TVout is a completely interrupt driven library that will output either NTSC or PAL composite.
Hardware Connections
Connect an RCA plug to the arduino according to the following schematic. A 75 OHM resistor may be needed between VID and GND on the RCA plug for a very small subset ofTVs
