查看: 6631|回復(fù): 0
智能小車(chē)單片機(jī)程序及報(bào)告+流程圖+管腳說(shuō)明
最全單片機(jī)智能小車(chē)制作資料,希望對(duì)大家有幫助
報(bào)告模板:
元器件:
流程圖:
程序:
  1. ORG     0000H
  2. LJMP    MAIN
  3. ORG     0003H
  4. LJMP    MINE_BOMB
  5. ORG     000BH
  6. LJMP    TIMER
  7. ORG     0013H
  8. LJMP    HUOER
  9. ORG     001BH
  10. LJMP    SPEED
  11. ;**************************************************
  12. ORG     0030H
  13. ;**************************************************
  14. MINE_BOMB:
  15.         PUSH    A
  16.         PUSH    PSW
  17.         INC     3AH
  18.         MOV     A,40H
  19.         MOV     3BH,A
  20.         MOV     A,41H
  21.         MOV     3CH,A
  22.         CLR    20H.3
  23.         SETB   P3.4
  24.         SETB   P3.5
  25.         POP     PSW
  26.         POP     A
  27. RETI
  28. ;**************************************************
  29. TIMER:
  30.         PUSH    A
  31.         PUSH    PSW
  32.         MOV       TL0,#0F0H
  33.         MOV       TH0,#0D8H
  34.         INC       37H
  35.         MOV       A,37H
  36.         CJNE      A,#100,TIMEREND
  37. ;is 1second
  38. IS_HUN:
  39.         MOV       37H,#0
  40.         ;            IS C_MINE,STOP AND THAN  XUAN
  41.         JB       20H.0,QI_LAI        ;THIS TIME,THE CAR IS WAITTING IN THE END,
  42.         DEC      39H
  43.         MOV      A,39H
  44.         CJNE     A,#0H,TIMEREND
  45.         SETB     20H.0
  46.         LJMP     TIMEREND
  47. QI_LAI:
  48.         JB       20H.1,WAKE_UP
  49.         DEC      38H
  50.         CPL      P3.4
  51.         MOV      A,38H
  52.         CJNE     A,#0H,WAKE_UP
  53.         SETB     20H.1
  54.         CLR      P3.4
  55.         SETB     TR1
  56.         MOV      5AH,#23
  57. WAKE_UP:
  58.         INC       43H
  59.         MOV       A,43H
  60.         CJNE      A,#30,GOGOGO_DOWN
  61.         MOV       A,42H
  62.         JZ        GOGOGO_DOWN
  63.         LJMP      HOME
  64. GOGOGO_DOWN:
  65.         MOV       A,43H
  66.         CJNE      A,#60,TIMEREND
  67.         MOV       43H,#0
  68.         INC       42H
  69.         MOV       A,42H
  70.         CJNE      A,#60,TIMEREND
  71.         MOV       42H,#0
  72. TIMEREND:
  73.         POP     PSW
  74.         POP     A
  75. RETI
  76. ;**************************************************
  77. HUOER:
  78.         PUSH    A
  79.         PUSH    PSW
  80.         MOV     A,3FH
  81.         CLR     C
  82.         ADD     A,#64    ;加上6.3毫米
  83.         CJNE    A,#100,CHECK_CM
  84. CHECK_CM:
  85.         JC      ADD_CM
  86.         SUBB    A,#100    ;大于10個(gè)毫米了,要作調(diào)整
  87.         MOV     3FH,A
  88.         INC     41H
  89. ADD_CM:                   ;厘米上要加2
  90.         INC     41H
  91.         INC     41H
  92.         MOV     A,41H
  93.         CJNE    A,#100,CHECK_M
  94. CHECK_M:
  95.         JC      HUOER_END
  96.         SUBB    A,#100    ;大于一米了,要調(diào)整一下
  97.         MOV     41H,A
  98.         INC     40H
  99.         ;查看是否是兩米了,是的話就算到了B區(qū)
  100.         MOV     A,40H
  101.         CJNE    A,#2,HUOER_END
  102.         MOV     36H,#0BH
  103. HUOER_END:
  104.         POP     PSW
  105.         POP     A
  106. RETI
  107. ;**************************************************
  108. SPEED:
  109.         PUSH    A
  110.         PUSH    PSW
  111.         MOV       TL1,#0B0H
  112.         MOV       TH1,#03CH
  113.         INC       5BH
  114.         MOV       A,5BH
  115.         CJNE      A,5AH,SPEED_NO_EQUAL   ; 5A中放了速度值,比5A大,剛置為停,小則行
  116.         CLR       P3.0                   ; 等于5A了,置為停
  117.         LJMP      SP_END
  118. SPEED_NO_EQUAL:                          ; 不是5A
  119.         JC       IS_GOGOGO               ; 小于5A,則向前走
  120.         CJNE     A,#40,SP_BIG_TOTAL      ; 是不是比總脈沖值大
  121.         SETB     P3.0
  122.         MOV      5BH,#0H
  123.         LJMP     SP_END
  124. IS_GOGOGO:                               ;是行,就置行
  125.         SETB     P3.0
  126.         LJMP     SP_END
  127. SP_BIG_TOTAL:                            ; 大于5A,不是40
  128.         CLR      P3.0
  129.         JC       SP_END                  ;比40小則是停,就不管
  130.         MOV      5AH,#0H
  131. SP_END:
  132.         POP     PSW
  133.         POP     A
  134. RETI
  135. ;**************************************************
  136. ;**************************************************
  137. MAIN:
  138.         MOV     SP,#5FH
  139.         LCALL   INIT
  140.     ;   LJMP    HOME;\\\\\\\\\
  141. SIX_SECOND:
  142.         JB      20H.0,GO_MINE_ZEON
  143.         MOV     R1,#39H
  144.         LCALL   SETCODEALL
  145.         LCALL   OUT
  146.         LJMP    SIX_SECOND
  147. GO_MINE_ZEON:
  148.         SETB     TR1
  149.         LJMP     MINE_WAY
  150. RET
  151. ;**************************************************
  152. ;**************************************************
  153. INIT:
  154.      MOV        R1,#36H
  155.      MOV        R2,#34
  156. INIT_LOOP:
  157.      MOV        @R1,#0
  158.      INC        R1
  159.      DJNZ       R2,INIT_LOOP
  160.      MOV        20H,#0H
  161.      SETB       20H.1
  162.      SETB       20H.3
  163.      MOV        39H,#6H      ;倒計(jì)時(shí)654321
  164.      MOV        38H,#5H      ;倒計(jì)時(shí)54321
  165.      MOV        5AH,#24      ;用于車(chē)速控制
  166.      MOV        36H,#0AH
  167.      MOV        P3,#0CH
  168.      MOV        P2,#0H
  169. INT_ZONE:
  170.      LCALL      SET_INT
  171. RET
  172. ;**************************************************
  173. SET_INT:
  174.      MOV       TMOD,#01H
  175.      MOV       TL0,#0F0H
  176.      MOV       TH0,#0D8H
  177.      MOV       TL1,#0B0H
  178.      MOV       TH1,#03CH
  179.      SETB      TR0
  180.      CLR       TR1
  181.      SETB      EA
  182.      SETB      ET0
  183.      SETB      ET1
  184.      SETB      EX0
  185.      SETB      IT0
  186.      SETB      EX1
  187.      SETB      IT1
  188. RET
  189. ;**************************************************
  190. SETCODEALL:;6543210
  191.         MOV     R0,#30H
  192.         MOV     R2,#6
  193. SETCODEALL_LOOP:
  194.         MOV     A,@R1
  195.         MOV     DPTR,#TAB
  196.         MOVC    A,@A+DPTR
  197.         MOV     @R0,A
  198.         INC     R0
  199.         DJNZ    R2,SETCODEALL_LOOP
  200. RET
  201. ;**************************************************
  202. ;**************************************************
  203. MINE_WAY:
  204.         LCALL TRACK
  205.         JB    20H.3,MINE_WAY
  206.         MOV     C,P3.2           ;下面有雷,就是低
  207.         JC    MINE_WAY
  208.         ;下面是關(guān)小燈和蜂鳴器
  209.         CLR     P3.4
  210.         CLR     P3.5
  211.         ;看看長(zhǎng)度是否超過(guò)4米
  212.         MOV     A,40H
  213.         CJNE    A,#4H,PASS_C
  214.         LJMP    C_POINT
  215. PASS_C:
  216.         JNC     C_POINT
  217.         ;下面調(diào)用一般雷的處理方法,再返回主程序
  218.         LCALL   NORMAL_MINE
  219.         LJMP    MINE_WAY
  220.         ;下面是到達(dá)C點(diǎn)了
  221. C_POINT:
  222.         CLR     20H.1
  223.         LCALL   FIVE_SECOND
  224.         SETB    20H.3
  225.         SETB    TR1
  226.         MOV     5AH,#23
  227.         LJMP    BOLK
  228. RET
  229. ;****************************************************
  230. TRACK:
  231.       MOV       A,P0
  232.       ANL       A,#07H
  233.       CJNE      A,#7H,SET_TURN
  234.       LJMP      LIGHT_END
  235. SET_TURN:
  236.       CJNE      A,#3H,LIGHT_NEXT
  237. RIGHT_LIGHT:         ;  看右邊的光敏元件
  238.       CLR       P2.7        ;這時(shí)就要向右轉(zhuǎn)彎了
  239.       SETB      P2.6
  240.       LCALL     TURN_DELAY
  241.       CLR       P2.6
  242.       RET
  243. LIGHT_NEXT:          ; 左轉(zhuǎn)了
  244.       CJNE      A,#06H,LIGHT_END
  245.       SETB      P2.7
  246.       SETB      P2.6
  247.       LCALL     TURN_DELAY
  248.       CLR       P2.6
  249.       RET
  250. LIGHT_END:
  251.       CLR   P2.6
  252. RET
  253. ;****************************************************
  254. TURN_DELAY:
  255.       MOV        5AH,#26
  256.       MOV        C, P0.1
  257.       JC         TURN_DELAY
  258.       MOV        A,36H
  259.       CJNE       A,#0AH,IS_ZONE_B
  260.       MOV        5AH,#24
  261.       LJMP       TURN_DELAY_END
  262. IS_ZONE_B:
  263.       MOV        5AH,#20
  264. TURN_DELAY_END:
  265. RET
  266. ;****************************************************
  267. NORMAL_MINE:
  268.       CLR        TR1
  269.       CLR        P2.6
  270.       ;以下是保存雷長(zhǎng)度
  271.       MOV       A,3CH
  272.       ADD       A,#53H
  273.       MOV       R0,A
  274.       CLR       C
  275.       MOV       A,41H
  276.       ADD       A,#100
  277.       SUBB      A,3CH
  278.       CJNE      A,#100,NORMAL_MINE_LENGTH
  279. NORMAL_MINE_LENGTH:
  280.       JC        NO_CHANGE
  281.       SUBB      A,#100
  282. NO_CHANGE:
  283.       MOV       @R0,A
  284.       ;以下是計(jì)算中點(diǎn)距起點(diǎn)的距離
  285.       MOV       B,#2H
  286.       DIV       AB
  287.       ADD       A,3CH
  288.       CJNE      A,#100,SET_CENTER
  289. SET_CENTER:
  290.       JC        NO_P_WAY
  291.       SUBB      A,#100
  292.       INC       3BH
  293. NO_P_WAY:
  294.       MOV       3CH,A
  295.       ;保存中點(diǎn)距離
  296.       MOV       A,3AH
  297.       DEC       A
  298.       MOV       B,#2H
  299.       MUL       AB
  300.       MOV       R0,48H
  301.       ADD       A,R0
  302.       MOV       R0,A
  303.       MOV       A,3BH
  304.       MOV       @R0,A
  305.       INC       R0
  306.       MOV       A,3CH
  307.       MOV       @R0,A
  308.       CLR        P3.0
  309.       CLR        P3.1
  310.       CLR        P2.6
  311.       CLR        TR1
  312.       ;以下是延時(shí)顯示程序
  313.       LCALL      DELAY_MINE2
  314.       CLR        P3.1
  315.       SETB       P3.0
  316.       SETB       TR1
  317.       SETB       20H.3
  318. RET
  319. ;****************************************************
  320. DELAY_MINE1:
  321.       MOV       R6,#2H
  322. DELAY_LOOP_MINE1:
  323.       LCALL      DELAY
  324.       DJNZ       R6,DELAY_LOOP_MINE1
  325. RET
  326. ;****************************************************
  327. ;****************************************************
  328. DELAY_MINE2:
  329.       LCALL     SET_CODE_MINE
  330.       MOV       R5,#03H
  331. DELAY_LOOP_MINE_F:
  332.       MOV       R6,#08FH
  333.       DELAY_LOOP_MINE2:
  334.            LCALL      OUT
  335.            DJNZ       R6,DELAY_LOOP_MINE2
  336.       DJNZ     R5,DELAY_LOOP_MINE_F
  337. RET
  338. ;****************************************************
  339. SET_CODE_MINE:
  340.       MOV     A,3BH
  341.       MOV     B,#0AH
  342.       DIV     AB
  343.       MOV     44H,A
  344.       MOV     45H,B
  345.       MOV     A,3CH
  346.       MOV     B,#0AH
  347.       DIV     AB
  348.       MOV     46H,A
  349.       MOV     47H,B
  350.       LCALL   SET_CODE
  351. RET
  352. ;****************************************************
  353. FIVE_SECOND:
  354.          CLR        TR1
  355.          CLR        P2.6
  356.          SETB       P3.1
  357.          SETB       P3.0
  358.          LCALL      DELAY_MINE1
  359.          CLR        P3.0
  360.          CLR        P3.1
  361.          CLR        P2.6
  362.          SETB       P3.5
  363.          SETB       P3.4
  364.          CLR        TR1
  365. STOP_AT_C:
  366.         MOV     R1,#38H
  367.         LCALL   SETCODEALL
  368.         JB      20H.1,C_WAKE_LE
  369.         LCALL   OUT
  370.         LJMP    STOP_AT_C
  371. C_WAKE_LE:
  372.         SETB    TR1
  373. RET
  374. ;****************************************************
  375. ;****************************************************
  376. BOLK:
  377.         SETB    TR1
  378.         MOV     5AH,#20
  379. SEEK_LAMP:
  380.         LCALL   TURN_TO_LAMP
  381.         MOV     C,P0.1
  382.         JNC     HOME
  383.         JB      20H.6,SEEK_LAMP
  384.         MOV     C,P0.6
  385.         JC      SEEK_LAMP
  386. AV:     LCALL   AVOID_WHITE_BOLK
  387.         MOV     C,P0.6
  388.         JNC     AV
  389.         SETB    20H.6
  390.         LJMP    SEEK_LAMP
  391. RET
  392. ;******************************************************
  393. TURN_TO_LAMP:
  394.         MOV  C,P0.3
  395.         JNC  LOOK_RIGHT
  396.         LCALL  TURN_LEFT_MIDDLE
  397.         RET
  398. LOOK_RIGHT:
  399.         MOV     C,P0.5
  400.         MOV     R6,#4FH
  401. FORWARDLIGHT:
  402.         LCALL   DELAY
  403.         DJNZ    R6,FORWARDLIGHT
  404.         JNC     TURN_TO_LAMP_END
  405.         LCALL   TURN_RIGHT_MIDDLE
  406.         RET
  407. TURN_TO_LAMP_END:
  408. RET
  409. ;******************************************************
  410. ;******************************************************
  411. AVOID_WHITE_BOLK:
  412.          CLR     TR1
  413.          CLR    P2.7
  414.          SETB    P2.6
  415.          SETB    P3.1
  416.          LCALL   DELAY
  417.
  418.          SETB    TR1
  419.          MOV    R5,#05H
  420. AVOID_R5:
  421.          MOV    R6,#0FFH
  422. AVOID_R6:
  423.          LCALL  DELAY
  424.          DJNZ   R6,AVOID_R6
  425.          DJNZ   R5,AVOID_R5
  426.
  427.          CLR     TR1
  428.          CLR     P2.6
  429.          CLR     P3.1
  430.
  431.          LCALL  DELAY
  432.          SETB    TR1
  433.          MOV    R5,#06H
  434. AVOID_R52:
  435.          MOV    R6,#0FFH
  436. AVOID_R62:
  437.          LCALL  DELAY
  438.          DJNZ   R6,AVOID_R62
  439.          DJNZ   R5,AVOID_R52
  440.
  441.
  442.          MOV     5AH,#30
  443.          MOV    R6,#3FH
  444. AVOID_LOOP:
  445.          LCALL  DELAY
  446.          DJNZ   R6,AVOID_LOOP
  447.          MOV    C,P0.6
  448.          JNC    AVOID_WHITE_BOLK
  449.          MOV    5AH,#20
  450.          CLR     P2.6
  451. RET
  452. ;******************************************************
  453. HOME:
  454.         MOV     IE,#0H
  455.         MOV     IE,#0H
  456.         CLR     P2.6
  457.         CLR     P3.0
  458. HOME_WAIT:
  459.         CLR     P2.6
  460.         CLR     P3.0
  461.         SETB    P3.4
  462.         LCALL   KEY_QUERY     ; 查詢鍵盤(pán)
  463.         LCALL   TIP_SET_CODE  ; 設(shè)置顯示值
  464.          MOV     R1,#44H
  465.          LCALL   SET_CODE
  466.         LCALL   OUT           ; LED 輸出
  467.         LJMP    HOME_WAIT
  468. RET
  469. ;******************************************************
  470. KEY_QUERY:
  471.         LCALL   KEY
  472.         JNC    KEY_QUERY_END
  473.         LCALL   KEY
  474.         JNC      KEY_QUERY_END
  475.         LCALL   DEAL_KEY
  476. KEY_WA:
  477.         LCALL   KEY
  478.         JC      KEY_WA
  479. KEY_QUERY_END:
  480. RET
  481. RET
  482. ;******************************************************
  483. TIP_SET_CODE:
  484.         MOV  A,59H
  485.         JZ   SET_TIME
  486.         MOV     R0,#46H
  487.         MOV     B,#02H
  488.         MUL     AB
  489.         ADD     A,R0
  490.         MOV     R0,A
  491. SET_NUM:
  492.         MOV     A,@R0
  493.         MOV     B,#0AH
  494.         DIV     AB
  495.         MOV     44H,A
  496.         MOV     45H,B
  497.         INC     R0
  498.         MOV     B,#0AH
  499.         MOV     A,@R0
  500.         DIV     AB
  501.         MOV     46H,A
  502.         MOV     47H,B
  503.         RET
  504. SET_TIME:
  505.         MOV     R0,#42H
  506.         LJMP    SET_NUM
  507. RET
  508. ;*****************************************************
  509. OUT:
  510.         MOV     R0,#30H
  511.         MOV     R2,#6H
  512.         MOV     R4,#0H
  513. LOOP:
  514.         MOV     A,@R0
  515.         LCALL   OUTPUT
  516.         INC     R0
  517.         INC     R4
  518.         DJNZ    R2,LOOP
  519. RET
  520. ;*******************************************************
  521. OUTPUT: ;在A中是要顯示的數(shù)據(jù),R4中是要顯示的位
  522.         MOV     R3,#8H
  523.         CLR     P1.3
  524. OUT_LOOP:
  525.         RLC     A
  526.         MOV     P1.2,C
  527.         CLR     P1.4
  528.         NOP
  529.         NOP
  530.         NOP
  531.         SETB    P1.4
  532.         NOP
  533.         NOP
  534.         NOP
  535.         DJNZ    R3,OUT_LOOP
  536. OUT_LOOP_END:
  537.         MOV     P1,R4
  538.         SETB    P1.3
  539.         LCALL   DELAY
  540.         CLR     P1.3
  541. RET
  542. ;******************************************************
  543. SET_CODE:
  544.         MOV     R0,#44H
  545.         MOV     R1,#30H
  546.         MOV     R2,#4H
  547. SET_CODE_LOOP:
  548.         MOV     A,@R0
  549.         MOV     DPTR,#TAB
  550.         MOVC    A,@A+DPTR
  551.         MOV     @R1,A
  552.         INC     R0
  553.         INC     R1
  554.         DJNZ    R2,SET_CODE_LOOP
  555.         ;以下是顯示是第幾個(gè)雷
  556.         MOV     A,3AH
  557.         MOV     DPTR,#TAB
  558.         MOVC    A,@A+DPTR
  559.         MOV     35H,A
  560.         ;以下是使一個(gè)LED為暗
  561.         MOV     34H,#0H
  562. RET
  563. ;******************************************************
  564. TAB:   DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH,77H,7CH,39H,5EH,79H,71H
  565. ;*****************************************************
  566. KEY:
  567.         MOV     58H,#0FEH;
  568.         MOV     R1,#4H
  569. KEY_LOOP:
  570.         MOV     P1,58H
  571.         MOV     A,P1
  572.         CJNE    A,58H,KEY_NEXT1
  573.         MOV     A,58H ;NO KEY FIND
  574.         RL      A
  575.         MOV     58H,A
  576.         DJNZ    R1,KEY_LOOP
  577.         CLR    C
  578.         LJMP    KEY_END
  579. KEY_NEXT1:
  580.         SETB    C
  581. KEY_END:
  582. RET
  583. DEAL_KEY:
  584.          MOV    A,58H
  585.          MOV    P1,#0F0H
  586.          CJNE   A,#0FEH,TWO
  587. ONE_1:   SETB   P1.1
  588.          NOP
  589.          MOV    C,P1.1
  590.          JC    ONE_2
  591.          MOV    59H,#0EH
  592.          LJMP   DEAL_END
  593. ONE_2:   SETB   P1.2
  594.          MOV    C,P1.2
  595.          JC    ONE_3
  596.          MOV    59H,#07H
  597.          LJMP   DEAL_END
  598. ONE_3:   MOV    59H,#0FH
  599.          LJMP   DEAL_END
  600. TWO:     CJNE   A,#0FDH,THREE
  601. TWO_1:   SETB   P1.0
  602.          MOV    C,P1.0
  603.          JC    TWO_2
  604.          MOV    59H,#2H
  605.          LJMP   DEAL_END
  606. TWO_2:   SETB   P1.2
  607.          MOV    C,P1.2
  608.          JC    TWO_3
  609.          MOV    59H,#6H
  610.          LJMP   DEAL_END
  611. TWO_3:   MOV    59H,#9H
  612.          LJMP   DEAL_END
  613. THREE:   CJNE   A,#0FBH,FOUR
  614. THREE_1: SETB   P1.0
  615.          MOV    C,P1.0
  616.          JC    THREE_2
  617.          MOV    59H,#1H
  618.          LJMP   DEAL_END
  619. THREE_2: SETB   P1.1
  620.          MOV    C,P1.1
  621.          JC    THREE_3
  622.          MOV    59H,#4H
  623.          LJMP   DEAL_END
  624. THREE_3: MOV    59H,#8H
  625.          LJMP   DEAL_END
  626. FOUR:
  627. FOUR_1:  SETB   P1.0
  628.          MOV    C,P1.0
  629.          JC    FOUR_2
  630.          MOV    59H,#0H
  631.          LJMP   DEAL_END
  632. FOUR_2:  SETB   P1.1
  633.          MOV    C,P1.1
  634.          JC    FOUR_3
  635.          MOV    59H,#3H
  636.          LJMP   DEAL_END
  637. FOUR_3:  MOV    59H,#5H
  638.          LJMP   DEAL_END
  639. DEAL_END:
  640. RET
  641. ;******************************************************
  642. DELAY:
  643.         MOV     R7,#0FFH
  644. DELAY_LOOP:
  645.         DJNZ    R7,DELAY_LOOP
  646. RET
  647. ;******************************************************
  648. TURN_RIGHT_MIDDLE:
  649.          MOV      5AH,#30
  650. TURN_RIGHT_MIDDLE_START:
  651.          CLR    P2.7
  652.          SETB   P2.6
  653.          MOV    C,P0.3
  654.          JNC    TURN_RIGHT_MIDDLE_START
  655.          CLR    P2.6
  656.          MOV    5AH,#23
  657. RET
  658. ;******************************************************
  659. TURN_LEFT_MIDDLE:
  660.           MOV    5AH,#30
  661. TURN_LEFT_MIDDLE_START:
  662.          SETB   P2.7
  663.          SETB   P2.6
  664.           MOV    C,P0.5
  665.          JNC    TURN_RIGHT_MIDDLE_START
  666.          CLR    P2.6
  667.          MOV    5AH,#23H
  668. RET
  669. ;*********************************************
  670. END
全國(guó)大學(xué)電子設(shè)計(jì)大賽_智能小車(chē).rar (512.05 KB, 下載次數(shù): 12)
