查看: 4257|回復(fù): 0
AVR I2C通信程序
ID:119428 發(fā)表于 2016-5-9 09:08 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
uchar SDA_Return(void)//0-low level  1-hign level
          uchar flag;
          uchar oldSREG=SREG;
          SREG&=~(_BV(7));
   DDRC&=0xfd;
   PORTC|=_BV(PC1);
   if((PINC&_BV(PC1)) !=0)//0000 0010
        flag=1;
        flag=0;
                SREG=oldSREG;
                return flag;
void delay(void)
void start(void)
        SDA_1;
        delay();
        SCL_1;
        delay();
        SDA_0;
        delay();
void stop(void)
        SDA_0;
        delay();
    SCL_1;
        delay();
    SDA_1;
        delay();
void respons(void)
        uchar i=0;
        SCL_1;
        delay();
        while((SDA_Return())&&(i<250))i++;
        SCL_0;
        delay();
void I2C_init(void)
        SDA_1;
        delay();
        SCL_1;
        delay();
void write_byte(unsigned char i)
    unsigned char temp,num=0;
    for(temp=0;temp<8;temp++)
            num=i&0x80;
        SCL_0;
        delay();
        if(num==0)
            {SDA_0; }
            {SDA_1; }
        delay();
                SCL_1;
                delay();
                i=i<<1;
                delay();
        SCL_0;
    delay();
        SDA_0;
    delay();
uchar read_byte(void)
        uchar i,j,value=0;
                SCL_0;
        for(i=0;i<8;i++)
                value<<=1;
                value|=SDA_Return();
                SCL_1;
                delay();
                //delay();
                SCL_0;
                delay();
        return value;
void Ack_I2c(void)
        SDA_0;
        delay();
        SCL_1;
        delay();
        SCL_0;
        delay();
        SDA_1;
void NAck_I2c(void)
        SDA_1;
        delay();
        SCL_1;
        delay();
        SCL_0;
        delay();
