocks)
u32 tmp = 0, pllmull = 0, pllsource = 0, presc = 0;
/* Get SYSCLK source ——————————————————-*/
tmp = RCC->CFGR & CFGR_SWS_Mask;
switch (tmp)
case 0×00: /* HSI used as system clock */
RCC_Clocks->SYSCLK_Frequency = HSI_Value;
break;
case 0×04: /* HSE used as system clock */
RCC_Clocks->SYSCLK_Frequency = HSE_Value;
break;
case 0×08: /* PLL used as system clock */
/* Get PLL clock source and multiplication factor ———————-*/
pllmull = RCC->CFGR & CFGR_PLLMull_Mask;
pllmull = ( pllmull >> 18) + 2;
pllsource = RCC->CFGR & CFGR_PLLSRC_Mask;
if (pllsource == 0×00)
{/* HSI oscillator clock divided by 2 selected as PLL clock entry */
RCC_Clocks->SYSCLK_Frequency = (HSI_Value >> 1) * pllmull;
{/* HSE selected as PLL clock entry */
if ((RCC->CFGR & CFGR_PLLXTPRE_Mask) != (u32)RESET)
{/* HSE oscillator clock divided by 2 */
RCC_Clocks->SYSCLK_Frequency = (HSE_Value >> 1) * pllmull;
RCC_Clocks->SYSCLK_Frequency = HSE_Value * pllmull;
break;
default:
break;
…. //省略以下代碼
我們追蹤到 HSE_Value 的定義
/* In the following line adjust the value of External High Speed oscillator (HSE)
used in your application */
#define HSE_Value ((u32)8000000) /* Value of the External oscillator in Hz*/
上面的定義說(shuō)明:你需要在你的實(shí)際應(yīng)用的時(shí)候,跟據(jù)實(shí)際的外部晶振的值,修改HSE_Value的值。
如果沒(méi)有留意到這個(gè)情況的話,所有的跟求系統(tǒng)頻率有關(guān)的應(yīng)用,都會(huì)出錯(cuò),例如在固件庫(kù)stm32f10x_usart.c中的設(shè)計(jì)串口波特率的時(shí)候。。。
